    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
      droftarts administrators @paolozampini1973
      @paolozampini1973 Can you move the motor connected at the bottom of the image, to the top?
      paolozampini1973undefined 1 Reply Last reply Reply Quote 1
      • paolozampini1973undefined
        paolozampini1973 @droftarts
        @droftarts
        1. DRIVER 3 E0 extruders
          DRIVER 4 E1 extruders
          DRIVER 5 E2 extruders
          DRIVER 6 E3 extruders
          TOTAL 4 extruders
          these are four extruders these Drivers are already engaged Tell me if I have made myself clear please
        2. Z1 DRIVER 2 Z2 DRIVER 9 Here are the independent AXIS Z
          @droftarts YES THIS Z2 that is Z2 driver 9
            @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
            Yes. Can you move it as indicated?
            paolozampini1973undefined 2 Replies Last reply Reply Quote 1
              @droftarts Yes of course I can move it but once we have moved Z you are doing all this to switch to DUEX 2 correct me if I'm wrong ?
              Ok I moved Z2 But where do you tell me that's driver 1 = Y
                @droftarts I moved like you told me now what to do?
                  @paolozampini1973 In config.g, change:
                  M569 P1 S1                                   ; Z2 (Y)    physical drive 1 goes forwards
                  M584 X7 Y8 Z2:1 E3:4:5:6 S0                  ; set drive mapping
                  Reset after this change, then test Z works correctly
                    @droftarts AXIS Z OK
                    M574 Z2 S1 P"!zstop+!duex.e6stop" I have to reconfigure it as I configure it because otherwise the switches don't work rightly?
                    droftartsundefined 2 Replies Last reply Reply Quote 0
                      @paolozampini1973 duex.e6stop should still work in DueX2 mode, but if you want you can move it to the Duet 2. I suggest ystop.
                        @droftarts Yes you're right No it's okay let it stay where it is
                          @droftarts Ok Now what do you want me to do ?
                            @paolozampini1973 Next, remove these 4 jumpers on DueX:
                            1 for DueX2 mode:
                            3 to disable on board stepper drivers:
                              @droftarts Yes I have already done this
                                Including the jumper on EN9?
                                paolozampini1973undefined droftartsundefined 2 Replies Last reply Reply Quote 1
                                  @droftarts YES
                                    droftarts administrators @droftarts
                                    Reset Duet and DueX. Check that DueX is recognised as DueX2. Send M122 to check.
                                      @droftarts 22/3/2022, 15:31:27 M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX2
                                      Board ID: 0JD0M-9P6M2-NW4SN-6J1DD-3SJ6K-KAURK
                                      Used output buffers: 6 of 24 (20 max)
                                      Static ram: 23876
                                      Dynamic ram: 77448 of which 0 recycled
                                      Never used RAM 13092, free system stack 184 words
                                      Tasks: NETWORK(ready,10.5%,246) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,313) DUEX(notifyWait,0.0%,24) MAIN(running,86.4%,433) IDLE(ready,2.9%,29), total 100.0%
                                      Owned mutexes: WiFi(NETWORK)
                                      Last reset 00:00:25 ago, cause: power up
                                      Last software reset at 2022-03-22 15:15, reason: User, GCodes spinning, available RAM 13092, slot 1
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      Step timer max interval 0
                                      MCU temperature: min 25.3, current 29.0, max 29.1
                                      Supply voltage: min 25.6, current 25.7, max 25.8, under voltage events: 0, over voltage events: 0, power good: yes
                                      Driver 0: position 0, standstill, SG min/max not available
                                      Driver 1: position 0, standstill, SG min/max not available
                                      Driver 2: position 0, standstill, SG min/max not available
                                      Driver 3: position 0, standstill, SG min/max not available
                                      Driver 4: position 0, standstill, SG min/max not available
                                      Driver 5: position 0, standstill, SG min/max not available
                                      Driver 6: position 0, standstill, SG min/max not available
                                      Driver 7: position 0
                                      Driver 8: position 0
                                      Driver 9: position 0
                                      Driver 10: position 0
                                      Driver 11: position 0
                                      Date/time: 2022-03-22 15:31:26
                                      Cache data hit count 987899119
                                      Slowest loop: 6.44ms; fastest: 0.18ms
                                      === Storage ===
                                      Free file entries: 10
                                      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                                      === MainDDARing ===
                                      === AuxDDARing ===
                                      Heater 1 is on, I-accum = 0.0
                                      Segments left: 0
                                      Movement lock held by null
                                      HTTP is idle in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      LCD is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      Code queue is empty.
                                      === Filament sensors ===
                                      Extruder 0 sensor: no filament
                                      Extruder 1 sensor: ok
                                      Extruder 2 sensor: no filament
                                      Extruder 3 sensor: ok
                                      === DueX ===
                                      Read count 1, 2.32 reads/min
                                      === Network ===
                                      Slowest loop: 39.64ms; fastest: 0.00ms
                                      HTTP sessions: 1 of 8
                                      • WiFi -
                                        Network state is active
                                        WiFi firmware version 1.26
                                        WiFi MAC address 40:f5:20:0d:6b:49
                                        WiFi Vcc 3.37, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 23400
                                        WiFi IP address 192.168.1.4
                                        WiFi signal strength -63dBm, mode 802.11n, reconnections 0, sleep mode modem
                                        Clock register 00002002
                                        22/3/2022, 15:31:20 Connected to 192.168.1.4
                                        @paolozampini1973 Great. Test if the extruder drives on driver 5 and 6 work. These are tool 2 and tool 3. Send M302 P1 to allow cold extrusion.
                                          @droftarts Yes ok but the temperature has already been set to zero degrees
                                            @paolozampini1973 I just want to know if the motors work. Heat up the tool and remove filament if you need to.
                                            paolozampini1973undefined 1 Reply Last reply Reply Quote 0
