    Strange Behavior , after "Pause" 'Cancel ""print again"
    Beta Firmware
    1.9k
    • moth4017undefined
      moth4017 @Phaedrux
      @phaedrux ```
      ;cancel.g
      G28 X Y
      ; homex.g
      ; called to home the X axis
      ;M98 P/macros/sensorless_Z
      G91               		; relative positioning
      G1 H1 X-235 F12000 		; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X15 F6000    		; go back a few mm
      G1 H1 X-235 F360  		; move slowly to X axis endstop once more (second pass)
      ;G1 H2 Z-5 F12000   		; lower Z again
      G90  					; absolute positioning
      G1 X20 F6000			; go to X 0 print area
      G92 X0					; set X to 0 position
      ;sensorless_z
      M915 P0.4:0.5:0.6 S3 F0 R0                          ; Configure Z-Axis Stall Detection
      M906 Z300	                                  		; Lower motor current by 50%
      M574 Z2 S4                                       	; Configure Z-Axis stall detection homing
      M400                                             	; make sure everything has stopped before we make changes
      M906 Z1000	                                  		; Reset motor current
      M400
      ; homey.g
      ; called to home the Y axis
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 11:07:38 GMT+1300 (New Zealand Daylight Time)
      G1 H1 Y315 F12000 			; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y15 F12000    		; go back a few mm
      G1 H1 Y315 F360  			; move slowly to Y axis endstop once more (second pass)
      ;G1 H2 Z-5 F12000   			; higher Z again
      G1 Y0 F6000					; go to X 0 print area
      G92 Y0						; set X to 0 position```
      ; pause.g
      ; called when a print from SD card is paused
      M83            ; relative extruder moves
      G1 E-10 F3600  ; retract 10mm of filament
      G1 Z5 F360     ; lift Z by 5mm
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      G28 X Y
        Phaedrux Moderator @moth4017
        @moth4017 said in Strange Behavior , after "Pause" 'Cancel ""print again":
        You may need to start quoting your file names when calling macros. It should be fine in standalone mode, but in SBC mode it is required and may be required in standalone in the future.
        It's a long shot, but still worth a shot.
        M98 P"/macros/sensorless_Z"
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @Phaedrux
          @phaedrux
          No change
          Cancelled printing file 0:/gcodes/Body1_0.35mm_ABS__17m.gcode, print time was 0h 0m
          Error: Failed to home axes
          Error: Driver 0.4 error: over temperature shutdown
          Error: Driver 0.5 error: over temperature shutdown
          Warning: Driver 0.5 warning: over temperature warning
          Warning: Driver 0.4 warning: over temperature warning
            Are your drivers actually getting hot to the touch or are they spurious warnings? Printing is working correctly, right?
            • moth4017undefined
              moth4017 @Phaedrux
              @phaedrux
              No they are not hot and i did a 8 hour print and they were ok , i only get that error after the "Pause, Cancel"
                I assume you're in stealthchop mode for the stall detection?
                • moth4017undefined
                  moth4017 @Phaedrux
                  @phaedrux
                  M569 P0.4 S1 D3 V30 ; physical drive 4 goes forwards D3=stealthchop
                  M569 P0.5 S0 D3 V30 ; physical drive 5 goes backwards
                  M569 P0.6 S1 D3 V30 ; physical drive 6 goes forwards
                    Can you zip up the entire sys and macros folders and share them with me, either upload them here but first change the file extension to .txt or use a file sharing cloud service. I'd like to get a complete look at what's going on with the actual files.
                    • moth4017undefined
                      moth4017 @Phaedrux
                      @phaedrux system_21_04-22.txt macros_21_-4_22.txt
                        Thanks, I'll have a look tomorrow.
                        • moth4017undefined
                          moth4017 @Phaedrux
                          @phaedrux
                          Cheers
                          Mark
                            Can you try copying your cancel.g to stop.g?
                            • moth4017undefined
                              moth4017 @Phaedrux
                              @phaedrux
                              Hi
                              ; stop.g
                              ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                              ;cancel.g
                              G28 X Y
                              Copied cancel .g to stop.g
                              Did "Pause" "M0" stop.g ran perfectly
                              Did "Pause " "cancel" ran perfectly
                              Did "Print again" after cancel
                              Cancelled printing file 0:/gcodes/Body1_0.2mm_ABS__9h28m.gcode, print time was 0h 1m
                                I just noticed in your pack of files that cancel.g has a leading blank space character.
                                2d257d8b-aba0-4070-8242-dd1f69d558cb-Screen Shot 2022-03-22 at 12.16.36 AM.png Screen Shot 2022-03-22 at 12.16.36 AM.png
                                  Do you have a start.g file? If not, can you create one and add G28 to it?
                                  That should make sure all axis are homed before the sliced gcode is executed.
                                  I think the over temperature warnings on drivers 0.4 and 0.5 may be related to stall detection on the Z axis.
                                  moth4017undefined 2 Replies Last reply Reply Quote 0
                                  • moth4017undefined
                                    moth4017
                                    @phaedrux
                                    Will do ill test now so you have results in the morning
                                    • moth4017undefined
                                      moth4017 @Phaedrux
                                      @phaedrux
                                      Interesting after removing the "space " from the "cancel.g" file the commands now work
                                      also the over temperture errors seem to have stopped, will do more checks to confirm
                                      • moth4017undefined
                                        moth4017 @Phaedrux
                                        @phaedrux
                                        After testing , I can confirm all the above issues are caused by the space in front of the " Cancel.g" file , including the errors below.
                                        Thanks for the help. im guessing you will want to trap this issue some how, help happy to help test if needed .
                                        🅱 Cancelled printing file 0:/gcodes/Body1_0.35mm_PLA__17m.gcode, print time was 0h 0m
                                        Error: Probe was not triggered during probing move
                                        Error: Driver 0.6 error: over temperature shutdown
                                          Well I think what's happening here is that with the cancel.g basically missing when the print is canceled it's getting sent M0
                                          https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m0-stop-or-unconditional-stop
                                          Then when trying to print again the machine is not in a ready state. When the motors are in stealthchop mode they require a short tuning move and I guess that's not happening, hence the errors.
                                          It would be best to have a cancel.g and stop.g file present with the commands you wish to happen. Use M0 as your slicer end gcode, then have all your ending commands in stop.g.
                                          You can also use a start.g file that has any preparation commands you want. Like homing the printer, pre-heating, etc.
                                          That should give you more predictable behaviour.
                                          • moth4017undefined
                                            moth4017 @Phaedrux
                                            @phaedrux
                                            Thank you for the advice, please close thiis thread
                                            • Phaedruxundefined Phaedrux has marked this topic as solved
