    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    24.4k
    • paolozampini1973undefined
      paolozampini1973 @droftarts
      @droftarts Yes it's fine ok I was saying for you because I didn't want to take advantage of your time for me it's fine thanks
        droftarts administrators @droftarts
        @droftarts Questions:
        1. In DueX2 mode, you said that the external drivers (X and Y) move correctly (except for the original problem of skipping), but you cannot move the extruders on driver 5 and driver 6. Correct?
        2. In DueX2 mode, can you move the Z2 motor on driver 9? Is it connected to an external driver as well?
        3. Is there any reason you cannot connect Z2 motor to driver 0 or 1 on the Duet 2 WiFi board?
        4. Please post a good picture of how your DueX v0.11 board is set up.
        5. What is the exact specification of the thermistors that you have for your tools and bed? Make, model or link would be useful.
        Try to keep your answers short and accurate!
        paolozampini1973undefined 2 Replies Last reply Reply Quote 0
          @droftarts my printer configuration:
          Z is configured with two INDEPENDENT motors FOR SELF-LEVELING one on Driver 1 = Z one on the driver 9 = Z then X = DRIVER 7 EXSTERNAL DM860H Y = DRIVER 8 EXSTERNAL DM860H then I have 4 driver instructors 3 TMC2660 + driver 4 TMC2660 + driver 5 TMC2660 + driver 6 TMC2660
          PROBLEMS WITH DUEX5 V0.11 IN DUEX5 OFF DRIVE MODE 7 AXIS X + DRIVER 8 AXIS Y WHY I NEED TO USE IT
            @droftarts I have sent you my configuration I hope it is clear that I was able to explain if there is something that I have not been clear Please tell me thanks
              droftarts administrators @paolozampini1973
              @paolozampini1973 Please answer the questions. I can't help you if you don't answer the questions.
              paolozampini1973undefined 1 Reply Last reply Reply Quote 1
                @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                This is incorrect. Your config.g shows the first Z motor on driver 2.
                M584 X7 Y8 Z2:9 E3:4:5:6 S0
                  @droftarts
                  driver 2 = z1 driver 9 z2 axis must be separated for self-leveling
                  drive3 =E0 EXTRUDER drive 4=E1 EXTRUDER drive5 =E2 EXTRUDER drive 6=E4 EXTRUDER
                    Yes, but the second Z motor can be on ANY other driver. I want you to move it to driver 0 (X on Duet 2) or driver 1 (Y on Duet 2).
                    Then the bed can move with the DueX in DueX2 mode, because the on board drivers 7, 8 and 9 are disabled in DueX2 mode.
                    paolozampini1973undefined 3 Replies Last reply Reply Quote 1
                      @droftarts Excuse me for my question but I have 4 extruders I do not know if I have explained myself Forgive me if I do not understand be patient but I have 4 extruders
                        @droftarts Please be patient that I send you a photo of my printer that I built
                          This post is deleted!
                            @paolozampini1973 Yes, I understand the machine. You're just posting the same images again. PLEASE ANSWER THESE QUESTIONS!
                            3. Is there any reason you cannot connect Z2 motor to driver 0 (X) or 1 (Y) on the Duet 2 WiFi board?
                            If you don't understand the questions above, please say.
                              @droftarts
                              i can't move them because i have it busy driver 5 driver 6 are busy driver 4 is busy driver 3 is busy there are 4 extruders connected
                                @droftarts Sorry my dear I sent you the photos because I can't explain I have 4 instructors as you can see from the photos they are connected then I need two outputs for X and Y then I need two independent outputs for Zeta and this seems to me that we understand each other Have patience because the printer is a bit complex
                                self-leveling takes place via two switches As you can see from the photos Look carefully at the photos Maybe so I can explain myself better Forgive me for my poor English
                                  @paolozampini1973 Can you move the motor connected at the bottom of the image, to the top?
                                    @droftarts
                                    1. DRIVER 3 E0 extruders
                                      DRIVER 4 E1 extruders
                                      DRIVER 5 E2 extruders
                                      DRIVER 6 E3 extruders
                                      TOTAL 4 extruders
                                      these are four extruders these Drivers are already engaged Tell me if I have made myself clear please
                                    2. Z1 DRIVER 2 Z2 DRIVER 9 Here are the independent AXIS Z
                                      @droftarts YES THIS Z2 that is Z2 driver 9
                                        Yes. Can you move it as indicated?
                                        paolozampini1973undefined 2 Replies Last reply Reply Quote 1
                                          @droftarts Yes of course I can move it but once we have moved Z you are doing all this to switch to DUEX 2 correct me if I'm wrong ?
                                          Ok I moved Z2 But where do you tell me that's driver 1 = Y
                                            @droftarts I moved like you told me now what to do?
