NeoPixel wrong Color
@heartleander81
Maybe there are some unwanted signals to the LED-strip at startup? Can you try to clear all LEDs before the white?
Could be in the same line with the configuration. -
@o_lampe how clear i all LED?
M150 P0 S60 ? That use I to make it off. -
I was having issues with RGB LED's on my Voron, adding a 1.5K resistor to the Data line at the strip end fixed it.
@rushmere3d dotstar ore neopixel? Neopixel have 1 data line not 2
@heartleander81 Neopixels and I'm aware of that maybe didn't explain it right.
Where the 3 wires attach to the strip, disconnect the data and solder a resistor to the wire then the other end to the data connection on the strip. I didn't say anything about 2 data lines?
@rushmere3d sorry then I misunderstood. But unfortunately I don't have anything like that at home and what surprises me before the update to 3.4 I had no problem with it.
@dc42 @ I use M150 X1 for RGB NeoPixel
Issused found. How Can I close ore delet this thread?
Care to share? What it was and how you fixed it.
You need to mark it as a question, then mark it as solved.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
@rushmere3d
I clamped the line for the signals between the ramen and the motor and I suspect that I have generated interference signals.
