Solved 3.4.0 Stable breaks Nozz Heater[1LC ]Error:M307:Response timeout
EDIT 4/3/2022 10:55 PM PST - After several trial and error tests and actually adding a new spare 1LC fresh from factory 3.3 fw version [ 1LC v1.2 ] it seems that upgrading to the 3.4.0 stable release is breaking my systems heater. See all points below.
Error: M307: Response timeout: CAN addr 121, req type 6049, RID=14
Error: M307: Response timeout: CAN addr 121, req type 6049, RID=8
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 214CFW: 3.4. Latest STABLE
SBC Mode / Pi 4
Duet3 Mini 5+
Voron 2.4
1LC Toolboard v1.2;=================================== ; Nozzle Heater ;=================================== M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as Thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S285 ; set temperature limit for heater 1 to 285C
This is new ... Also cant turn heater1 On Off or Standby in DWC
@sputnikoc3d ```
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) All averaging filters OK Never used RAM 2624, free system stack 88 words Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,101) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.8%,349) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0% Last reset 00:15:24 ago, cause: software Last software reset data not available Driver 0: pos 0, 415.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 26, reads 3640, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter -5/8, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled VIN voltage: min 24.2, current 24.3, max 24.3 MCU temperature: min 38.2C, current 38.2C, max 42.0C Last sensors broadcast 0x00000002 found 1 96 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 18229, send timeouts 14, received 8167, lost 0, free buffers 37, min 37, error reg 110000 Last cancelled message type 4525 dest 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, other errors 0
everything else on the toolboard is working except the H1 nozzle heater .... therm / probe / fans . Heater was working before on the old toolboard that had the bad mosfet/blown mosfet - replaced the 1LC to a ver 1.2 - flashed all the fw up to 3.4.0 and started installing Klicky - klicky is working - all else is - but the Heater.
This is my 2nd 1LC tooboard ... I do have another spare. [3rd ]
Not sure whats going on here. All other crimps and wiring on the 1LC works or worked before 3.4.0
Put on a spare v1.2 1LC toolboard.
FW ver 3.3 atm - and all works as intended - even the heater.
Will flash the board to 3.4.0
Ok well flashing the 1LC FW to 3.4.0 using M997 B121 ... updated the firmware.
It hung on updating - please wait like it did the very first time I upgraded to 3.4.0 Stable.
1LC worked fine on 3.3 from the factory. Now on 3.4.0 Stable - the above errors have returned, and no heater control. Its as if it is DEAD.
@sputnikoc3d i suggest check your wiring
@jay_s_uk said in 3.4.0 Stable breaks Nozz Heater[1LC ]Error:M307:Response timeout:
I have multiple times and it works great. Everything works on 1LC ver 3.3 fw. Everything on the toolboard except the heater works on 3.4.0
@sputnikoc3d what type of wiring are you using?
Cat 5 twisted pair for CAN
@sputnikoc3d the M307 errors are why the heater won't turn on. Have you used M115 or M122 to check that the main board is running firmware 3.4 ?
You may need to rerun heater 1 tuning to generate a new M307 H1 command.
@dc42 - TY for your reply.
Fresh reboot and power cycle of the SBC / Duet generates No M307 error code - that only happens on estop of the duet.
1st op after fresh reboot of entire machine and no reporting of errors, I try M303 H1 S240. I get :
M303 H1 S240
Auto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
Auto tune starting phase 2, heating up
Auto tune cancelled because temperature is not increasing -
@dc42 well there it is ... looks like the FW upgrade from the previous post using the USB stick didnt actually work as planned ...
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: 1JDTH-UA67A-G65J0-40TFU-22D0Z-R2KLQ Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 102756 Dynamic ram: 93644 of which 0 recycled Never used RAM 42456, free system stack 200 words Tasks: SBC(ready,2.3%,312) HEAT(notifyWait,0.0%,269) Move(notifyWait,0.0%,338) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,346) TMC(notifyWait,1.1%,106) MAIN(running,95.1%,536) IDLE(ready,0.7%,29) AIN(delaying,0.8%,264), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:05:55 ago, cause: power up Last software reset at 2021-10-30 23:33, reason: User, GCodes spinning, available RAM 42456, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 MCU revision 3, ADC conversions started 355962, completed 355961, timed out 0, errs 0 Step timer max interval 1474 MCU temperature: min 21.7, current 29.9, max 29.9 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/224/158, gc cycles 0 Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32297, writes 11, timeouts 0, DMA errors 0 Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0 Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0 Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0 Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 32299, writes 9, timeouts 0, DMA errors 0 Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0 Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0 Date/time: 2021-10-31 00:02:40 Cache data hit count 836168537 Slowest loop: 9.15ms; fastest: 0.07ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 3111, received 6801, lost 0, longest wait 2ms for reply type 6026, peak Tx sync delay 3, free buffers 16 (min 15), ts 1778/1777/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === State: 4, failed transfers: 1, checksum errors: 0 Last transfer: 4ms ago RX/TX seq numbers: 13281/13281 SPI underruns 0, overruns 0 Disconnects: 0, timeouts: 0, IAP RAM available 0x10810 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.4.0 Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 39.80, max time between full transfers: 87.9ms, max pin wait times: 51.1ms/11.5ms Codes per second: 0.22 Maximum length of RX/TX data transfers: 3464/796
Please mark this issue as resolved - it was due to m failure to notice mismatched firmware.
Got the right FW on the Duet Mainboard via M997 S0
@sputnikoc3d - well the rasp pi is not updated to 3.4.0 stable though
grep of the isntalled duet versions indicates all are still on 3.4beta3 on the Pi
Ideas to correct this ?
I think you got your answer in your other thread.
