    1HCL 1.0 closed loop controller
    2.6k
    • Stephen6309undefined
      Stephen6309 @supertb1
      @supertb1 The symbols file is not the firmware. Use Duet2and3firmware-3.4.0.zip. That's the first file on the release page.
      The firmwares all have firmware in the filename.
      https://github.com/Duet3D/RepRapFirmware/releases
      • alankilianundefined
        alankilian @Stephen6309
        @supertb1 THIS is a link to the 3.4.0 release ZIP file.
        • supertb1undefined
          supertb1 @dc42
          @dc42 So I did the Duet2and3Firmware-3.4.0 that took ,and then I did the Duet3Firmware_MB6HC which yielded :3.4 6mainboard error.jpg
          and it basically bricked the controller, I can't get on the DWC and I can't make it do anything from the touch screen... I hope a reset will fix this and nothing permanent has been done. any help would be great.
            If you send M115 on the paneldue does it respond?
            You can use this method to flash the desired firmware directly to the 6HC.
            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
            Can you also check what firmware version you have running on the PanelDue in the setup page? You should probably update it as well using USB and similar procedure.
            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
            supertb1undefined 2 Replies Last reply Reply Quote 0
            • supertb1undefined
              supertb1 @Phaedrux
              No response, and to boot the status light on the main board is dimly lit, the status on the 1HLC boards are flashing red....so at this point is my best coarse of action to connect my computer directly to the Main Board and use BOSSA to flash the firmware? or am I someplace else?
              what is the correct board sequence to flash? What have I done to this thing? so exciting to have messed this thing up and now I get to learn how to fix it😵 😨 😰 😬 🤔 😟
              • supertb1undefined
                supertb1 @Phaedrux
                @phaedrux one last thing, while using BOSSA what is the correct order to install the software?
                  Phaedrux Moderator @supertb1
                  @supertb1 said in 1HCL 1.0 closed loop controller:
                  I'm not sure what you mean by correct order. Have you looked at this link yet? https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware
                  supertb1undefined 1 Reply Last reply Reply Quote 0
                  • supertb1undefined
                    supertb1 @Phaedrux
                    @phaedrux Have you guys made a video someplace demonstrating a BOSSA or other method of erasure through firmware install... this is making me a little nervous never having done this before
                      It's pretty straightforward.
                      https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
                      Fit the erase jumper, power it up, remove the jumper. The firmware is erased and will show up as a bossa port.
                      Select the port in Bossa, select the firmware file, select the options to match those shown in the picture and flash and verify.
                      You can't damage the board with a firmware update even if it fails in the middle.
                      • supertb1undefined
                        supertb1 @Phaedrux
                        @phaedrux is the diagnostic light rite next to the micro USB port?
                        • supertb1undefined
                          supertb1 @Phaedrux
                          @phaedrux positive responce.jpg OK I used BOSSA to install Duet3Firmware_MB6HC... not Duet2and3Firmware-3.4.0 and it worked... I have access to DWC... so is it at this point I can install Duet2and3Firmware-3.4.0 or is there something else I should do to make sure I don't have another system lock up.
                            If you now have access to DWC you can upload the full 3.4 zip file to ensure you have all the right files in place for future updates.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/Duet2and3Firmware-3.4.0.zip
                            Upload that zip file as is to the system tab in DWC. Don't extract it first. Once done, check the firmware version again with M115. It may prompt to update any attached expansion boards as well. You can check those with M115 B# where # is the CAN bus address of the expansion board.
                            supertb1undefined 3 Replies Last reply Reply Quote 0
                            • supertb1undefined
                              supertb1 @Phaedrux
                              Same errors as before, it is Duet2and3Firmware-3.4.0 causing the system to lock up, I'm going to start over here, this next time I will record and post a youtube video of the update as it happens. Hopefully I can glean some idea as to why or when exactly the fail happens. unless you have a better idea?
                              • supertb1undefined
                                supertb1 @Phaedrux
                                @phaedrux do you think it would help to disconnect everything from the board except the panel Due?
                                • supertb1undefined
                                  supertb1 @Phaedrux
                                  @phaedrux I erased the board again and then used BOSSA to re-install Duet3Firmware_MB6HC.bin. At startup the first error I get on my panel due is "ERROR Bad model parameters". Then it posts the IP address and then it posts connected.
                                    dc42 administrators @supertb1
                                    That suggests a problem with one of your M307 commands in config.g, or a missing M307 command.
                                    • supertb1undefined
                                      supertb1 @dc42
                                      @dc42 ; General preferences
                                      M550 P"Hemera" ; set printer name
                                      M552 P192.168.1.74 S1 ; enable network and acquire dynamic address via DHCP
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      G4 S1 ;wait for expansion boards to start
                                      M569.1 P50.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 50 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
                                      M569.1 P51.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 51 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
                                      M569 P50.0 D4 S1 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) X axis
                                      M569 P51.0 D4 S1 ; Configure the motor on the 1HCL at can address 51 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) Y axis
                                      M584 X50.0 Y51.0 Z0.0 E0.1 ; set drive mapping
                                      M92 X106.50 Y106.50 Z400.00 E420.00 ; set steps per mm
                                      M906 X1000 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M917 X10 Y10 ; Set the closed loop axes to have a holding current of zero
                                      M208 X235 Y235 Z235 S0 ; set axis maxima
                                      M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin !^io1.in
                                      M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
                                      M591 D0 P7 C"io5.in" L7 R55:150 E22 S1 ;Bigtree smart filament moniter v2 set to moniter between 55%-150% of 7 counts over a distance of 22mm
                                      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                                      M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X60 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                      M557 X15:200 Y15:200 S20 ; define mesh grid
                                      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 Bed Heater
                                      M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                                      M307 H0 B1 S5.00 ; enable bang-bang mode for the bed heater and set PWM limit
                                      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                                      M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
                                      M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                                      M106 P0 C"Tool Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                                      ;M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
                                      M950 F1 C"!out6+out6.tach" ; Fan 1 uses out6, but we are using a PWM fan so the output needs to be inverted, and using out6.tach as a tacho input
                                      M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency
                                      M106 P1 C"Extruder" S1 H1 T50 ; set fan 1 name and value. Thermostatic control is turned on
                                        @supertb1 looks like you haven't run M303 heater tuning on either of your heaters, so you have incomplete M307 commands.
                                        • supertb1undefined
                                          supertb1 @dc42
                                          @dc42 OK thanks... I will get that done... any idea why Duet2and3Firmware-3.4.0 is causing the board to lock up? or do you think the heater tune is the answer?
                                          • supertb1undefined
                                            supertb1 @dc42
                                            @dc42 This is what I came up with on my heater calibrations:
                                            M307 H0 R0.395 K0.368:0.000 D5.05 E1.35 S1.00 B0
                                            M307 H1 R4.905 K0.241:0.035 D7.64 E1.35 S1.00 B0 V24.0
                                            Do I try and perform Duet2and3Firmware-3.4.0.zip again? or is there something else I need to do?
