    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    24.0k
    • paolozampini1973undefined
      paolozampini1973 @droftarts
      @droftarts Listen to me when I say something and before I say something I think about it I don't talk to Ugh the problem now that I still have to solve the problem But you have to understand you are a hardware problem or a software problem as I said before for me it is a software problem and obviously before I had a small problem now I have big problems so what I ask you and please please please at least try to understand if it is a hardware problem or a software problem because otherwise I am forced to upgrade to version 0.8
      unless I could print with some pitch loss problem but at least I could print now I have practically the printer stopped
        paolozampini1973 @tekkydave
        @tekkydave Excuse me but if I do as you say or three motors that I cannot use then I still have a big problem So what is the advantage of having bought the 011 version because I have these problems that I have with the 011 I did not have them so explain to me you this solution that you recommend me maybe I don't understand Thanks very kind
        tekkydaveundefined 1 Reply Last reply Reply Quote 0
        • tekkydaveundefined
          tekkydave @paolozampini1973
          @paolozampini1973 @droftarts has already given the solution:
          Move the Z2 axis from output 9 on the Duex to either 0 or 2 on the Duet.
          Put the Duex in Duex2 mode.
          Make the changes to config.g that he will be giving to you.
          Once that is done lets see what remaining problems there are.
          ~ tekkydave ~
          D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
          FreeCAD, PrusaSlicer
          paolozampini1973undefined 1 Reply Last reply Reply Quote 1
            @tekkydave my printer configuration:
            Z is configured with two INDEPENDENT motors FOR SELF-LEVELING one on Driver 1 = Z one on the driver 9 = Z then X = DRIVER 7 EXSTERNAL DM860H Y = DRIVER 8 EXSTERNAL DM860H then I have 4 driver instructors 3 TMC2660 + driver 4 TMC2660 + driver 5 TMC2660 + driver 6 TMC2660
            PROBLEMS WITH DUEX5 V0.11 IN DUEX5 OFF DRIVE MODE 7 AXIS X + DRIVER 8 AXIS Y WHY I NEED TO USE IT
            are engaged or four independent extruders in total there are 8 motors Now I am sending you how I configured the printer and This is how it must be then the solution of You tell me how I can do it if I have 8 motors
              @paolozampini1973
              I'll do it by means of a table:
              Driver      Axis
              0           unused
              1           Z1
              2           Z2
              3           E1
              4           E2
              5           E3
              6           E4
              7           X (external)
              8           Y (external)
              9           unused (external)
              This is all 8 motors. The Duex is in Duex2 mode.
              ~ tekkydave ~
              paolozampini1973undefined 2 Replies Last reply Reply Quote 1
                @tekkydave DRIVER 5 + DRIVER 6 in DUEX mode 2 they do not work they are disabled understood This is a test that I have already done they do not work only 7 8 and 9 works I think you don't know this thing you've never tried But they don't work
                  @tekkydave I repeat then this is not a solution this is to turn the problem because as I repeat with the 0.8 these problems I did not have the 0.11 HAS problems Then honestly buying a version that should solve some problems but instead you create other problems this is not normal what I mean understood I Thanks for your kind attention Thank you but in this way you do not solve the problem it turns it creating even more problems
                    @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                    Correct - I haven't tried it. I only have a duex2 in my printer as I only have one extruder and 3 Z motors plus X & Y. I am simply repeating the information that others have already given days ago. Good luck solving your issues. Now I am convinced this thread is a Turing Test 🙂
                    ~ tekkydave ~
                      @tekkydave Please Unfortunately, this version has problems that in the design phase it can happen that one does not notice it But in fact I now take down the 0:11 you were Monterò from 08 However I do not recommend to buy the 011 Until proven otherwise it is that I now have 6 problems including 4 are very serious
                      paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                        paolozampini1973 @paolozampini1973
                        @dc42 my printer configuration:
                        1. HOW DO POWER SUPPLY X + Y GO WITHOUT ANY DATA COMMAND
                        2. HIGH TEMPERATURE M906 I TRIED TO PUT ALL AXES AT 0 MHA THE PROBLEM PERSISTS CONTINUOUSLY THE TEMPERATURE DRIVE TMC2660 AND 24 ° DEGREES
                        3. I ALWAYS HAVE THE SAME STEP LOSS PROBLEM AS DUEX 5 V0.8
                        4. THERMOCOUPLES REPORT 18 DEGREES LESS
                          5)and then I have the problem that in two ex 5 it gives Short Circuit error only in DUEX 5 mode
                          Vorrei lasciare V 011 ma la Y x si muove senza dargli il comando quindi è inutile parlare di altri problemi c'è da risolvere il primo Questo è il problema Va bene aspetterò quando ti libererai lo farò pubblica il file di configurazione grazie
                        21/3/2022, 15:38:13 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                        Errore: spegnimento per sovratemperatura segnalato dai conducenti 7 8
                        21/3/2022, 15:38:08 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                        21/3/2022, 15:38:04 Errore: cortocircuito verso terra segnalato dal conducente( s) 7 8
                        21/3/2022, 15:37:59 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                        Errore: spegnimento per sovratemperatura segnalato da driver(i) 7 8
                        21/3/2022, 15:37:55 Errore: cortocircuito verso terra segnalato dal conducente(i) 7 8
                        Errore: spegnimento per sovratemperatura segnalato dal conducente(i) 7 8
                        21/3/2022 , 15:37:50 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                        Errore: spegnimento per sovratemperatura segnalato dai driver 7 8
                        21/3/2022, 15:37:49 M122
                        === Diagnostica ===
                        RepRapFirmware per Duet 2 WiFi/Ethernet versione 3.3 (2021-06-15 21:44 :54) in esecuzione su Duet WiFi 1.02 o successivo +
                        ID scheda DueX5: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
                        Buffer di uscita utilizzati: 3 di 24 (20 max)
                        Ram statico: 23876
                        Ram dinamico : 77448 di cui 0 riciclato
                        Mai usato RAM 13092, stack di sistema libero 184 parole
                        Attività: NETWORK(ready,10.4%,231) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,319) DUEX(notifyWait,0.0 %,24) MAIN(in esecuzione,86.5%,411) IDLE(ready,3.0%,29), totale 100.0%
                        Mutex di proprietà:
                        === Piattaforma ===
                        Ultimo ripristino 00:00:25 fa, causa: software
                        Ultimo ripristino del software alle 15:37 del 21-03-2022, motivo: utente, rotazione di GCodes, RAM disponibile 13092, slot 1
                        Codice di ripristino del software 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/MAIN status Freestk:
                        Error 0x00
                        Errori Aux0 0,0,0
                        Intervallo max timer passo 0
                        Temperatura MCU: min 29.3, corrente 30.0, max 30.3
                        Tensione di alimentazione: min 25.6, corrente 25.7, max 25.8, eventi di sottotensione: 0, eventi di sovratensione: 0, alimentazione buona : si
                        Heap OK, gestisce allocata/usata 0/0, memoria heap allocata/usata/riciclabile 0/0/0, cicli gc 0
                        Driver 0: posizione 0, fermo, SG min/max non disponibile
                        Driver 1: posizione 0, fermo , SG min/max non disponibile
                        Pilota 2: posizione 0, fermo, SG min/max non disponibile
                        Pilota 3: posizione 0, fermo, SG min/max non disponibile
                        Pilota 4: posizione 0, fermo, SG min/max non disponibile
                        Pilota 5: posizione 0, fermo, SG min/max non disponibile
                        Driver 6: posizione 0, fermo, SG min/max non disponibile
                        Driver 7: posizione 0, spegnimento temperatura! corto a terra, fermo, SG min/max non disponibile
                        Driver 8: posizione 0, spegnimento della temperatura! da corto a terra, fermo, SG min/max non disponibile
                        Pilota 9: posizione 0, fermo, SG min/max non disponibile
                        Pilota 10: posizione 0
                        Pilota 11: posizione 0
                        Data/ora: 21-03-2022 15:37 :49
                        Conteggio hit dati cache 981081507
                        Ciclo più lento: 6,48 ms; più veloce: 0,19 ms Errori
                        I2C nak 0, timeout di invio 0, timeout di ricezione 0, finishTimeouts 0, reset 0
                        === Archiviazione ===
                        Voci file libere: 10
                        SD card 0 rilevate, velocità interfaccia: 20,0 MBytes/sec
                        SD card letta più lunga tempo 1,0 ms, tempo di scrittura 0,0 ms, numero massimo di tentativi 0
                        === Sposta ===
                        DM creati 83, maxWait 0 ms, compensazione letto in uso: nessuno, offset comp 0,000
                        === MainDDARing === Movimenti
                        pianificati 0, movimenti completati 0 , singhiozzo 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], stato CDDA -1
                        === AuxDDARing === Mosse
                        pianificate 0, mosse completate 0, singhiozzo 0, stepErrors 0, LaErrors 0, Underruns [0 , 0, 0], stato CDDA -1
                        === Calore ===
                        Riscaldatori letto = 0 -1 -1 -1, riscaldatori a camera = -1 -1 -1 -1
                        Riscaldatore 1 acceso, I-accum = 0.0
                        Segmenti rimasti: 0
                        Blocco movimento mantenuto da null
                        HTTP è inattivo in stato(i) 0
                        Telnet è inattivo in stato(i) 0
                        Il file è inattivo in stato(i) 0
                        USB è inattivo in stato(i) 0
                        Aux è inattivo in stato(i) 0
                        Trigger è inattivo in stato(i) 0
                        La coda è inattiva nello stato(i) 0 Il
                        display LCD è inattivo nello stato(i) 0
                        Daemon è inattivo nello stato(i) 0
                        La pausa automatica è inattiva nello stato(i) 0 La
                        coda del codice è vuota.
                        === Sensori filamento ===
                        Sensore estrusore 0: nessun filamento
                        Sensore estrusore 1: ok
                        Sensore estrusore 2: nessun filamento
                        Sensore estrusore 3: ok
                        === DueX ===
                        Conteggio letture 1, 2,36 letture/min
                        === Rete ===
                        Ciclo più lento: 39,88 ms; più veloce: 0,00 ms
                        Stati del risponditore: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessioni Sessioni
                        HTTP: 1 di 8
                        WiFi -
                        Lo stato della rete è attivo
                        Il modulo WiFi è connesso al punto di accesso
                        Messaggi di errore: in sospeso 0, non pronto 0, noresp 0
                        Versione firmware WiFi 1.26
                        Indirizzo MAC WiFi 40:f5:20:0d:6b:49
                        WiFi Vcc 3.37, motivo ripristino Attivato per processore principale
                        Dimensioni flash Wi-Fi 4194304, heap libero 20888
                        Indirizzo IP Wi-Fi 192.168.1.5
                        Potenza segnale Wi-Fi -64dBm, modalità 802.11n, riconnessioni 0, modalità sospensione modem
                        Registro orologio 00002002
                        Stati socket: 0 4 0 0 0 0 0 0
                        21/3 /2022, 15:37:46 Errore: cortocircuito verso terra segnalato dai conducenti 7 8
                        21/3/2022, 15:37:41 Errore: cortocircuito -a terra segnalato dal/dai conducente/i 7 8
                        21/3/2022, 15:37:39 Connesso a 192.168.1.5config (18).g
                          @dc42 I would like to know why you cannot pay attention to my problem it is a curiosity Thanks At least after one I will disturb more I have written to you many times
                            @dc42 she lets me think about this by not answering I have a problem that technically in my experience is very serious in my opinion and she is aware of it
                              @dc42 I want to thank you for all the attention you gave me even if you didn't even spend 10 seconds on more important things.
                                @droftarts please when you have some time we can clarify there is a software problem or a hardware problem At least this otherwise I want to return it honestly it only created problems for you too I tried to contact @ dc42 several times but I have not received no reply I don't know why thank you you are very kind
                                  @engikeneer I WANTED TO THANK YOU FOR THE DEDICATED TIME
                                  paolozampini1973undefined 1 Reply Last reply Reply Quote -1
                                    @dc42 so it is the confirmation that you are not interested in the problems of version 0.11 because you have not paid attention you have serious problems that v 0.11 has good
                                      Hello everyone So I'll explain the problem of the card The problem is that the card is that the drivers are not correctly disconnected This is why it gives the error and whoever designed it does not seem to care about the very serious design problem v0 11 would be to remove it from the market from the sale it goes complements magazine and from how I have seen no one has been able to give an answer because it gives short circuit errors But I must admit that giving solutions to get around the problem are all good but the real solution I have not seen this great skill Today I take apart the card and throw it away because for me personally it has created serious problems and I see that whoever designed it is a big manager if he was a responsible person he would have questioned us he would have talked about it would have understood he would have made himself heard anyway I want to thank those people who gave you a less decent answer but those people who try to get around the problem don't work that way guys get around the problem doesn't work Go you have to solve the problem you have to understand where the problem is I'm used to it so for many maybe they do it as a pastime as a game.
                                        droftarts administrators @paolozampini1973
                                        @paolozampini1973 I have some time this afternoon to help you. However, I need you to answer my questions, test things as I ask you to, and please no long arguments and saying again and again "there's a problem!". If I can get the information I need, we can work out where the problem is. Okay?
                                          @droftarts yes yes Thank you for your time with me
                                            @droftarts So what I would like to ask you I want to reassemble the v 0.8 and solve the problems with the v0.8 version because I repeat the only problem that I had a small loss of step and that's it I didn't have any kind of problem except to make some very small optimizations the rest worked everything is fine for you if you start reassembling v0.8 ?
