    Z-probe commissioning problem
    Smart effector for delta printers
    5.4k
    • number40fanundefined
      number40fan
      Have you changed the H number yet? Just wonder if it is freaking out because your homed height is greater than what your config is.
        number40fan
        M665 R246.6 L440.0 B180 H443
        Try this and see what happens.
        • RGN01undefined
          RGN01
          @number40fan:
          Yes, if I manually lower the nozzle from homed position it stops at bed height so that seems OK.
          • RGN01undefined
            RGN01
            @number40fan:
            I have that already - after changing it earlier.
            In an effort to fix the 'freezing' problem, I replaced deployprobe.g - it now reacts to the G30 command without freezing - but the original problem returns and it ignores a touch on the nozzle during the G30 operation.
              number40fan
              Notes from the Wiki.
              Version 1.19
              Upgrade notes from version 1.18.2:
              •Recommended DuetWebControl version is 1.19
              •Recommended DuetWiFiServer version is 1.19
              •Important! If you use an IR Z probe or some other type that does not need to be deployed, delete the files sys/deployprobe and sys/retractprobe.g if they exist, because they are now called automatically. You can do this in the System Files Editor of the web interface.
              You do need those two files removed, so your issue is somewhere else.
                number40fan
                So, now when the nozzle is at the bed, the web interface reads 0 for Z height?
                • RGN01undefined
                  RGN01
                  @number40fan:
                  Version 1.19
                  If I remove deployprobe.g then I get the freezing issue. It contains the following:
                  [[language]]
                  ; Probe deployment routine for Mini Kossel
                  M564 S0					; don't apply limits
                  G1 X25 Y93 Z40 F10000	; put probe arm next to belt
                  G1 X-5 F500				; move probe arm across belt
                  G1 X12 F1000			; move probe back
                  G1 X0 Y0 F10000			; move to somewhere sensible
                  M564 S1					; apply limits again
                  With that file in place, it seems to execute the commands, then probes the bed (green LED flash) and then stops with z=-0.1. Without that file it does none of those operations and enters a permanently busy state.
                  I will try and comment those lines out 1 by 1 to find which one is required to make G30 work.
                    number40fan
                    @RGN01:
                    I've also homed the printer and slowly dropped the nozzle until it just touches the bed. The Z-height readings were:
                    Homed: 645.0
                    Touching bed: 212.5
                    This is what I don't get. When you home a printer, it doesn't count how far it moved until it activates the endstop switches. It just moves until it hits them, backs off, moves slowly until it hits again and usually moves away 5mm or so. That is your homed height. The Duet then uses your H number from M665 to determine how far above the bed the nozzle is. How was yours showing 645 with 550 in the M665? Do you have a config-override.g file?
                    • RGN01undefined
                      RGN01
                      @number40fan:
                      @RGN01:
                      Homed: 645.0
                      Touching bed: 212.5
                      Yes, there is a config-override.g file with a warning not to edit it as it is machine generated.
                      With the deployprobe.g file as below, G30 seems to work (although it does leave the nozzle at -0.1)
                      [[language]]
                      G1 X0 Y0 F25000			; move to somewhere sensible
                      Without that file, or with that line commented out, G30 does not work.
                      • MoS-tekknixundefined
                        MoS-tekknix
                        Good point, that is always pain in the ass if you forget it 😉
                          number40fan
                          Can you paste what is in it?
                            MoS-tekknix
                            Please show us your config-override.g
                            • RGN01undefined
                              RGN01
                              @number40fan:
                              @RGN01:
                              Homed: 645.0
                              Touching bed: 212.5
                              OK, just realised that was a typo - 645 should have been 445. I'm really sorry for the confusion!
                                MoS-tekknix
                                No need to say sorry for anything. Still interessted in the override-settings….
                                  number40fan
                                  Have you ran anything that required a M500 command like a hotend or heat bed calibration?
                                  • RGN01undefined
                                    RGN01
                                    @number40fan:
                                    Yes, I did that twice - for bed PID and hotend PID auto tune.
                                      number40fan
                                      @RGN01:
                                      But it still showed 212 touching the bed?
                                        MoS-tekknix
                                        Please paste the content in.
                                        • RGN01undefined
                                          RGN01
                                          The config-override.g file looks like this:
                                          [[language]]
                                          ; Delta parameters
                                          M665 R246.6 L440.0 B180 H433
                                          M666 X0.000 Y0.000 Z0.000 A0.00 B0.00
                                          ; Heater model parameters
                                          M307 H0 A645.6 C1147.3 D12.1 S1.00 B0
                                          M307 H1 A533.4 C223.7 D3.0 S1.00 B0
                                          M307 H2 A340.0 C140.0 D5.5 S1.00 B0
                                          M307 H3 A340.0 C140.0 D5.5 S1.00 B0
                                          M307 H4 A340.0 C140.0 D5.5 S1.00 B0
                                          M307 H5 A340.0 C140.0 D5.5 S1.00 B0
                                          M307 H6 A340.0 C140.0 D5.5 S1.00 B0
                                          M307 H7 A340.0 C140.0 D5.5 S1.00 B0
                                          ; Z probe parameters
                                          G31 T1 P100 X0.0 Y0.0 Z-0.10
                                          G31 T3 P500 X0.0 Y0.0 Z0.70
                                          G31 T4 P500 X0.0 Y0.0 Z0.00
                                          • RGN01undefined
                                            RGN01
                                            I removed the bed to check on the fans in the control box. After re-installing,, the homed Z-height now reads 441.39 and it reads 9.39 when touching the bed.
