    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.7k
      droftarts administrators
      @paolozampini1973 Do you mean that the external driver is turning off the power to the motor when it is stationary, even during printing?
      In the pdf you linked, it says:
      T1: ENA (enable signal) should be determined to be high by a DIR of at least 5μs.
      In general, it is recommended that ENA+ and ENA- be left floating.
      ie they recommend leaving ENA+ and ENA- unconnected. But if the driver is switching off power during printing, you need to connect them. Usually ENA+ to 5V, ENA- to ground. This will cause the motor to be powered all the time the Duet is on, though.
      But... are these the motors you are using on X and Y??? 17HS19-2004S1.pdf
      Because according to that pdf, they are 2.0A motors. The Duet 2 or DueX can control these directly! Why use the external drivers? Or are you going to fit bigger motors in the future?
      paolozampini1973undefined 2 Replies Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @droftarts
        @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
        Yes maybe one day you will intend to get bigger maybe but the problem is that colleague you direct I remember that the speed was very lowHowever at the moment I am doing some tests from what I understood in the explanation above M 201 the higher the better the lm566 I leave it at 1000 I have 900 which I think I understand that it is more than enough
          @droftarts however from the photos The structure is very rigid and also very heavy. I do not know if you have observed it carefully what idea did you get?
            droftarts administrators @paolozampini1973
            @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
            Yes, I had a look. A rigid and heavy frame is good, but in other areas I think you are going to have difficulties.
            Four nozzles on one carriage:
            • unless there is some lifting device for the nozzles not in use, you have 4x the opportunity for a nozzle to hit the print. A tool changing system doesn't have this issue.
            • controlling oozing from four nozzles is, likewise, difficult. Better to park the unused nozzles, eg like a tool changer.
            • The carriage is heavy. Jerk and acceleration will be limited.
            Ballscrews (I think?) for linear motion:
            • These are going to limit your top speed. At some point, the long unsupported span means that the ballscrew will wobble.
            • The other limit is how fast the stepper motor can turn, ie number of steps per mm. You have them set to 200 steps per mm, which actually isn't too bad compared to belt systems.
            Moving bed (Y axis)
            • For large machines, it's a large bed. That's a lot of mass to move around. The weight will limit jerk and acceleration.
            • With a moving bed, you move the print around a lot too. If you print large objects, this adds even more weight to the bed.
            • I always worry when mains electricity wires are connected to an axis the moves a lot. Please be careful!
            I think your machine will be slow (because of the weight of each axis), but accurate. If you can overcome the problems of the nozzles hitting the print, and oozing, and if it works for you, then great!
            There is a reason large machines with multiple extruders are built as CoreXY (or Cartesian XY gantry) and bed that moves in Z, or doesn't move at all. Machines like Voron, RatRig, SecKit, E3D toolchanger, Jubilee and others (sorry to all those I forgot). It keeps the working axis light, for speed, and unused tools out of the way.
            paolozampini1973undefined 1 Reply Last reply Reply Quote 0
              @droftarts However, the singer I must tell you that she is very precise Consider that I printed a 30 mm circle and an error of about 1 or 2 cents Measured by a micrometer clearly and repetitive I seem to have solved the bulk of course there is to be optimized but with all the cables in that state it is unthinkable that then we can make perfect calibrations In fact I will still have to fix the cables and in any case I will have to put a shielded cable for signals to the external drivers even the vertical line is almost imperceptible However, then I will keep you updated And another thing the top is perfectly flat which is not an easy thing I'll give you an example a print of 35 cm I repeat 30 cm there is a difference in height from 0.02 to 0.05 Maximumconfig (24).g
                paolozampini1973 @paolozampini1973
                @droftarts A TIP I WANT TO CHANGE NEMA 17 17HS19-2004S1 TO NEMA 23 23HS22-2804S BECAUSE WITH THE WEIGHT TO MOVE, HAVING DOUBLE TORQUE, I COULD INCREASE PERFORMANCE
                17HS19-2004S1.pdf
                23HS22-2804S.pdf
                  @droftarts
                  I have a problem with the Z axis manual override works fine driver 0 direction + and - driver 2 direction + and -
                  but when I give the command home all or home z it works only driver 0 direction + driver 2 direction + and - and drive 0 not returning in direction z- that towards z- there are the two switches of driver 0 and driver 2 which are used for self-leveling problem I don't understand that it has always worked until yesterday and today it doesn't work. I have not made any changesconfig (26).g homez.g homeall.g
                  I forgot to say that if I follow the command return home X the Z axis moves direction + driver 0 and driver 2 waits for x to return home and then moves driver 0 and driver 2 - and normal operation occurs the same way too y regularly performs the same function
                    @droftarts Hello I haven't been able to do the print tests yet because I have the problem with Z
                    please can you help me i can't understand the problem i have Z It's since yesterday i can't find the problem
                      @paolozampini1973 I have been testing this, and I think one of your endstops is not working. Either broken wiring, connected in the wrong place, or incorrect configuration.
                      When you send M119 with no endstop triggered, it should report "Z: not stopped". When you press either, or both, of the endstops, it should report "Z: at min stop". If one of the endstops does not report a change, check the wiring.
                      I have also tested endstop inputs on a DueX5 v0.11 in DueX2 mode, and all endstop inputs on the DueX worked correctly.
                      This is your current configuration:
                      M574 X0 S1 P"!xstop"                                ; configure active-high endstop for low end on X via pin xstop
                      M574 Y1 S1 P"!ystop"                                ; configure active-high endstop for low end on Y via pin ystop
                      M574 Z2 S1 P"!zstop+!E1stop"
                      'X0' means 'no endstop'. If it is at the low end (ie when triggered, X is at 0), change to X1.
                      'Z2' means 'at the high end', ie when Z is at 320. But I think your machine homes Z when the nozzle is close to the bed, which is the 'low end'. Change to Z1.
                      See https://docs.duet3d.com/User_manual/Reference/Gcodes/M574
                      paolozampini1973undefined 3 Replies Last reply Reply Quote 0
                        @droftarts No I think I have not explained myself iswitch have absolutely nothing to do with it I try to explain myself anyway Thanks thanks you made me feel it is not a hardware problem I will also explain to you why Z moves towards the more regularly when I go home with y and then comes back towards the less than 15 mm and this is regular if I do it with X it goes 15 mm towards the plus and then returns towards the less than 15 mm and this is also regular but if I do it with Z it goes home they rise towards the plus 15 mm and then only one axis returns 15 mm the basket what comes home with everything Iasi but it has absolutely nothing to do switch no Switch it is a configuration problem that I am seeing somewhere it is wrong with this I'm sure to 1000 * 1000 I hope I have been able to explain to me why the switch is not getting there but I have a configuration problem Suicide tested and work well Everyone changes Status no problem with Switches
                          @droftarts I can make a very short video but I don't know if I can publish it here
                          I have probably changed a parameter that I cannot understand which parameter I have changed the problem I have it only with Z it comes home and with it returns home all the axes coach X returns home I have no problems Z gets up and yes lowers both axes at the same time and is correct with Y the same thing goes up by 15 mm and low series regularly with both axes of Z and works regularly I hope I explained Thanks
                          SIamundefined 1 Reply Last reply Reply Quote 0
                          • SIamundefined
                            SIam @paolozampini1973
                            @paolozampini1973 I would say post a video, sometimes it is an easier way to solve problems
                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                            Duet WiFi 1.02 or later + DueX5
                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                            Duet WiFi Server: 1.26
                            Duet Web Control 3.4.0beta4 (2021-09-27)
                              @droftarts i reversed the problem before it was configured like this M584 X0 Y1 Z2: 1 E3: 4: 5: 6 Now I configured it this other way M584 X0 Y1 Z1: 2 E3: 4: 5: 6 the result that before I had the problem on the left Now I have what you say on the right now I understand But why why has it always worked like this for months and now I have the problem I do not understand and above all it has also worked so the day before yesterday after we made all the changes
                              M574 Z1 S1 P"!zstop+e1stop"
                              please help me because it doesn't make sense. It always worked because now it doesn't work anymore. The thing is too weird
                              SIamundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              • SIamundefined
                                @paolozampini1973 Did you use two different motors for the z axis ?
                                M569 P1 S0 R1                                      ; Y    physical drive 1 goes forwards
                                M569 P2 S1                                         ; Z    physical drive 2 goes forwards
                                If you use the same motors with the same wiring, I would say you need to configure both motors the same way
                                  paolozampini1973 @SIam
                                  @siam Listen Thanks for the intervention but the machine has been running like this for months
                                  How do I cut a video ? you tell me the size is too big
                                    @paolozampini1973 The order you define the axes in M584 and endstops in M574, configures the endstop for the axis. We moved them around the other day, so it's possible they got swapped.
                                    With
                                    M584 X0 Y1 Z2:1 E3:4:5:6
                                    Z2 uses zstop, Z1 uses e1stop.
                                    The same is true of leadscrew position, M671; the first leadscrew is the first one defined in M584.
                                      Use youtube, post link. Can't upload videos to Duet3D forum.
                                        @droftarts
                                        M574 Z2 S1 P"!zstop" ?
                                        M574 Z1 S1 P"e1stop" ?
                                        but Forgive me Excuse me for what reason it always worked even after when we made the changes I did the print tests it worked after we also made the changes and now it doesn't work anymore it's a very strange thing You can help me understand Thanks
                                          @droftarts
                                          NO. Z parameter in M574 sets where the endstop is physically, on the axis. High or low. Both endstops are low, and combined together. Listing them separately is incorrect. You also seem to have lost the inversion on the e1stop. It should be:
                                          M574 Z1 S1 P"!zstop+!e1stop"
                                            @droftarts
                                            M574 Z1 S1 P"!e1stop"
                                            So this is how it works that it goes towards the plus and then returns towards the minus but the first switch intervenes you can see both AXES
