    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    25.0k
      droftarts administrators @paolozampini1973
      @paolozampini1973 The order you define the axes in M584 and endstops in M574, configures the endstop for the axis. We moved them around the other day, so it's possible they got swapped.
      With
      M584 X0 Y1 Z2:1 E3:4:5:6
      M574 Z1 S1 P"!zstop+e1stop"
      Z2 uses zstop, Z1 uses e1stop.
      The same is true of leadscrew position, M671; the first leadscrew is the first one defined in M584.
        @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
        @siam Listen Thanks for the intervention but the machine has been running like this for months
        How do I cut a video ? you tell me the size is too big
        Use youtube, post link. Can't upload videos to Duet3D forum.
        paolozampini1973undefined 1 Reply Last reply Reply Quote 0
        • paolozampini1973undefined
          paolozampini1973 @droftarts
          @droftarts
          M574 Z2 S1 P"!zstop" ?
          M574 Z1 S1 P"e1stop" ?
          but Forgive me Excuse me for what reason it always worked even after when we made the changes I did the print tests it worked after we also made the changes and now it doesn't work anymore it's a very strange thing You can help me understand Thanks
            @droftarts
            NO. Z parameter in M574 sets where the endstop is physically, on the axis. High or low. Both endstops are low, and combined together. Listing them separately is incorrect. You also seem to have lost the inversion on the e1stop. It should be:
            M574 Z1 S1 P"!zstop+!e1stop"
            paolozampini1973undefined 2 Replies Last reply Reply Quote 0
              @droftarts
              M574 Z1 S1 P"!e1stop"
              So this is how it works that it goes towards the plus and then returns towards the minus but the first switch intervenes you can see both AXES
                @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                @droftarts
                NO. Z parameter in M574 sets where the endstop is physically, on the axis. High or low. They both should be Z1. Listing them separately is incorrect, too. You also seem to have lost the inversion on the e1stop. It should be:
                so it doesn't do the inversion it goes towards the plus and it doesn't come back towards the minus but the thing I don't understand why it doesn't work anymore has always worked even after we put our hands on it
                  @paolozampini1973 What does M119 report when:
                  No switch is pressed
                  Z1 endstop is pressed
                  Z2 endstop is pressed
                  Both endstops are pressed
                  And post the endstop configuration you are using when testing.
                    @droftarts So the problem is not the speech of switches that have to close and open because practically when you give it back home it goes up 15 mm and then it has to do the inversion towards minus putting the separated the inversion towards minus does it however I repeat not get to the switches I have now done a try to take it myself manually the switches work both tested they work it is not a problem of the switches it is a problem towards the plus and then return towards the minus towards the Switch clearly if only one axis works only l the axis is rightly placed sideways
                    droftartsundefined 2 Replies Last reply Reply Quote 0
                      @paolozampini1973 Please just do the test and report, using M574 Z1 S1 P"!zstop+!e1stop" for configuration. It won't work with two separate M574 commands.
                        25/3/2022, 17:34:11 M574 Z2 S1 P"!zstop!+!e1stop"
                        Error: M574: Unknown pin name 'zstop!'
                          @paolozampini1973 Also, the last homeall.g does not home z; it just sets Z=0 wherever Z is.
                          G1 S2 H2 Z15 F1500          ; lift Z relative to current position
                          G1 S1 H1 X-500 Y-500 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 S2 H2 X5 Y5 F1500       ; go back a few mm
                          G1 S1 H1 X-500 Y-500 F360  ; move slowly to X and Y axis endstops once more (second pass)
                          G1 S1 H1 Z-300 F360        ; move Z down stopping at the endstop
                          G90                     ; absolute positioning
                          G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                          homez.g does a move towards home, then sets Z=0 when the endstops are triggered.
                          G1 H2 Z15 F700    ; lift Z relative to current position
                          G1 H1 Z-300 F700 ; move Z down until the endstop is triggered
                          However, your M208 is M208 X500 Y500 Z320 S0, so Z axis is longer than the Z-300 move. In homez.g, change G1 H1 Z-300 F700 to G1 H1 Z-400 F700: it must be a bigger move than the axis length. Did you change M208 recently?
                            You have an extra ! in there.
                            AND CHANGE Z2 to Z1
                              @droftarts config (27).g
                              you correct the files please and I start as you send me
                                @paolozampini1973 Now you are missing the +
                                USE THIS!
                                Anyway, I have to go now. See my earlier post about change homez.g.
                                  No I haven't changed it recently this car was so configured for months this is what I was always doing Solving the problem of loss of pace and it seems that you can see that step has been resolved but I still have to try it well
                                    paolozampini1973 @paolozampini1973
                                    ; homeall.g
                                    ; called to home all axes
                                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed May 19 2021 14:46:37 GMT+0200 (Ora legale dell’Europa centrale)
                                    G92 Z=0 ; set Z position to axis minimum (you may want to adjust this)
                                    ;G91 ; relative positioning
                                    ;G90 ; absolute positioning
                                      i did as you told me i put Z = 0 this is the result
                                      SIamundefined 1 Reply Last reply Reply Quote 0
                                      • SIamundefined
                                        SIam @paolozampini1973
                                        @paolozampini1973 and what have you done ? home z or home all ? If it was home z then you have to home x/y first.
                                        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                        Duet WiFi 1.02 or later + DueX5
                                        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                        Duet WiFi Server: 1.26
                                        Duet Web Control 3.4.0beta4 (2021-09-27)
                                        • SIamundefined
                                          SIam @SIam
                                          @siam oh I have overseen you was trying to home the z axis first before you can do this home y/x ( g28 x / g28 y)
                                            @droftarts
                                            G92 Z0 good
                                            G92 Z=0 no good
                                            M574 Z1 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
                                            M574 Z2 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
                                            M569 P7 S0 R1 T14:14:26:26 ; E4 X physical drive 7 goes forwards
                                            M569 P8 S1 R1 T14:14:26:26 ; E5 Y physical drive 8 goes forwards
                                            with these messages it seems that he no longer loses steps tomorrow I change from nema 17 to nema 23
                                            tell me your thoughts thanks
                                            17HS19-2004S1.pdf 23HS22-2804S.pdf
                                            how can I return the courtesy that you have helped me ?
                                            droftartsundefined paolozampini1973undefined 2 Replies Last reply Reply Quote 0
