Z-drives not moving, new Duet3
2.0k
    Heide @droftarts
    @droftarts Does not work (K1), now it is just making a rumbling sound.
    K1 Z3 thats also what the RRF for coreXY has. But not working
    Voron CoreXY with Duet 3 + expansion + PanelDue 7i - 300 * 300 * 300 and Hemera Revo
    undefined 1 Reply Last reply 25 Mar 2022, 13:42 Reply Quote 0
      Heide @Heide
      25.3.2022 14.42.15 M669
      Kinematics is CoreXY, no segmentation, matrix:
      1.00 1.00 0
      1.00 -1.00 0
      0 0 1.00
      undefined 1 Reply Last reply 25 Mar 2022, 13:43 Reply Quote 0
        Heide @Heide
        With Z3
        25.3.2022 14.43.33 M669
        Kinematics is CoreXY, no segmentation, modified matrix:
        1.00 1.00 0
        1.00 -1.00 0
        3.00 0 0
        undefined 1 Reply Last reply 25 Mar 2022, 13:49 Reply Quote 0
          droftarts administrators @Heide
          @heide said in Z-drives not moving, new Duet3:
          With Z3
          1.00 1.00 0
          1.00 -1.00 0
          3.00 0 0
          You don't want the Z to move 3 times what X is moving, and not move with Z, which is what that shows. Use M669 K1, it's correct. If Z is rumbling, sound more like the motors are blocked from moving mechanically.
          Where did this come from? It's not what the configuration tool produces.
          undefined 1 Reply Last reply 25 Mar 2022, 13:58 Reply Quote 0
            Heide @droftarts
            @droftarts After the build and lining the linear rails. I could move the gantry with my little finger. After I have assembled it with belts I can move it without any problems (there are resistance, but nothing out of the ordinary) . I am positive that there are no tight assembly.
            But maybe the assemble of the wire on the motor is wrong??? I change it the other day for all the motors. But there not any problems with the X and Y.
            undefined 1 Reply Last reply 25 Mar 2022, 14:00 Reply Quote 0
              Heide @Heide
              I forgot about the K1 Z3. It is from the configuring of RRF for coreXY printer. I can not remember what the original code was from Config tool. But I will try with the tool again
              undefined 1 Reply Last reply 25 Mar 2022, 14:07 Reply Quote 0
                Heide @Heide
                But I would think that it's normal, when not homed
                undefined 1 Reply Last reply 25 Mar 2022, 14:12 Reply Quote 0
                  Heide @Heide
                  I have tried to move the gantry up and down (I'm not happy doing that, but I wanted to be sure that there are normal movement), and it feels as it should
                  undefined 1 Reply Last reply 25 Mar 2022, 14:25 Reply Quote 0
                    Heide @Heide
                    If I use this command it gantry moved up, without any problem.
                    G91
                    G1 H2 Z300 F3000
                    undefined 2 Replies Last reply 25 Mar 2022, 15:21 Reply Quote 0
                      @heide I've edited your first post to put your config and homing files in code tags, which makes it easier to read and find the relevant bits.
                      I think this is an endstop issue. Your Z homing is using two methods:
                      When you call 'homez.g', it uses an endstop switch, and it is configured to trigger at the MINIMUM Z, ie when the nozzle touches the bed, with M574 Z1 S1 P"io3.in". Is this correct? The homing move is G1 H1 Z-200 F100, so it's moving the bed up. Also, a quirk of homing is that it relies on the M208 settings; currently you have the Z maximum set to M208 Z300, so it's possible for the Z axis to move and not hit the endstop. This may also cause homing to fail.
                      When you call 'homeall.g', it's using the Z probe. homeall.g should work correctly, assuming the probe is configured correctly.
                      The comments in the config.g are slightly confusing. It talks about moving Z up and down. But this is based on a machine that moves the nozzle in Z, eg Prusa i3. For a CoreXY, think of it 'Z up' as 'increasing the distance between bed and nozzle' and vice versa for 'Z down'.
                      Edit: Sorry, I see in your later edit to homez.g and homeall.g that you are using just endstops, not probe.
                        @heide Can you describe where your Z endstop is? Is it the same as the Z probe? If so, you just want to use G30 for homing Z, not command a move.
                        undefined 1 Reply Last reply 25 Mar 2022, 15:34 Reply Quote 0
                          Heide @droftarts
                          @droftarts the endstop is not assigned as the probe. It's placed near the bed.
                          I have tested it, and it works.
                          @droftarts said in Z-drives not moving, new Duet3:
                          M574 Z1 S1 P"io3.in" correct
                          Just to be clear the bed is not moving, the gantry is.
                          I will a just the Z to 400
                          undefined 1 Reply Last reply 25 Mar 2022, 15:39 Reply Quote 0
                            Ah, yes, forgot it was a Voron!
                            I realise that now, looking at the assigned pins for Z endstop and probe. However, if you have a probe, and you can home with that, what is the function of the endstop? It would be better to have it at the top of the machine, furthest from the bed. That way, in the event of a loss of power, you can home Z to the top, and continue printing. Home at the bottom, and you're more likely to hit the print.
                            Yes, just needs to be bigger than the value set by M208.
                            undefined 1 Reply Last reply 25 Mar 2022, 15:42 Reply Quote 0
                              Heide @droftarts
                              @droftarts I learn all the time, but that make sens somehow. But I my case it does not matter witch one I use. I does not move at all. It moves when I punch in this code
                              G91
                              G1 H2 Z300 F3000
                              undefined 1 Reply Last reply 25 Mar 2022, 15:49 Reply Quote 0
                                @heide Hmm. I think that as that works, it's got to be a configuration issue. Can you post your current config.g, homez.g and homeall.g, preferably in code tags </> on the editing bar. Also post response to M122 and M98 P"config.g"
                                undefined 1 Reply Last reply 25 Mar 2022, 15:57 Reply Quote 0
                                  Heide @droftarts
                                  @droftarts Here is it. I hope that I have done it correctly with the </>, have never used it, but I will gladly learn it.
                                  ; Configuration file for Duet 3 (firmware version 3.3)
                                  ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Mar 22 2022 17:37:43 GMT+0100 (Centraleuropæisk normaltid)
                                  M550 P"Heides Printer" ; set printer name
                                  M669 K1 ; select CoreXY mode
                                  ; Wait a moment for the CAN expansion boards to start
                                  G4 S2
                                  M552 P192.168.0.110 S1 ; enable network and acquire dynamic address via DHCP
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S0 ; disable FTP
                                  M586 P2 S0 ; disable Telnet
                                  M569 P0.0 S1 ; physical drive 0.0 goes forwards, drive E
                                  M569 P1.0 S1 ; physical drive 1.0 goes forwards, drive A
                                  M569 P0.1 S1 ; physical drive 0.1 goes forwards, drive Z1
                                  M569 P1.1 S1 ; physical drive 1.1 goes forwards, drive B
                                  M569 P0.2 S0 ; physical drive 0.1 goes backwards, drive Z2
                                  M569 P0.3 S1 ; physical drive 0.1 goes forwards, drive Z3
                                  M569 P0.4 S0 ; physical drive 0.1 goes backwards, drive Z4
                                  M584 X1.0 Y1.1 Z0.1:0.2:0.3:0.4 E0.0 ; set drive mapping
                                  M350 X16 Y16 Z16 I0 ; configure microstepping without interpolation
                                  M350 E16 I1 ; configure microstepping with interpolation
                                  M92 X53.333 Y53.333 Z53.333 E397.00 ; set steps per mm
                                  M566 X720.00 Y720.00 Z150.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X18000.00 Y18000.00 Z2400.00 E6000.00 ; set maximum speeds (mm/min)
                                  M201 X2000.00 Y2000.00 Z250.00 E1800.00 ; set accelerations (mm/s^2)
                                  M906 X900 Y900 Z900 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X300 Y300 Z300 S0 ; set axis maxima
                                  M574 X1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io0.in
                                  M574 Y1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop Y1 = low-end on Y via pin !io1.in
                                  M574 Z1 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop U1 = low-end, S1 = active-high (NC) on Z via pin io3.in
                                  M558 P5 A5 S0.01 B0 R0.2 C"^io4.in" H5 F1000:400 T4500 I0 ; set Z probe type to switch and the dive height + speeds
                                  M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                                  M557 X50:250 Y50:250 S20 ; define mesh grid
                                  ; Bed leveling
                                  M671 X-65:-65:365:365 Y-20:380:380:-20 S20 ; Define Z belts location (Front_Left, Back_Left, Back_Right, Front_Right)
                                  M557 X25:275 Y25:275 S25 ; Define bed mesh grid (inductive probe, positions include the Z offset!)
                                  M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                                  M307 H0 B1 S1.00 ; 100% PWM, bang-bang mode for the bed heater
                                  M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                                  M143 H1 S300 ; set temperature limit for heater 1 to 300C
                                  M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                                  M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                                  M106 P1 S1 I0 H1 T50 ; set fan 1 value. Thermostatic control is turned on when temp reaches 50 °C
                                  M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency. Electronics bay fan, turn on gradually if MCU is over 45 °C or any TMC driver is over temp
                                  M106 P2 T45:65 F50 H-1 ; set fan 2 value. Thermostatic control is turned off
                                  M950 F3 C"out8" Q500 ; create fan 3 on pin out8 and set its frequency. Electronics bay fan, turn on gradually if MCU is over 45 °C or any TMC driver is over temp
                                  M106 P3 T45:65 F50 H-1 ; set fan 3 value. Thermostatic control is turned off
                                  M563 P0 D0 H1 F1 ; define tool 0
                                  T0
                                  ; homeall.g
                                  ; called to home all axes
                                  G91 ; relative mode
                                  G1 H1 X-240 Y-240 F3000 ; coarse home X or Y
                                  G1 H1 X400 ; coarse home X
                                  G1 H1 Y400 ; coarse home Y
                                  G1 X4 Y4 F600 ; move away from the endstops
                                  G1 H1 X-100 ; fine home X
                                  G1 H1 Y-5 ; fine home Y
                                  G1 H2 Z4 F200 ; raise head 4mm to ensure it is above the switch trigger height
                                  G90 ; back to absolute mode
                                  G1 X0 Y0 F2000 ; put the head wherever you want it to be when you home Z (omit this line if it doesn't matter)
                                  G91 ; relative mode
                                  G1 H1 Z-400 F100 ; move Z down until the switch triggers
                                  G92 Z0.3 ; tell the firmware that we are at Z=0.3mm
                                  ;G91 ; relative positioning
                                  ;G90 ; absolute positioning
                                  ; homez.g
                                  ; called to home the Z axis
                                  G91 ; relative mode
                                  G1 X-5 Y-100 F2000 ; put the head wherever you want it to be when you home Z (omit this line if it doesn't matter)
                                  G91 ; relative mode
                                  ;G1 H2 Z5 F100 ; lift Z relative to current position
                                  25.3.2022 16.54.32 M122
                                  RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                                  Board ID: 08DJM-956BA-NA3TN-6J9FL-3S86R-9TB6T
                                  Used output buffers: 3 of 40 (13 max)
                                  Static ram: 151000
                                  Dynamic ram: 96452 of which 128 recycled
                                  Never used RAM 103092, free system stack 200 words
                                  Tasks: NETWORK(ready,26.4%,209) ETHERNET(notifyWait,0.0%,173) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,8.0%,92) MAIN(running,65.6%,925) IDLE(ready,0.0%,30), total 100.0%
                                  Owned mutexes:
                                  Last reset 00:31:53 ago, cause: software
                                  Last software reset at 2022-03-25 16:22, reason: User, GCodes spinning, available RAM 103052, slot 2
                                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  Step timer max interval 132
                                  MCU temperature: min 45.0, current 45.6, max 45.9
                                  Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                                  12V rail voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0
                                  Events: 0 queued, 0 completed
                                  Driver 0: standstill, SG min 0, mspos 8, reads 48246, writes 14 timeouts 0
                                  Driver 1: standstill, SG min 0, mspos 312, reads 48246, writes 14 timeouts 0
                                  Driver 2: standstill, SG min 0, mspos 728, reads 48246, writes 14 timeouts 0
                                  Driver 3: standstill, SG min 0, mspos 312, reads 48246, writes 14 timeouts 0
                                  Driver 4: standstill, SG min 0, mspos 728, reads 48246, writes 14 timeouts 0
                                  Driver 5: standstill, SG min 0, mspos 8, reads 48250, writes 11 timeouts 0
                                  Date/time: 2022-03-25 16:54:31
                                  Slowest loop: 17.39ms; fastest: 0.05ms
                                  === Storage ===
                                  Free file entries: 10
                                  SD card longest read time 3.2ms, write time 2.4ms, max retries 0
                                  DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                  Segments left: 0
                                  Movement lock held by null
                                  HTTP is idle in state(s) 0
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Trigger is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  SBC is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Aux2 is idle in state(s) 0
                                  Code queue is empty
                                  === CAN ===
                                  Messages queued 17221, received 15313, lost 0, boc 0
                                  Longest wait 1ms for reply type 6042, peak Tx sync delay 372, free buffers 50 (min 49), ts 9568/9567/0
                                  Tx timeouts 0,0,0,0,0,0
                                  === Network ===
                                  Slowest loop: 63.78ms; fastest: 0.02ms
                                  HTTP sessions: 1 of 8
                                  - Ethernet -
                                  State: active
                                  Error counts: 0 0 0 0 0
                                  25.3.2022 16.56.11 M98 P"config.g"
                                  HTTP is enabled on port 80
                                  FTP is disabled
                                  TELNET is disabled
                                  Error: Bad command: **Put G/M Codes in here to run when Tool 0 is about to be activated**
                                  Error: G0/G1: insufficient axes homed
                                  undefined undefined 4 Replies Last reply 25 Mar 2022, 16:10 Reply Quote 0
                                    @heide It's the </> icon on the editing bar above, puts in these:
                                    code_text
                                      JoergS5 @Heide
                                      there's a glitch in your homeall: X400 Y400 should be -400 and -400, please see example at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Homing_files
                                      After homing movement of X and Y together, X and Y shall be moved into the same direction (negative X and Y) again some distance. This shall ensure that both X and Y are homed. Then a litte backwards (which is positive value here) and slowly with - again to the endstops.
                                      undefined 1 Reply Last reply 25 Mar 2022, 21:13 Reply Quote 1
                                        Heide @JoergS5
                                        @joergs5 I will change this tomorrow. But I'm sure that I have already tried it. (I have tried so many things today)
                                        undefined 1 Reply Last reply 25 Mar 2022, 21:20 Reply Quote 0
                                          JoergS5 @Heide
                                          The risk is high that you mixed something up by trying different things.
                                          First thing to check is that G1 H1 X-100 and Y-100 move your hotend into the correct direction toward the endstops. Then please try my proposal.
                                          What I do if I am not sure about correct codes, I run them line by line directly in the DWC command line and check that in this case the first, second, third endstops are triggered as expected. There are a few G-Code commands which can be run only in a specific order (drive additions and their mappings), but most commands can be tested this way.
                                          undefined 1 Reply Last reply 25 Mar 2022, 21:31 Reply Quote 0
                                          15 out of 48
