    Strange Behavior , after "Pause" 'Cancel ""print again"
    Beta Firmware
    1.9k
    • moth4017undefined
      moth4017 @Phaedrux
      @phaedrux system_21_04-22.txt macros_21_-4_22.txt
        Thanks, I'll have a look tomorrow.
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @Phaedrux
          @phaedrux
          Cheers
          Mark
            Can you try copying your cancel.g to stop.g?
            • moth4017undefined
              moth4017 @Phaedrux
              @phaedrux
              Hi
              ; stop.g
              ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 11:07:38 GMT+1300 (New Zealand Daylight Time)
              ;cancel.g
              G28 X Y
              Copied cancel .g to stop.g
              Did "Pause" "M0" stop.g ran perfectly
              Did "Pause " "cancel" ran perfectly
              Did "Print again" after cancel
              Cancelled printing file 0:/gcodes/Body1_0.2mm_ABS__9h28m.gcode, print time was 0h 1m
              Error: Failed to home axes
              Error: Driver 0.4 error: over temperature shutdown
              Error: Driver 0.5 error: over temperature shutdown
              Warning: Driver 0.5 warning: over temperature warning
                I just noticed in your pack of files that cancel.g has a leading blank space character.
                2d257d8b-aba0-4070-8242-dd1f69d558cb-Screen Shot 2022-03-22 at 12.16.36 AM.png Screen Shot 2022-03-22 at 12.16.36 AM.png
                  Phaedrux Moderator @moth4017
                  @moth4017 said in Strange Behavior , after "Pause" 'Cancel ""print again":
                  Do you have a start.g file? If not, can you create one and add G28 to it?
                  That should make sure all axis are homed before the sliced gcode is executed.
                  I think the over temperature warnings on drivers 0.4 and 0.5 may be related to stall detection on the Z axis.
                  moth4017undefined 2 Replies Last reply Reply Quote 0
                  • moth4017undefined
                    moth4017
                    @phaedrux
                    Will do ill test now so you have results in the morning
                    • moth4017undefined
                      moth4017 @Phaedrux
                      @phaedrux
                      Interesting after removing the "space " from the "cancel.g" file the commands now work
                      also the over temperture errors seem to have stopped, will do more checks to confirm
                      • moth4017undefined
                        moth4017 @Phaedrux
                        @phaedrux
                        After testing , I can confirm all the above issues are caused by the space in front of the " Cancel.g" file , including the errors below.
                        Thanks for the help. im guessing you will want to trap this issue some how, help happy to help test if needed .
                        🅱 Cancelled printing file 0:/gcodes/Body1_0.35mm_PLA__17m.gcode, print time was 0h 0m
                        Error: Probe was not triggered during probing move
                        Error: Driver 0.6 error: over temperature shutdown
                          Well I think what's happening here is that with the cancel.g basically missing when the print is canceled it's getting sent M0
                          https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m0-stop-or-unconditional-stop
                          Then when trying to print again the machine is not in a ready state. When the motors are in stealthchop mode they require a short tuning move and I guess that's not happening, hence the errors.
                          It would be best to have a cancel.g and stop.g file present with the commands you wish to happen. Use M0 as your slicer end gcode, then have all your ending commands in stop.g.
                          You can also use a start.g file that has any preparation commands you want. Like homing the printer, pre-heating, etc.
                          That should give you more predictable behaviour.
                          • moth4017undefined
                            moth4017 @Phaedrux
                            @phaedrux
                            Thank you for the advice, please close thiis thread
                            • Phaedruxundefined Phaedrux has marked this topic as solved
