    Is there a terminal like YAT for RPI?
    Using Duet Controllers
    1.8k
    • tecnoundefined
      tecno @Phaedrux
      @phaedrux
      I want to access my Duet Mini5 via USB so I can get Wifi working as this drops out now and then.
        Ok. So you want to access the Duet terminal from the Pi? Now I understand.
        You can follow this guide and use the instructions for Linux
        https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • oliofundefined
          oliof
          the screen command in Linux can be used as a serial terminal.
          • tecnoundefined
            tecno @oliof
            @oliof
            There is no screen i Raspberry OS
            • oliofundefined
              oliof @tecno
              @tecno you can install it, using the normal package installation system, i.e. sudo apt-get update; sudo apt install screen
              • tecnoundefined
                tecno @oliof
                @oliof
                How on earth do you get screen to connect to Duet board?
                • tecnoundefined
                  tecno @Phaedrux
                  @phaedrux said in Is there a terminal like YAT for RPI?:
                  Sorry but not one word on how to with Pi
                  • oliofundefined
                    oliof @tecno
                    @tecno I am not close to my printers right now, but it's just the serial device as an argument to screen, so something like screen /dev/ttyUSB0 (the latter could be something else, check dmesg). Read the screen man page for other options like connection speed.
                    • tecnoundefined
                      tecno @oliof
                      @oliof
                      OK ls /dev/ttyACM0 is there
                      screen /dev/ttyACM0
                      screen terminating
                      Sorry but this kind of terminal is real PITA
                      • tecnoundefined
                        tecno @tecno
                        Managed to get CuteCom installed but no response on M115, only response I get is Error : VIN undervoltage when I power down.
                        Short.. Printer has been working for +48hours and I needed to change filament so I decided to take a brake for dinner and shut off the printer. After that I have no connection with the Duet board other than above Undervoltage message, no other commands work. USB terminal feels a bit wonky/loose.
                          VIN undervoltage may just mean that VIN power has been removed but the duet is still powered by 5v via usb.
                          Where are you seeing the undervoltage event message?
                          • tecnoundefined
                            tecno @Phaedrux
                            In CuteCom when unplugged power.
                            Anyhow this morning I get response to commands, have not touched anything from last night so go figure what was going on yesterday evening. Config.g empty 'again'.
                            • chrishammundefined
                              chrishamm administrators @tecno
                              @tecno minicom should work, too. It comes preconfigured for the Duet on DuetPi.
                              Duet software engineer
                              tecnoundefined 1 Reply Last reply Reply Quote 1
                              • tecnoundefined
                                tecno @chrishamm
                                @chrishamm
                                OK, satisfied with Cutecom.
                                  Phaedrux Moderator @tecno
                                  @tecno said in Is there a terminal like YAT for RPI?:
                                  Was this the original problem here or that it had happened previously?
                                  • tecnoundefined
                                    tecno @Phaedrux
                                    @phaedrux
                                    Both
                                      Had you edited config.g before it had gone empty?
                                      Was config.g missing completely, or just blank?
                                      Was config.g.bak present and complete?
                                      • tecnoundefined
                                        tecno @Phaedrux
                                        @phaedrux
                                        No
                                        Blank
                                        Present
                                          Thanks. Had we replaced this board for you already when it first happened?
                                          • tecnoundefined
                                            tecno @Phaedrux
                                            @phaedrux
                                            No config this morning, printer been offline for 2 days.
                                            Today no config.g and no config.g.bak
                                            re. board To be honest I do not remember. M552 S1 keeps me running
