    Poor surface finish
    27
    1.3k
    • jens55undefined
      jens55
      Well crap ..... minimum layer time was set at 3 seconds and I guess that the layers tried to print faster than that ..... dropped it down to 1 second and it is running nicely at the set speed of 100 mm/sec.
      Odd though that increasing the speed factor allowed the speed to go higher .... I guess because the minium layer time is enforced in the slicer and the speed factor setting is strictly on the printer.
      It appeared though that adjusting the speed factor did not seem to change the extruder speed as increasing the speed resulted in under extrusion. Very odd ....
      • jens55undefined
        jens55 @jens55
        Apparently as of RRF 31. speed factor does not affect extrusion speed. I am not sure why this was changed from the earlier versions of RRF where speed factor modified all speed settings including extruder speed.
        mrehorstdmdundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • mrehorstdmdundefined
          mrehorstdmd @jens55
          @jens55 a low jerk setting could be limiting speed on a circular print.
          • jens55undefined
            jens55 @mrehorstdmd
            @mrehorstdmd, the speed limiting happened because of layer time. Once that was reduced from 3 sec to 1 sec, the speed was back up to what it was set to in Cura.
            In the past I had set jerk to 25 but as it turns out, I had turned off jerk control for some reason or another.
            • infiniteloopundefined
              infiniteloop
              @jens55 said in Poor surface finish:
              I'm still at 3.3b4, but up to that version, I can assure that extrusion follows the speed factor precisely. Apparently, with your apparatus, other factors play a role 🙄
              • jens55undefined
                jens55 @infiniteloop
                @infiniteloop, well that is quite possible since making assumptions and jumping to conclusions is one of my fav past-times 😞
                It just seemed to fit - proper extrusion at the original speed, increase 'speed factor' and see under extrusion. While it is possible that I was pushing the extruder too much, in this case I was going relatively slow and would not have thought that I was anywhere near the hot end limit.
                • rjenkinsgbundefined
                  rjenkinsgb @jens55
                  @jens55 From the way the defects occur at similar locations in different consecutive layers, I suspect something mechanically sticking - eg a bit of grit in a bearing or a dry bearing.
                  That could explain the blob or melting effect, if the nozzle momentarily pauses them jumps past that spot once the drive system has wound up enough??
                  Robert J.
                  Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                    dc42 administrators @jens55
                    Speed factor is not applied to extruder-only moves, i.e. retraction, reprime, filament loading and unloading.
                    • jens55undefined
                      jens55 @dc42
                      @dc42, thanks for the clarification !
                        mrehorstdmd @rjenkinsgb
                        @rjenkinsgb I had an extruder motor cable failure several years ago when I used a too small bend radius in a drag chain. It would cause the extruder to cut out momentarily at specific XY locations in the prints. It took a while to figure out what was happening. The wires had fractured inside their own insulation, the result of being bent too many times.
