    Strange Behavior , after "Pause" 'Cancel ""print again"
    Beta Firmware
    1.9k
    • moth4017undefined
      moth4017 @Phaedrux
      @phaedrux
      No change
      Cancelled printing file 0:/gcodes/Body1_0.35mm_ABS__17m.gcode, print time was 0h 0m
      Error: Failed to home axes
      Error: Driver 0.4 error: over temperature shutdown
      Error: Driver 0.5 error: over temperature shutdown
      Warning: Driver 0.5 warning: over temperature warning
      Warning: Driver 0.4 warning: over temperature warning
        Are your drivers actually getting hot to the touch or are they spurious warnings? Printing is working correctly, right?
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @Phaedrux
          @phaedrux
          No they are not hot and i did a 8 hour print and they were ok , i only get that error after the "Pause, Cancel"
            I assume you're in stealthchop mode for the stall detection?
            • moth4017undefined
              moth4017 @Phaedrux
              @phaedrux
              M569 P0.4 S1 D3 V30 ; physical drive 4 goes forwards D3=stealthchop
              M569 P0.5 S0 D3 V30 ; physical drive 5 goes backwards
              M569 P0.6 S1 D3 V30 ; physical drive 6 goes forwards
                Can you zip up the entire sys and macros folders and share them with me, either upload them here but first change the file extension to .txt or use a file sharing cloud service. I'd like to get a complete look at what's going on with the actual files.
                • moth4017undefined
                  moth4017 @Phaedrux
                  @phaedrux system_21_04-22.txt macros_21_-4_22.txt
                    Thanks, I'll have a look tomorrow.
                    • moth4017undefined
                      moth4017 @Phaedrux
                      @phaedrux
                      Cheers
                      Mark
                        Can you try copying your cancel.g to stop.g?
                        • moth4017undefined
                          moth4017 @Phaedrux
                          @phaedrux
                          Hi
                          ; stop.g
                          ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
                          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Dec 30 2021 11:07:38 GMT+1300 (New Zealand Daylight Time)
                          ;cancel.g
                          G28 X Y
                          Copied cancel .g to stop.g
                          Did "Pause" "M0" stop.g ran perfectly
                          Did "Pause " "cancel" ran perfectly
                          Did "Print again" after cancel
                          Cancelled printing file 0:/gcodes/Body1_0.2mm_ABS__9h28m.gcode, print time was 0h 1m
                            I just noticed in your pack of files that cancel.g has a leading blank space character.
                            2d257d8b-aba0-4070-8242-dd1f69d558cb-Screen Shot 2022-03-22 at 12.16.36 AM.png Screen Shot 2022-03-22 at 12.16.36 AM.png
                              Phaedrux Moderator @moth4017
                              @moth4017 said in Strange Behavior , after "Pause" 'Cancel ""print again":
                              Do you have a start.g file? If not, can you create one and add G28 to it?
                              That should make sure all axis are homed before the sliced gcode is executed.
                              I think the over temperature warnings on drivers 0.4 and 0.5 may be related to stall detection on the Z axis.
                              moth4017undefined 2 Replies Last reply Reply Quote 0
                              • moth4017undefined
                                moth4017
                                @phaedrux
                                Will do ill test now so you have results in the morning
                                • moth4017undefined
                                  moth4017 @Phaedrux
                                  @phaedrux
                                  Interesting after removing the "space " from the "cancel.g" file the commands now work
                                  also the over temperture errors seem to have stopped, will do more checks to confirm
                                  • moth4017undefined
                                    moth4017 @Phaedrux
                                    @phaedrux
                                    After testing , I can confirm all the above issues are caused by the space in front of the " Cancel.g" file , including the errors below.
                                    Thanks for the help. im guessing you will want to trap this issue some how, help happy to help test if needed .
                                    🅱 Cancelled printing file 0:/gcodes/Body1_0.35mm_PLA__17m.gcode, print time was 0h 0m
                                    Error: Probe was not triggered during probing move
                                    Error: Driver 0.6 error: over temperature shutdown
                                      Well I think what's happening here is that with the cancel.g basically missing when the print is canceled it's getting sent M0
                                      https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m0-stop-or-unconditional-stop
                                      Then when trying to print again the machine is not in a ready state. When the motors are in stealthchop mode they require a short tuning move and I guess that's not happening, hence the errors.
                                      It would be best to have a cancel.g and stop.g file present with the commands you wish to happen. Use M0 as your slicer end gcode, then have all your ending commands in stop.g.
                                      You can also use a start.g file that has any preparation commands you want. Like homing the printer, pre-heating, etc.
                                      That should give you more predictable behaviour.
                                      • moth4017undefined
                                        moth4017 @Phaedrux
                                        @phaedrux
                                        Thank you for the advice, please close thiis thread
                                        • Phaedruxundefined Phaedrux has marked this topic as solved
