    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    23.3k
    • SIamundefined
      SIam @SIam
      @siam oh I have overseen you was trying to home the z axis first before you can do this home y/x ( g28 x / g28 y)
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • paolozampini1973undefined
        paolozampini1973 @droftarts
        @droftarts
        G92 Z0 good
        G92 Z=0 no good
        M574 Z1 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
        M574 Z2 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
        M569 P7 S0 R1 T14:14:26:26 ; E4 X physical drive 7 goes forwards
        M569 P8 S1 R1 T14:14:26:26 ; E5 Y physical drive 8 goes forwards
        with these messages it seems that he no longer loses steps tomorrow I change from nema 17 to nema 23
        tell me your thoughts thanks
        17HS19-2004S1.pdf 23HS22-2804S.pdf
        how can I return the courtesy that you have helped me ?
        droftartsundefined paolozampini1973undefined 2 Replies Last reply Reply Quote 0
          droftarts administrators @paolozampini1973
          @paolozampini1973
          G92 Z=0 no good
          That’s not a GCode command, and not one I wrote.
          I think you mentioned $10,000 at the beginning???!!!
          paolozampini1973undefined 3 Replies Last reply Reply Quote 1
            This post is deleted!
              @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
              @paolozampini1973
              G92 Z=0 no good
              and how much I have spent so far to carry out this project that I have not finished yet I hope to finish by next month at the latest
                @paolozampini1973
                G92 Z=0 no good
                Tomorrow I will do the replacement of the motors You have seen the configuration of my pulse config
                  paolozampini1973 @paolozampini1973
                  @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
                  What is the maximum pulse value that is firmware you can control ?
                    You shouldn't need to set the timing that high. I suggested T3:3:6:6. Did that not work? If you have to use such long pulses, I would guess it's because of running at 3.3V signalling, rather than 5V. Your drivers said they could do T2.5:2.5:5:5, so 5µs for a full step pulse, so 1,000,000 / 5 = 200,000 steps per second. With your setting, a full step pulse is 28µs, so you are limited to 1,000,000 / 28 = 35,700 steps per second. This limits you to 35700 / 200 (your steps per mm) = 178.5mm/s. The Duet 2 can realistically do around 100,000 steps per second, so getting the timing down to T5:5:10:10 would definitely help go faster.
                    For the Z endstop, use M574 Z1 S1 P"!zstop+!e1stop". Using Z2 works as well, because it is followed by G92 Z0. If you remove this and use Z2, homing Z will cause Z to be set to the axis maximum, of 320. So use Z1.
                    One more thing. In your homeall.g, each G1 command is followed by S1 or S2. These are unnecessary, and potentially confusing, as they are used to set laser power in RRF 3! The H1 and H2 parameters are correct. See https://docs.duet3d.com/User_manual/Reference/Gcodes/G1
                    e.g.:
                    G1 H2 Z15 F1500          ; lift Z relative to current position
                    G1 H1 X-500 Y-500 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
                    G1 H2 X5 Y5 F1500       ; go back a few mm
                    G1 H1 X-500 Y-500 F360  ; move slowly to X and Y axis endstops once more (second pass)
                    G1 H1 Z-300 F360        ; move Z down stopping at the endstop
                    G90                     ; absolute positioning
                    G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                      T3:3:6:6 Yes I remember you told me this settings however I lose the pace
                      T2.5:2.5:5:5 Yes I remember you told me this settings however I lose the pace I also tried to put them 74hc14 but it is much worse from 5 times I had to put it to 4 times even 3.8V to make it work it looks very strange but it is So I finally unplugged it
                        @droftarts however it is also true that the mass to be moved is a lot on purpose. I sent you to show you here nema 23 they have double the torque resistance and half and the girl is shorter in fact I was waiting for your consideration and your opinion on those engines because with nema17 it goes well
                          @paolozampini1973 Sorry, I don't know if NEMA 23 will run better than NEMA17 with your external drivers on your machine. You will just have to test them.
                            but based on the characteristics what do you think17HS19-2004S1.pdf 23HS22-2804S.pdf
                              M569 P7 S0 R1 T5:5:10:10 ; E4 X physical drive 7 goes forwards
                              M569 P8 S1 R1 T5:5:10:10 ; E5 Y physical drive 8 goes forwards
                              M569 P9 S1 R-1 ; E6 Z physical drive 9 goes forwards
                              M584 X7 Y8 Z1:2 E3:4:5:6 S0 ; set drive mapping
                              M671 X0:0 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                              M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping without interpolation
                              M92 X99.975 Y99.975 Z800.10 E392.70:392.70:392.70:392.70 ; set steps per mm
                              M566 X1000.00 Y1100.00 Z1500.00 E5000.00:5000.00:5000.00:5000.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X10000.00 Y10000.00 Z4500.00 E10000.00:10000.00:10000.00:10000.00 ; set maximum speeds (mm/min)
                              M201 X2400.00 Y2400.00 Z1500.00 E4000.00:4000.00:4000.00:4000.00 ; set accelerations (mm/s^2)
                              M906 X0 Y2000 Z2000 E1500:1500:1000:1000 I90 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S15 ; Set idle timeout
                              Yes so it doesn't lose the pace I'm trying now
                              100 mm of printing and 130 of displacement
                              paolozampini1973undefined 1 Reply Last reply Reply Quote 0
                                @droftarts
                                someone can explain to me why I start printing a rectangle 200 mm x 20 mm and when it starts printing it starts printing 55 mm after this means that on a line of 200 mm It only prints 145 mm because?
                                config (30).g
                                  @paolozampini1973 as this is a new issue, use your new thread. I have undeleted it.
