    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    24.8k
    • paolozampini1973undefined
      paolozampini1973 @droftarts
      @droftarts Excuse me for my question but I have 4 extruders I do not know if I have explained myself Forgive me if I do not understand be patient but I have 4 extruders
        @droftarts Please be patient that I send you a photo of my printer that I built
          This post is deleted!
            droftarts administrators @paolozampini1973
            @paolozampini1973 Yes, I understand the machine. You're just posting the same images again. PLEASE ANSWER THESE QUESTIONS!
            1. In DueX2 mode, you said that the external drivers (X and Y) move correctly (except for the original problem of skipping), but you cannot move the extruders on driver 5 and driver 6. Correct?
            2. In DueX2 mode, can you move the Z2 motor on driver 9?
            3. Is there any reason you cannot connect Z2 motor to driver 0 (X) or 1 (Y) on the Duet 2 WiFi board?
            4. Please post a good picture of how your DueX v0.11 board is set up.
            5. What is the exact specification of the thermistors that you have for your tools and bed? Make, model or link would be useful.
            If you don't understand the questions above, please say.
            paolozampini1973undefined 3 Replies Last reply Reply Quote 1
              @droftarts
              i can't move them because i have it busy driver 5 driver 6 are busy driver 4 is busy driver 3 is busy there are 4 extruders connected
                @droftarts Sorry my dear I sent you the photos because I can't explain I have 4 instructors as you can see from the photos they are connected then I need two outputs for X and Y then I need two independent outputs for Zeta and this seems to me that we understand each other Have patience because the printer is a bit complex
                self-leveling takes place via two switches As you can see from the photos Look carefully at the photos Maybe so I can explain myself better Forgive me for my poor English
                  @paolozampini1973 Can you move the motor connected at the bottom of the image, to the top?
                  paolozampini1973undefined 1 Reply Last reply Reply Quote 1
                    @droftarts
                    1. DRIVER 3 E0 extruders
                      DRIVER 4 E1 extruders
                      DRIVER 5 E2 extruders
                      DRIVER 6 E3 extruders
                      TOTAL 4 extruders
                      these are four extruders these Drivers are already engaged Tell me if I have made myself clear please
                    2. Z1 DRIVER 2 Z2 DRIVER 9 Here are the independent AXIS Z
                      @droftarts YES THIS Z2 that is Z2 driver 9
                        @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                        Yes. Can you move it as indicated?
                        paolozampini1973undefined 2 Replies Last reply Reply Quote 1
                          @droftarts Yes of course I can move it but once we have moved Z you are doing all this to switch to DUEX 2 correct me if I'm wrong ?
                          Ok I moved Z2 But where do you tell me that's driver 1 = Y
                            @droftarts I moved like you told me now what to do?
                              @paolozampini1973 In config.g, change:
                              M569 P1 S1                                   ; Z2 (Y)    physical drive 1 goes forwards
                              M584 X7 Y8 Z2:1 E3:4:5:6 S0                  ; set drive mapping
                              Reset after this change, then test Z works correctly
                                @droftarts AXIS Z OK
                                M574 Z2 S1 P"!zstop+!duex.e6stop" I have to reconfigure it as I configure it because otherwise the switches don't work rightly?
                                droftartsundefined 2 Replies Last reply Reply Quote 0
                                  @paolozampini1973 duex.e6stop should still work in DueX2 mode, but if you want you can move it to the Duet 2. I suggest ystop.
                                    @droftarts Yes you're right No it's okay let it stay where it is
                                      @droftarts Ok Now what do you want me to do ?
                                        @paolozampini1973 Next, remove these 4 jumpers on DueX:
                                        1 for DueX2 mode:
                                        3 to disable on board stepper drivers:
                                          @droftarts Yes I have already done this
                                            Including the jumper on EN9?
                                            paolozampini1973undefined droftartsundefined 2 Replies Last reply Reply Quote 1
