    DUEX 5 V0.8 TO DUEX 5 V0.11
    283
    24.1k
      droftarts administrators @paolozampini1973
      @paolozampini1973 Now you are missing the +
      USE THIS!
      M574 Z1 S1 P"!zstop+!e1stop"
      Anyway, I have to go now. See my earlier post about change homez.g.
      paolozampini1973undefined 1 Reply Last reply Reply Quote 0
      • paolozampini1973undefined
        paolozampini1973 @droftarts
        @droftarts said in DUEX 5 V0.8 TO DUEX 5 V0.11:
        @paolozampini1973 Also, the last homeall.g does not home z; it just sets Z=0 wherever Z is.
        G1 S2 H2 Z15 F1500          ; lift Z relative to current position
        G1 S1 H1 X-500 Y-500 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
        G1 S2 H2 X5 Y5 F1500       ; go back a few mm
        G1 S1 H1 X-500 Y-500 F360  ; move slowly to X and Y axis endstops once more (second pass)
        G1 S1 H1 Z-300 F360        ; move Z down stopping at the endstop
        G90                     ; absolute positioning
        G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
        homez.g does a move towards home, then sets Z=0 when the endstops are triggered.
        G1 H2 Z15 F700    ; lift Z relative to current position
        G1 H1 Z-300 F700 ; move Z down until the endstop is triggered
        However, your M208 is M208 X500 Y500 Z320 S0, so Z axis is longer than the Z-300 move. In homez.g, change G1 H1 Z-300 F700 to G1 H1 Z-400 F700: it must be a bigger move than the axis length. Did you change M208 recently?
        No I haven't changed it recently this car was so configured for months this is what I was always doing Solving the problem of loss of pace and it seems that you can see that step has been resolved but I still have to try it well
        paolozampini1973undefined 2 Replies Last reply Reply Quote 0
          paolozampini1973 @paolozampini1973
          @paolozampini1973 said in DUEX 5 V0.8 TO DUEX 5 V0.11:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed May 19 2021 14:46:37 GMT+0200 (Ora legale dell’Europa centrale)
          G92 Z=0 ; set Z position to axis minimum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
            i did as you told me i put Z = 0 this is the result
            SIamundefined 1 Reply Last reply Reply Quote 0
            • SIamundefined
              SIam @paolozampini1973
              @paolozampini1973 and what have you done ? home z or home all ? If it was home z then you have to home x/y first.
              Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
              Duet WiFi 1.02 or later + DueX5
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
              Duet WiFi Server: 1.26
              Duet Web Control 3.4.0beta4 (2021-09-27)
              • SIamundefined
                SIam @SIam
                @siam oh I have overseen you was trying to home the z axis first before you can do this home y/x ( g28 x / g28 y)
                  @droftarts
                  G92 Z0 good
                  G92 Z=0 no good
                  M574 Z1 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
                  M574 Z2 S1 P"!zstop+!e1stop" it works there is no difference I don't understand why
                  M569 P7 S0 R1 T14:14:26:26 ; E4 X physical drive 7 goes forwards
                  M569 P8 S1 R1 T14:14:26:26 ; E5 Y physical drive 8 goes forwards
                  with these messages it seems that he no longer loses steps tomorrow I change from nema 17 to nema 23
                  tell me your thoughts thanks
                  17HS19-2004S1.pdf 23HS22-2804S.pdf
                  how can I return the courtesy that you have helped me ?
                  droftartsundefined paolozampini1973undefined 2 Replies Last reply Reply Quote 0
                    @paolozampini1973
                    G92 Z=0 no good
                    That’s not a GCode command, and not one I wrote.
                    I think you mentioned $10,000 at the beginning???!!!
                    paolozampini1973undefined 3 Replies Last reply Reply Quote 1
                      This post is deleted!
                        @paolozampini1973
                        G92 Z=0 no good
                        and how much I have spent so far to carry out this project that I have not finished yet I hope to finish by next month at the latest
                          @paolozampini1973
                          G92 Z=0 no good
                          Tomorrow I will do the replacement of the motors You have seen the configuration of my pulse config
                            What is the maximum pulse value that is firmware you can control ?
                              You shouldn't need to set the timing that high. I suggested T3:3:6:6. Did that not work? If you have to use such long pulses, I would guess it's because of running at 3.3V signalling, rather than 5V. Your drivers said they could do T2.5:2.5:5:5, so 5µs for a full step pulse, so 1,000,000 / 5 = 200,000 steps per second. With your setting, a full step pulse is 28µs, so you are limited to 1,000,000 / 28 = 35,700 steps per second. This limits you to 35700 / 200 (your steps per mm) = 178.5mm/s. The Duet 2 can realistically do around 100,000 steps per second, so getting the timing down to T5:5:10:10 would definitely help go faster.
                              For the Z endstop, use M574 Z1 S1 P"!zstop+!e1stop". Using Z2 works as well, because it is followed by G92 Z0. If you remove this and use Z2, homing Z will cause Z to be set to the axis maximum, of 320. So use Z1.
                              One more thing. In your homeall.g, each G1 command is followed by S1 or S2. These are unnecessary, and potentially confusing, as they are used to set laser power in RRF 3! The H1 and H2 parameters are correct. See https://docs.duet3d.com/User_manual/Reference/Gcodes/G1
                              e.g.:
                              G1 H2 Z15 F1500          ; lift Z relative to current position
                              G1 H1 X-500 Y-500 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
                              G1 H2 X5 Y5 F1500       ; go back a few mm
                              G1 H1 X-500 Y-500 F360  ; move slowly to X and Y axis endstops once more (second pass)
                              G1 H1 Z-300 F360        ; move Z down stopping at the endstop
                                T3:3:6:6 Yes I remember you told me this settings however I lose the pace
                                T2.5:2.5:5:5 Yes I remember you told me this settings however I lose the pace I also tried to put them 74hc14 but it is much worse from 5 times I had to put it to 4 times even 3.8V to make it work it looks very strange but it is So I finally unplugged it
                                  @droftarts however it is also true that the mass to be moved is a lot on purpose. I sent you to show you here nema 23 they have double the torque resistance and half and the girl is shorter in fact I was waiting for your consideration and your opinion on those engines because with nema17 it goes well
                                    @paolozampini1973 Sorry, I don't know if NEMA 23 will run better than NEMA17 with your external drivers on your machine. You will just have to test them.
                                      but based on the characteristics what do you think17HS19-2004S1.pdf 23HS22-2804S.pdf
                                        M569 P7 S0 R1 T5:5:10:10 ; E4 X physical drive 7 goes forwards
                                        M569 P8 S1 R1 T5:5:10:10 ; E5 Y physical drive 8 goes forwards
                                        M569 P9 S1 R-1 ; E6 Z physical drive 9 goes forwards
                                        M584 X7 Y8 Z1:2 E3:4:5:6 S0 ; set drive mapping
                                        M671 X0:0 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                        M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping without interpolation
                                        M92 X99.975 Y99.975 Z800.10 E392.70:392.70:392.70:392.70 ; set steps per mm
                                        M566 X1000.00 Y1100.00 Z1500.00 E5000.00:5000.00:5000.00:5000.00 ; set maximum instantaneous speed changes (mm/min)
                                        M203 X10000.00 Y10000.00 Z4500.00 E10000.00:10000.00:10000.00:10000.00 ; set maximum speeds (mm/min)
                                        M201 X2400.00 Y2400.00 Z1500.00 E4000.00:4000.00:4000.00:4000.00 ; set accelerations (mm/s^2)
                                        M906 X0 Y2000 Z2000 E1500:1500:1000:1000 I90 ; set motor currents (mA) and motor idle factor in per cent
                                        M84 S15 ; Set idle timeout
                                        Yes so it doesn't lose the pace I'm trying now
                                        100 mm of printing and 130 of displacement
                                          @droftarts
                                          someone can explain to me why I start printing a rectangle 200 mm x 20 mm and when it starts printing it starts printing 55 mm after this means that on a line of 200 mm It only prints 145 mm because?
                                          config (30).g
                                            @paolozampini1973 as this is a new issue, use your new thread. I have undeleted it.
