    Z-drives not moving, new Duet3
    2.2k
    • Heideundefined
      Heide @Heide
      New homeZ and homeAll
      When I use homeall, it works until it reaches the Z code
      HomeZ.g
      G91 ; relative mode
      G1 H2 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
      G90 ; back to absolute mode
      G1 X-5 Y-100 F2000 ; put the head wherever you want it to be when you home Z (omit this line if it doesn't matter)
      G91 ; relative mode
      G1 H1 Z-200 F100 ; move Z down until the switch triggers
      G92 Z0.3 ; tell the firmware that we are at Z=0.3mm
      Homeall.g
      G91 ; relative mode
      G1 H1 X-240 Y-240 F3000 ; coarse home X or Y
      G1 H1 X400 ; coarse home X
      G1 H1 Y400 ; coarse home Y
      G1 X4 Y4 F600 ; move away from the endstops
      G1 H1 X-100 ; fine home X
      G1 H1 Y-5 ; fine home Y
      G1 X0 Y0 F2000 ; put the head wherever you want it to be when you home Z (omit this line if it doesn't matter)
      G91 ; relative mode
      Voron CoreXY with Duet 3 + expansion + PanelDue 7i - 300 * 300 * 300 and Hemera Revo
        droftarts administrators @Heide
        @heide Sorry, my answer was incorrect. You don't need the Z parameter on M669. Just use:
        M669 K1 ; select CoreXY mode
        Edit:
        If I send it with the Z parameter, I get:
        M669 K1 Z3
        Error: Invalid kinematics matrix
        Send M669 on it's own to check the kinematics in use. Should show:
        M669
        Kinematics is CoreXY, no segmentation, matrix:
        1.00 1.00 0
        1.00 -1.00 0
        0 0 1.00
        Heideundefined 1 Reply Last reply Reply Quote 0
        • Heideundefined
          Heide @droftarts
          @droftarts Does not work (K1), now it is just making a rumbling sound.
          K1 Z3 thats also what the RRF for coreXY has. But not working
          • Heideundefined
            Heide @Heide
            25.3.2022 14.42.15 M669
            1.00 1.00 0
            1.00 -1.00 0
            0 0 1.00
            • Heideundefined
              Heide @Heide
              With Z3
              25.3.2022 14.43.33 M669
              Kinematics is CoreXY, no segmentation, modified matrix:
              1.00 1.00 0
              1.00 -1.00 0
              3.00 0 0
                @heide said in Z-drives not moving, new Duet3:
                With Z3
                1.00 1.00 0
                1.00 -1.00 0
                3.00 0 0
                You don't want the Z to move 3 times what X is moving, and not move with Z, which is what that shows. Use M669 K1, it's correct. If Z is rumbling, sound more like the motors are blocked from moving mechanically.
                Where did this come from? It's not what the configuration tool produces.
                • Heideundefined
                  Heide @droftarts
                  @droftarts After the build and lining the linear rails. I could move the gantry with my little finger. After I have assembled it with belts I can move it without any problems (there are resistance, but nothing out of the ordinary) . I am positive that there are no tight assembly.
                  But maybe the assemble of the wire on the motor is wrong??? I change it the other day for all the motors. But there not any problems with the X and Y.
                  • Heideundefined
                    Heide @Heide
                    I forgot about the K1 Z3. It is from the configuring of RRF for coreXY printer. I can not remember what the original code was from Config tool. But I will try with the tool again
                    • Heideundefined
                      Heide @Heide
                      But I would think that it's normal, when not homed
                      • Heideundefined
                        Heide @Heide
                        I have tried to move the gantry up and down (I'm not happy doing that, but I wanted to be sure that there are normal movement), and it feels as it should
                        • Heideundefined
                          Heide @Heide
                          If I use this command it gantry moved up, without any problem.
                          G91
                          G1 H2 Z300 F3000
                          droftartsundefined 2 Replies Last reply Reply Quote 0
                            @heide I've edited your first post to put your config and homing files in code tags, which makes it easier to read and find the relevant bits.
                            I think this is an endstop issue. Your Z homing is using two methods:
                            When you call 'homez.g', it uses an endstop switch, and it is configured to trigger at the MINIMUM Z, ie when the nozzle touches the bed, with M574 Z1 S1 P"io3.in". Is this correct? The homing move is G1 H1 Z-200 F100, so it's moving the bed up. Also, a quirk of homing is that it relies on the M208 settings; currently you have the Z maximum set to M208 Z300, so it's possible for the Z axis to move and not hit the endstop. This may also cause homing to fail.
                            When you call 'homeall.g', it's using the Z probe. homeall.g should work correctly, assuming the probe is configured correctly.
                            The comments in the config.g are slightly confusing. It talks about moving Z up and down. But this is based on a machine that moves the nozzle in Z, eg Prusa i3. For a CoreXY, think of it 'Z up' as 'increasing the distance between bed and nozzle' and vice versa for 'Z down'.
                            Edit: Sorry, I see in your later edit to homez.g and homeall.g that you are using just endstops, not probe.
                              @heide Can you describe where your Z endstop is? Is it the same as the Z probe? If so, you just want to use G30 for homing Z, not command a move.
                              • Heideundefined
                                Heide @droftarts
                                @droftarts the endstop is not assigned as the probe. It's placed near the bed.
                                I have tested it, and it works.
                                @droftarts said in Z-drives not moving, new Duet3:
                                M574 Z1 S1 P"io3.in" correct
                                Just to be clear the bed is not moving, the gantry is.
                                I will a just the Z to 400
                                  Ah, yes, forgot it was a Voron!
                                  I realise that now, looking at the assigned pins for Z endstop and probe. However, if you have a probe, and you can home with that, what is the function of the endstop? It would be better to have it at the top of the machine, furthest from the bed. That way, in the event of a loss of power, you can home Z to the top, and continue printing. Home at the bottom, and you're more likely to hit the print.
                                  Yes, just needs to be bigger than the value set by M208.
                                  • Heideundefined
                                    Heide @droftarts
                                    @droftarts I learn all the time, but that make sens somehow. But I my case it does not matter witch one I use. I does not move at all. It moves when I punch in this code
                                    G91
                                    G1 H2 Z300 F3000
                                      @heide Hmm. I think that as that works, it's got to be a configuration issue. Can you post your current config.g, homez.g and homeall.g, preferably in code tags </> on the editing bar. Also post response to M122 and M98 P"config.g"
                                      • Heideundefined
                                        Heide @droftarts
                                        @droftarts Here is it. I hope that I have done it correctly with the </>, have never used it, but I will gladly learn it.
                                        ; Configuration file for Duet 3 (firmware version 3.3)
                                        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Mar 22 2022 17:37:43 GMT+0100 (Centraleuropæisk normaltid)
                                        M575 P1 S1 B57600                                          ; enable support for PanelDue
                                        G90                                                        ; send absolute coordinates...
                                        M83                                                        ; ...but relative extruder moves
                                        M550 P"Heides Printer"                                     ; set printer name
                                        ; Wait a moment for the CAN expansion boards to start
                                        G4 S2
                                        M552 P192.168.0.110 S1                                     ; enable network and acquire dynamic address via DHCP
                                        M586 P0 S1                                                 ; enable HTTP
                                        M586 P1 S0                                                 ; disable FTP
                                        M586 P2 S0                                                 ; disable Telnet
                                        M569 P0.0 S1                                               ; physical drive 0.0 goes forwards, drive E
                                        M569 P1.0 S1                                               ; physical drive 1.0 goes forwards, drive A
                                        M569 P0.1 S1                                               ; physical drive 0.1 goes forwards, drive Z1
                                        M569 P1.1 S1                                               ; physical drive 1.1 goes forwards, drive B
                                        M569 P0.2 S0                                               ; physical drive 0.1 goes backwards, drive Z2
                                        M569 P0.3 S1                                               ; physical drive 0.1 goes forwards, drive Z3
                                        M569 P0.4 S0                                               ; physical drive 0.1 goes backwards, drive Z4
                                        M584 X1.0 Y1.1 Z0.1:0.2:0.3:0.4 E0.0                       ; set drive mapping
                                        M350 X16 Y16 Z16 I0                                        ; configure microstepping without interpolation
                                        M350 E16 I1                                                ; configure microstepping with interpolation
                                        M92 X53.333 Y53.333 Z53.333 E397.00                        ; set steps per mm
                                        M566 X720.00 Y720.00 Z150.00 E600.00                       ; set maximum instantaneous speed changes (mm/min)
                                        M203 X18000.00 Y18000.00 Z2400.00 E6000.00                 ; set maximum speeds (mm/min)
                                        M201 X2000.00 Y2000.00 Z250.00 E1800.00                    ; set accelerations (mm/s^2)
                                        M906 X900 Y900 Z900 E1000 I30                              ; set motor currents (mA) and motor idle factor in per cent
                                        M84 S30                                                    ; Set idle timeout
                                        M208 X0 Y0 Z0 S1                                           ; set axis minima
                                        M208 X300 Y300 Z300 S0                                     ; set axis maxima
                                        M574 X1 S1 P"!io1.in"                                      ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io0.in
                                        M574 Y1 S1 P"!io2.in"                                      ; configure switch-type (e.g. microswitch) endstop Y1 = low-end on Y via pin !io1.in
                                        M574 Z1 S1 P"io3.in"                                       ; configure switch-type (e.g. microswitch) endstop U1 = low-end, S1 = active-high (NC) on Z via pin io3.in
                                        M558 P5 A5 S0.01 B0 R0.2 C"^io4.in" H5 F1000:400 T4500 I0  ; set Z probe type to switch and the dive height + speeds
                                        M558 H30                                                   ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                        G31 P500 X0 Y0 Z2.5                                        ; set Z probe trigger value, offset and trigger height
                                        M557 X50:250 Y50:250 S20                                   ; define mesh grid
                                        ; Bed leveling
                                        M671 X-65:-65:365:365 Y-20:380:380:-20 S20                 ; Define Z belts location (Front_Left, Back_Left, Back_Right, Front_Right)
                                        M557 X25:275 Y25:275 S25                                   ; Define bed mesh grid (inductive probe, positions include the Z offset!)
                                        M308 S0 P"temp0" Y"thermistor" T100000 B3950               ; configure sensor 0 as thermistor on pin temp0
                                        M950 H0 C"out0" T0                                         ; create bed heater output on out0 and map it to sensor 0
                                        M307 H0 B1 S1.00                                           ; 100% PWM, bang-bang mode for the bed heater
                                        M140 H0                                                    ; map heated bed to heater 0
                                        M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
                                        M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8      ; configure sensor 1 as thermistor on pin temp1
                                        M950 H1 C"out1" T1                                         ; create nozzle heater output on out1 and map it to sensor 1
                                        M307 H1 B0 S1.00                                           ; disable bang-bang mode for heater and set PWM limit
                                        M143 H1 S300                                               ; set temperature limit for heater 1 to 300C
                                        M950 F0 C"out4" Q500                                       ; create fan 0 on pin out4 and set its frequency
                                        M106 P0 S0 H-1                                             ; set fan 0 value. Thermostatic control is turned off
                                        M950 F1 C"out5" Q500                                       ; create fan 1 on pin out5 and set its frequency
                                        M106 P1 S1 I0 H1 T50                                       ; set fan 1 value. Thermostatic control is turned on when temp reaches 50 °C
                                        M950 F2 C"out7" Q500                                       ; create fan 2 on pin out7 and set its frequency. Electronics bay fan, turn on gradually if MCU is over 45 °C or any TMC driver is over temp
                                        M106 P2 T45:65 F50 H-1                                     ; set fan 2 value. Thermostatic control is turned off
                                        M950 F3 C"out8" Q500                                       ; create fan 3 on pin out8 and set its frequency. Electronics bay fan, turn on gradually if MCU is over 45 °C or any TMC driver is over temp
                                        M106 P3 T45:65 F50 H-1                                     ; set fan 3 value. Thermostatic control is turned off
                                        M563 P0 D0 H1 F1                                           ; define tool 0
                                        G10 P0 X0 Y0 Z0                                            ; set tool 0 axis offsets
                                        G10 P0 R0 S0                                               ; set initial tool 0 active and standby temperatures to 0C
                                        T0
                                        ; homeall.g
                                        ; called to home all axes
                                        G91                     ; relative mode
                                        G91                     ; relative mode
                                        G1 H1 Z-400 F100        ; move Z down until the switch triggers
                                        ;G91                    ; relative positioning
                                        ;G1 Z5 F100             ; lift Z relative to current position
                                        ;G90                    ; absolute positioning
                                        ; homez.g
                                        ; called to home the Z axis
                                        G91              ; relative mode
                                        G91              ; relative mode
                                        ;G1 H2 Z5 F100        ; lift Z relative to current position
                                        25.3.2022 16.54.32	M122
                                        RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                                        Board ID: 08DJM-956BA-NA3TN-6J9FL-3S86R-9TB6T
                                        Used output buffers: 3 of 40 (13 max)
                                        Static ram: 151000
                                        Dynamic ram: 96452 of which 128 recycled
                                        Never used RAM 103092, free system stack 200 words
                                        Tasks: NETWORK(ready,26.4%,209) ETHERNET(notifyWait,0.0%,173) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.0%,92) MAIN(running,65.6%,925) IDLE(ready,0.0%,30), total 100.0%
                                        Owned mutexes:
                                        Last reset 00:31:53 ago, cause: software
                                        Last software reset at 2022-03-25 16:22, reason: User, GCodes spinning, available RAM 103052, slot 2
                                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                                        Error status: 0x00
                                        Aux0 errors 0,0,0
                                        Step timer max interval 132
                                        MCU temperature: min 45.0, current 45.6, max 45.9
                                        Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                        12V rail voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0
                                        Events: 0 queued, 0 completed
                                        Driver 0: standstill, SG min 0, mspos 8, reads 48246, writes 14 timeouts 0
                                        Driver 1: standstill, SG min 0, mspos 312, reads 48246, writes 14 timeouts 0
                                        Driver 2: standstill, SG min 0, mspos 728, reads 48246, writes 14 timeouts 0
                                        Driver 3: standstill, SG min 0, mspos 312, reads 48246, writes 14 timeouts 0
                                        Driver 4: standstill, SG min 0, mspos 728, reads 48246, writes 14 timeouts 0
                                        Driver 5: standstill, SG min 0, mspos 8, reads 48250, writes 11 timeouts 0
                                        Date/time: 2022-03-25 16:54:31
                                        Slowest loop: 17.39ms; fastest: 0.05ms
                                        === Storage ===
                                        Free file entries: 10
                                        SD card longest read time 3.2ms, write time 2.4ms, max retries 0
                                        DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                        === MainDDARing ===
                                        === AuxDDARing ===
                                        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                        Segments left: 0
                                        Movement lock held by null
                                        HTTP is idle in state(s) 0
                                        Telnet is idle in state(s) 0
                                        File is idle in state(s) 0
                                        USB is idle in state(s) 0
                                        Aux is idle in state(s) 0
                                        Trigger is idle in state(s) 0
                                        Queue is idle in state(s) 0
                                        LCD is idle in state(s) 0
                                        SBC is idle in state(s) 0
                                        Daemon is idle in state(s) 0
                                        Aux2 is idle in state(s) 0
                                        Code queue is empty
                                        === CAN ===
                                        Messages queued 17221, received 15313, lost 0, boc 0
                                        Longest wait 1ms for reply type 6042, peak Tx sync delay 372, free buffers 50 (min 49), ts 9568/9567/0
                                        Tx timeouts 0,0,0,0,0,0
                                        === Network ===
                                        Slowest loop: 63.78ms; fastest: 0.02ms
                                        HTTP sessions: 1 of 8
                                        - Ethernet -
                                        State: active
                                        Error counts: 0 0 0 0 0
                                        25.3.2022 16.56.11	M98 P"config.g"
                                        HTTP is enabled on port 80
                                        FTP is disabled
                                        TELNET is disabled
                                        Error: Bad command: **Put G/M Codes in here to run when Tool 0 is about to be activated**
                                        Error: G0/G1: insufficient axes homed
                                        droftartsundefined JoergS5undefined 4 Replies Last reply Reply Quote 0
                                          @heide It's the </> icon on the editing bar above, puts in these:
                                          code_text
                                          • JoergS5undefined
                                            JoergS5 @Heide
                                            there's a glitch in your homeall: X400 Y400 should be -400 and -400, please see example at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Homing_files
                                            After homing movement of X and Y together, X and Y shall be moved into the same direction (negative X and Y) again some distance. This shall ensure that both X and Y are homed. Then a litte backwards (which is positive value here) and slowly with - again to the endstops.
                                            Heideundefined 1 Reply Last reply Reply Quote 1
