    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    24.1k
    • paolozampini1973undefined
      paolozampini1973 @droftarts
      @droftarts So the problem is not the speech of switches that have to close and open because practically when you give it back home it goes up 15 mm and then it has to do the inversion towards minus putting the separated the inversion towards minus does it however I repeat not get to the switches I have now done a try to take it myself manually the switches work both tested they work it is not a problem of the switches it is a problem towards the plus and then return towards the minus towards the Switch clearly if only one axis works only l the axis is rightly placed sideways
      droftartsundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @paolozampini1973
        @paolozampini1973 Please just do the test and report, using M574 Z1 S1 P"!zstop+!e1stop" for configuration. It won't work with two separate M574 commands.
        paolozampini1973undefined 1 Reply Last reply Reply Quote 0
          @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
          25/3/2022, 17:34:11 M574 Z2 S1 P"!zstop!+!e1stop"
          Error: M574: Unknown pin name 'zstop!'
            @paolozampini1973 Also, the last homeall.g does not home z; it just sets Z=0 wherever Z is.
            G1 S2 H2 Z15 F1500          ; lift Z relative to current position
            G1 S1 H1 X-500 Y-500 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 S2 H2 X5 Y5 F1500       ; go back a few mm
            G1 S1 H1 X-500 Y-500 F360  ; move slowly to X and Y axis endstops once more (second pass)
            G1 S1 H1 Z-300 F360        ; move Z down stopping at the endstop
            G90                     ; absolute positioning
            G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
            homez.g does a move towards home, then sets Z=0 when the endstops are triggered.
            G1 H2 Z15 F700    ; lift Z relative to current position
            G1 H1 Z-300 F700 ; move Z down until the endstop is triggered
            However, your M208 is M208 X500 Y500 Z320 S0, so Z axis is longer than the Z-300 move. In homez.g, change G1 H1 Z-300 F700 to G1 H1 Z-400 F700: it must be a bigger move than the axis length. Did you change M208 recently?
              @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
              You have an extra ! in there.
              AND CHANGE Z2 to Z1
                @droftarts config (27).g
                you correct the files please and I start as you send me
                  @paolozampini1973 Now you are missing the +
                  USE THIS!
                  Anyway, I have to go now. See my earlier post about change homez.g.
                    No I haven't changed it recently this car was so configured for months this is what I was always doing Solving the problem of loss of pace and it seems that you can see that step has been resolved but I still have to try it well
                    paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                      paolozampini1973 @paolozampini1973
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed May 19 2021 14:46:37 GMT+0200 (Ora legale dell’Europa centrale)
                      G92 Z=0 ; set Z position to axis minimum (you may want to adjust this)
                      ;G91 ; relative positioning
                      ;G90 ; absolute positioning
                        i did as you told me i put Z = 0 this is the result
                        SIamundefined 1 Reply Last reply Reply Quote 0
                        • SIamundefined
                          SIam @paolozampini1973
                          @paolozampini1973 and what have you done ? home z or home all ? If it was home z then you have to home x/y first.
                          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                          Duet WiFi 1.02 or later + DueX5
                          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                          Duet WiFi Server: 1.26
                          Duet Web Control 3.4.0beta4 (2021-09-27)
                          • SIamundefined
                            SIam @SIam
                            @siam oh I have overseen you was trying to home the z axis first before you can do this home y/x ( g28 x / g28 y)
                              @droftarts
                              G92 Z0 good
                              G92 Z=0 no good
                              M574 Z1 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
                              M574 Z2 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
                              M569 P7 S0 R1 T14:14:26:26 ; E4 X physical drive 7 goes forwards
                              M569 P8 S1 R1 T14:14:26:26 ; E5 Y physical drive 8 goes forwards
                              with these messages it seems that he no longer loses steps tomorrow I change from nema 17 to nema 23
                              tell me your thoughts thanks
                              17HS19-2004S1.pdf 23HS22-2804S.pdf
                              how can I return the courtesy that you have helped me ?
                              droftartsundefined paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                                @paolozampini1973
                                G92 Z=0 no good
                                That’s not a GCode command, and not one I wrote.
                                I think you mentioned $10,000 at the beginning???!!!
                                paolozampini1973undefined 3 Replies Last reply Reply Quote 1
                                  This post is deleted!
                                    @paolozampini1973
                                    G92 Z=0 no good
                                    and how much I have spent so far to carry out this project that I have not finished yet I hope to finish by next month at the latest
                                      @paolozampini1973
                                      G92 Z=0 no good
                                      Tomorrow I will do the replacement of the motors You have seen the configuration of my pulse config
                                        What is the maximum pulse value that is firmware you can control ?
                                          You shouldn't need to set the timing that high. I suggested T3:3:6:6. Did that not work? If you have to use such long pulses, I would guess it's because of running at 3.3V signalling, rather than 5V. Your drivers said they could do T2.5:2.5:5:5, so 5µs for a full step pulse, so 1,000,000 / 5 = 200,000 steps per second. With your setting, a full step pulse is 28µs, so you are limited to 1,000,000 / 28 = 35,700 steps per second. This limits you to 35700 / 200 (your steps per mm) = 178.5mm/s. The Duet 2 can realistically do around 100,000 steps per second, so getting the timing down to T5:5:10:10 would definitely help go faster.
                                          For the Z endstop, use M574 Z1 S1 P"!zstop+!e1stop". Using Z2 works as well, because it is followed by G92 Z0. If you remove this and use Z2, homing Z will cause Z to be set to the axis maximum, of 320. So use Z1.
                                          One more thing. In your homeall.g, each G1 command is followed by S1 or S2. These are unnecessary, and potentially confusing, as they are used to set laser power in RRF 3! The H1 and H2 parameters are correct. See https://docs.duet3d.com/User_manual/Reference/Gcodes/G1
                                          e.g.:
                                          G1 H2 Z15 F1500          ; lift Z relative to current position
                                          G1 H1 X-500 Y-500 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
                                          G1 H2 X5 Y5 F1500       ; go back a few mm
                                          G1 H1 X-500 Y-500 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                          G1 H1 Z-300 F360        ; move Z down stopping at the endstop
                                            T3:3:6:6 Yes I remember you told me this settings however I lose the pace
                                            T2.5:2.5:5:5 Yes I remember you told me this settings however I lose the pace I also tried to put them 74hc14 but it is much worse from 5 times I had to put it to 4 times even 3.8V to make it work it looks very strange but it is So I finally unplugged it
