    Is there a terminal like YAT for RPI?
    Using Duet Controllers
    1.9k
    • tecnoundefined
      tecno @tecno
      Managed to get CuteCom installed but no response on M115, only response I get is Error : VIN undervoltage when I power down.
      Short.. Printer has been working for +48hours and I needed to change filament so I decided to take a brake for dinner and shut off the printer. After that I have no connection with the Duet board other than above Undervoltage message, no other commands work. USB terminal feels a bit wonky/loose.
        VIN undervoltage may just mean that VIN power has been removed but the duet is still powered by 5v via usb.
        Where are you seeing the undervoltage event message?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @Phaedrux
          @phaedrux said in Is there a terminal like YAT for RPI?:
          In CuteCom when unplugged power.
          Anyhow this morning I get response to commands, have not touched anything from last night so go figure what was going on yesterday evening. Config.g empty 'again'.
          • chrishammundefined
            chrishamm administrators @tecno
            @tecno minicom should work, too. It comes preconfigured for the Duet on DuetPi.
            Duet software engineer
            tecnoundefined 1 Reply Last reply Reply Quote 1
            • tecnoundefined
              tecno @chrishamm
              @chrishamm
              OK, satisfied with Cutecom.
                Phaedrux Moderator @tecno
                @tecno said in Is there a terminal like YAT for RPI?:
                Was this the original problem here or that it had happened previously?
                • tecnoundefined
                  tecno @Phaedrux
                  @phaedrux
                  Both
                    Had you edited config.g before it had gone empty?
                    Was config.g missing completely, or just blank?
                    Was config.g.bak present and complete?
                    • tecnoundefined
                      tecno @Phaedrux
                      @phaedrux
                      No
                      Blank
                      Present
                        Thanks. Had we replaced this board for you already when it first happened?
                        • tecnoundefined
                          tecno @Phaedrux
                          @phaedrux
                          No config this morning, printer been offline for 2 days.
                          Today no config.g and no config.g.bak
                          re. board To be honest I do not remember. M552 S1 keeps me running
                          • tecnoundefined
                            tecno @tecno
                            Here some moore
                            Now no CAN connection, WTF is going on??
                            jay_s_ukundefined tecnoundefined dc42undefined 3 Replies Last reply Reply Quote 0
                              jay_s_uk @tecno
                              @tecno i've seen that happen when i reboot. the board reboots before the toolboard can respond. its normal I think
                              • tecnoundefined
                                tecno @tecno
                                Edited config.g (probe) and now CAN is back, this a bit fishy.
                                • tecnoundefined
                                  tecno @jay_s_uk
                                  @jay_s_uk
                                  ; WAIT FOR CAN
                                  G4 S4 should be plenty
                                    jay_s_uk @tecno
                                    @tecno the red line issue you showed above was after the emergency stop and not to do with startup
                                    • tecnoundefined
                                      tecno @jay_s_uk
                                      @jay_s_uk
                                      Ain't that same as remote boot up?
                                        jay_s_uk @tecno
                                        @tecno no
                                        • tecnoundefined
                                          tecno @jay_s_uk
                                          @jay_s_uk
                                          So only power off and on?
                                            jay_s_uk @tecno
                                            @tecno imagine you're on the phone to someone and you ask them a question but they hang up before they can answer, thats the same as whats happening when you press the emergency stop button. the main board asks the heater to turn off to make sure its off but its already rebooting, so you get the error that the remote heater can't be turned off. it has nothing to do with startup delay
