    CoreIDX- Conversion of a CoreXY Printer into an IDEX
    3.7k
    • Strider007undefined
      Strider007
      Re: Corexyuv vs corexy idex
      This is a short discussion of a novel design conversion done to a CoreXY system, turning it into an IDEX or independent extruder system. The only additional mass added to the Y gantry is the weight of the new U carriage. Almost all of the original CoreXY components remain the same or very similar. This approach infers a lower complexity and mass on the gantry than all the IDEX systems available today. A Duet style mother board is required.
      I have always loved the design of a CoreXY machine for its scalability, precision, and speed. It is a truly great design but it only supports a single X carriage or single extruder. If the desire arises for dual extrusion, the conversion ideas that I have researched have been very complicated design modifications. They consist of tool changer systems, or a new motor on the Y gantry (added mass), or a complete duplicate set of belts, pulleys and motors. I have used dual extruders on a single carriage before and the results were not predictable and often too sloppy with smearing. I need independent extruders (IDEX) for the work I do. I spent most of my “Covid pandemic time” perfecting what I think is a reasonable path for conversion of most CoreXY machines into what I will call CoreIDX, or a modified CoreXY machine that becomes an IDEX system.
      Figure 1: CAD version of a CoreIDX gantry system
      My original design criterion was to create a very good CoreXY machine on a fairly large frame (~350x350x500mm print area); but this was really a fall back position if my IDEX idea didn’t work. I did not want to be wasteful so I reused as much of the original CoreXY components as possible. This concept reutilizes almost all of the original hardware by keeping the Core XY belts, pulleys and motor placements without additional motor weight to the Y gantry, only the U carriage weight is added. Figure 1 represents what I created based on a basic HEVO frame kit and design ideas found on Thingiverse.
      X and U Drive
      Figure 2 shows the pulleys, belts, and motors are the exact same as a CoreXY design. This conversion of a standard Core XY into a modified Cartesian IDEX is done by splitting the single X carriage into two carriages, X and U. These are now X&U belts and X&U motors .
      Figure 2: One belt attaches and the other passes through on the X and U carriages
      Each of them now attached to only one of the two pre-existing Core XY belts allowing the other belt to freely pass through it as shown in the circled area of Figure 2.
      Figure 3: Bottom view X & U carriages showing belt attachment and pass-through areas
      Figure 3 shows how the separation of the belts between the two new carriages was accomplished allowing a belt to attach to one carriage while passing through the other one.
      This design maintains the rigidity and alignment of the Y gantry in a similar manner as the CoreXY design since belts, pulleys tensions remain the same but they no longer drive the gantry in a Y direction. Each carriage is free of the other and driven by the original X and Y motors now repurposed as X and U drive motors driving either carriage in the X directions only.
      Fig 4: Y motor, shaft, and belts all mounted horizontally on top
      Y Drive
      The Y gantry is no longer driven or controlled by either of the two original motors. One additional motor is now required to drive the Y gantry back and forth. It is accomplished by adding the new Y motor to the back of the frame as shown in Figure 4. It drives a shaft with drive pulleys that push/pulls the Y gantry fore and aft just like many typical Cartesian printer designs. Adjustable belts pulleys are added to front of the machine to provide adjustment for the Y belt loops. This means the only added weight to the Y gantry is the weight of the additional U carriage and the attachment points for the belts and no additional motor mass since all positional drive motors are frame mounted.
      Kinematics
      This design maintains CoreXY belt tensions but does require modified kinematics not available to Marlin based HW/FW. The new X and U drives accurately move the two carriages in the +/- directions in a normal Cartesian manner but not the Y drive. If the Y gantry moves it will affect both X & U carriage positions. If the new Y gantry is moved, the X & U carriages either move diagonally together or apart. This means any Y movement of the gantry has to be countered by an equal movement of both the X & U motors (in opposite directions) in order to maintain their current position. This design requires hardware/firmware combination that allows for easily modified kinematics. Marlin and that class of hardware/firmware as far as I know can not accomplish this task. I do not have the programming skills to tackle C++ and/or Python therefore my logical choice was to move to a Duet style motherboard which runs RepRap firmware and capable of what I needed. With this motherboard the kinematics g-code command used is:
      M669 X1:0:0:0 Y-1:1:0:1 Z0:0:1:0 U0:0:0:1.
      CoreIDX Summary
      The CoreIDX machine has performs flawlessly and there are no plans to revert back to CoreXY. I have successfully used it for over a year commercially with amazing results. Besides great two color printing it has been utilized in duplicate and mirror mode operation too.
      Strider007undefined 1 Reply Last reply Reply Quote 3
        Strider007 @Strider007
        @strider007 said in CoreIDX- Conversion of a CoreXY Printer into an IDEX:
        Sorry, I incorrectly stated under "X and U Drive,..., FIg 2", that should refer back to Fig 1.
        • oliofundefined
          oliof @Strider007
          @strider007 cool design! I like it. Are you going to build it?
          Is the Y drive dual stepper, or dual shaft single stepper?
          Strider007undefined 1 Reply Last reply Reply Quote 0
            Strider007
            Oliof, the machine has been build and fully operational for about 18 months although several of the components have been redesigned several times. I'm not sure about your question on steppers. There are two carriages (X & U) each with a single hotend. They are located on the Y gantry. The extruders which drive the filaments can be located on the carriages (like BMG) or located on the frame in a bowden arrangement. Let me know if I answered your question or not.
              Strider007 @oliof
              @oliof the Y drive happens to be a dual shaft single stepper that is a bit larger than my U 8 X motors. It was something I had in my spares.
              • oliofundefined
                oliof
                thanks, all my questions have been answered. I'd be super interested in seeing photos of the machine (-:
                • sonderzugundefined
                  sonderzug
                  as far as I can see, this is a very slight variation of the "HaqXY" or "double markforged" kinematics, characterized by a separate motor for Y and a stationary stepper for X and U each. This has been discussed at length here: https://forum.duet3d.com/topic/7796/haq-xy/122
                  I've actually built a machine like this myself, which is still in the stage of being commissioned, but the geometry and kinematics work.
                  The only difference in your design, as far as I can see, is the routing of the X/U belts more in the "CoreXY way", meaning in the back of the gantry instead of back and forth on the y carriage, like I did and is described in the post mentioned above. I can't tell if this might be advantageous to cancel any racking forces that might exist; although because of the symmetry of the X and U belts, this seems academic.
                  I'm not sure if I personally would call it "core anything" but that is just down to taste.
                  best, Niklas
                    Strider007 @sonderzug
                    @sonderzug, I appreciate your input as I have not been following the latest IDEX designs concepts since about January of 2020, but I had seen a post back in 2019 that had a standard CoreXY design with Markforge carriage and pulleys added to it, and that was part of my inspiration. I believe, ( I'm not a mechanical engineer, just electrical) that the CoreXY style belt routing provides less raking of the Y gantry. Note that I also designed and build a Gli3DR style to see if it would work but I could not get the precision of the CoreXY especially if you are working with a large frame (520 x 510 mm interior) so I settled on this design. I am not surprised that others have found similar ways to implement independent extruders, but since my machine has been operational for 2 years now, I finally decided to basically publish the design and implementation of what I came up with. Better late than never. Here is a photo of the system after it completed a 2 color print
                    • Strider007undefined Strider007 referenced this topic
