    Duet 3. ? faulty Driver0. Post requested by Duet
    Using Duet Controllers
    1.2k
      T3P3Tony administrators @DavidSimcock
      @davidsimcock ok so something is causing the X axis to loose its holding torque as part of the Y homing.
      Can you try the following minimalistic homey.g temporarily.
      ; homey.g
      ; called to home the Y axis
      G91 ; relative positioning
      G1 H1 Y1500 F1500 ; move quickly to Y axis endstops and stop there (first pass)
      G1 Y-3 F150 ; go back a few mm
      G1 H1 Y1500 F150 ; move slowly to Y axis endstops once more (second pass)
      G90 ; absolute positioning
      Caution this file no longer homes homes Z as part of the Y move so please ensure the Z axis is in a safe position before running it.
      The idea is to see if the X axis is still disabled if X is homes first, then Y homed. both as individual moves. (so homeall.g is not modified yet.)
      DavidSimcockundefined 1 Reply Last reply Reply Quote 0
      • DavidSimcockundefined
        DavidSimcock @T3P3Tony
        @t3p3tony said in Duet 3. ? faulty Driver0. Post requested by Duet:
        ; homey.g
        Just to check Tony...are you suggesting I suspend all the commands in my homey.g and paste your commands beneath? Followed by sending homex.g and following this with sending homey.g ?
          @davidsimcock I would rename the current homey.g to homey.g.backup then make a new homey.g with the contents above. then yes G28 X, then G28 Y
            OK...I've done that. The result is that the x axis motor is de-energised at the end of the process.
              After homing is complete can you send M906 and M913 by itself and report back what it says?
              Another thing to try is to completely backup your current config, remove it all, and start with a fresh basic config from the online tool.
              https://configtool.reprapfirmware.org/Start
              DavidSimcockundefined 1 Reply Last reply Reply Quote 1
                DavidSimcock @Phaedrux
                @phaedrux said in Duet 3. ? faulty Driver0. Post requested by Duet:
                Thanks. Here are the M906 and M913
                M906.txt
                M913.txt
                  dc42 administrators @DavidSimcock
                  @davidsimcock from your config-axes.g file:
                  ; Axes configuration executed by config.g
                  M584 X0.0 Y0.1:0.3 Z0.2:0.4
                  M669 K0 X1:0:0:0 Y0:1:0:1 Z0:0:1:0
                  You are defining 3 physical axes but your M669 command assumes 4. Try changing the M669 command to this:
                  M669 K0 X1:0:0 Y0:1:0 Z0:0:1
                    DavidSimcock @dc42
                    @dc42 said in Duet 3. ? faulty Driver0. Post requested by Duet:
                    Right...I've revised the M669 as suggested. Homing now functions as it should, with the x axis motor holding torque. Thanks for the suggestion!
                      DavidSimcock @DavidSimcock
                      @davidsimcock The issue does seem to be resolved with changing the kinematics M669 command.
                      A BIG THANKS to all who have made suggestions to resolve the issue. It is much appreciated.
                      • dc42undefined dc42 marked this topic as a question
                      • dc42undefined dc42 has marked this topic as solved
                        @davidsimcock thanks for confirming this. May I ask where the config came from?
                          @t3p3tony I took it from the Ooznest Workbee configuration that I had on a duet 2 wifi, and adapted it for the parameters of my machine. Why there should have been those kinematis commands I don't know. And I confess to not really understanding why there were 4 entry's...
                            @davidsimcock thanks, I will follow up with Ooznest. Thanks agin with your patience as we worked through this.
                              jay_s_uk @T3P3Tony
                              @t3p3tony M669 was also a feature of this workbee config https://forum.duet3d.com/topic/27923/x-axis-stops-working-after-moving-y
                                T3P3Tony administrators @jay_s_uk
                                @jay_s_uk thank you for linking these two together I did not see that post.
                                We have captured the issue with M669 to review.
                                  dc42 administrators @T3P3Tony
                                  I've added the behaviour when M669 has too many entries per matrix row to the bug list.
