    Mini 5+ Wifi not working any more
    597
    • Chrissundefined
      Chriss
      Hi *,
      I have a Mini5+ here on my desk, just for testing purposes so it has no "usual" working configuration. I paned to play with the LEDs a bit but it is not connection to wifi any more.
      I flashed 3.4 final a while ago the to board. The status LED is blinking in the usual rhythm, so I guess that the firmware booted.
      I connected to the serial interface and tried to remove all known SSIDs to enter my SSID again.
      The answer to "M558 S"*" was:
      Error: M588: Failed to reset the WiFi module to factory settings: SPI timeout
      The WiFi Module is started.
      If I try to add my SSID again:
      Error: M587: Failed to add SSID to remembered list: SPI timeout
      M122
      === Diagnostics ===␊
      RepRapFirmware for Duet 3 Mini 5+ version 3.4.0 (2022-03-15 18:59:15) running on Duet 3 Mini5plus WiFi (standalone mode)␊
      Board ID: 7LU1X-X296U-D65J0-40KML-2H03Z-RS9Y6␊
      Used output buffers: 1 of 40 (1 max)␊
      === RTOS ===␊
      Static ram: 103684␊
      Dynamic ram: 108912 of which 204 recycled␊
      Never used RAM 26056, free system stack 144 words␊
      Tasks: NETWORK(ready,7.1%,373) HEAT(notifyWait,0.0%,374) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.0%,123) MAIN(running,92.0%,464) IDLE(ready,0.0%,29) AIN(delaying,0.8%,273), total 100.0%␊
      Owned mutexes: USB(MAIN)␊
      === Platform ===␊
      Last reset 00:35:12 ago, cause: power up␊
      Last software reset details not available␊
      Error status: 0x00␊
      MCU revision 3, ADC conversions started 2112196, completed 2112194, timed out 0, errs 0␊
      Step timer max interval 744␊
      MCU temperature: min 19.4, current 25.4, max 25.9␊
      Supply voltage: min 0.4, current 0.8, max 0.8, under voltage events: 0, over voltage events: 0, power good: no␊
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/12/12, gc cycles 0␊
      Events: 0 queued, 0 completed␊
      Driver 0: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0␊
      Driver 1: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0␊
      Driver 2: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0␊
      Driver 3: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0␊
      Driver 4: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0␊
      Driver 5: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0␊
      Driver 6: ok, SG min n/a, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0, CC errors 0␊
      Date/time: 1970-01-01 00:00:00␊
      Cache data hit count 4294967295␊
      Slowest loop: 200.45ms; fastest: 0.12ms␊
      === Storage ===␊
      Free file entries: 10␊
      SD card 0 detected, interface speed: 22.5MBytes/sec␊
      SD card longest read time 3.2ms, write time 0.0ms, max retries 0␊
      === Move ===␊
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000␊
      === MainDDARing ===␊
      Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1␊
      === AuxDDARing ===␊
      === Heat ===␊
      Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0␊
      === GCodes ===␊
      Segments left: 0␊
      Movement lock held by null␊
      HTTP is idle in state(s) 0␊
      Telnet is idle in state(s) 0␊
      File is idle in state(s) 0␊
      USB is ready with "M122" in state(s) 0␊
      Aux is idle in state(s) 0␊
      Trigger is idle in state(s) 0␊
      Queue is idle in state(s) 0␊
      LCD is idle in state(s) 0␊
      SBC is idle in state(s) 0␊
      Daemon is idle in state(s) 0␊
      Aux2 is idle in state(s) 0␊
      Autopause is idle in state(s) 0␊
      Code queue is empty␊
      === CAN ===␊
      Messages queued 10561, received 0, lost 0, boc 0␊
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 10561/0/0␊
      Tx timeouts 0,0,10560,0,0,0 last cancelled message type 30 dest 127␊
      === Network ===␊
      Slowest loop: 41.89ms; fastest: 0.00ms␊
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions␊
      HTTP sessions: 0 of 8␊
      - WiFi -␊
      Network state is changingMode␊
      WiFi module is idle␊
      Failed messages: pending 0, notready 0, noresp 2␊
      Failed to get WiFi status␊
      Socket states: 0 0 0 0 0 0 0 0␊
      ok␊
      I reflashed the Firmware and tried to create a SSID based on the wifi module:
      Error: M589: Failed to configure access point parameters: SPI timeout
      Is there anything I can do?
      Wifi Module somehow bricked?
      Cheers, Chriss
        Can you try sending these commands and report back what it says?
        M552 S-1
        M552 S0
        M552 S1
        M997 S1
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @Phaedrux
          @phaedrux
          M552 S-1
          WiFi module stopped
          ok
          M552 S0
          ok
          WiFi module started
          M552 S1
          ok
          WiFi reported error: no known networks found
          WiFi module is idle
          WiFi module is idle
          WiFi module is idle
          WiFi module is idle
          WiFi module is idle
          M997 S1
          Trying to connect at 230400 baud:  success
          Erasing 4096 bytes...
          Erasing 196608 bytes...
          Uploading file...
          5% complete
          10% complete
          15% complete
          20% complete
          25% complete
          30% complete
          35% complete
          40% complete
          45% complete
          50% complete
          55% complete
          60% complete
          65% complete
          70% complete
          75% complete
          80% complete
          85% complete
          90% complete
          95% complete
          Upload successful
          ok␊
          WiFi module started
          WiFi module is idle
          WiFi module is idle
          I tried this afterwards:
          M589 S"DuetSSID" P"12344321" I192.168.0.1 C1
          And got the same error:
          Cheers, Chriss
            jay_s_uk @Chriss
            @chriss send M552 S0 before sending your wifi details with M587
            • Chrissundefined
              Chriss @jay_s_uk
              @jay_s_uk
              Still the same:
              Edit: I guessed that your M587 was a typo, M589....
              But M587 reports the same anyway....
              Cheers, Chriss
                Are you intending to set it up in access point mode or normal wireless client mode?
                https://docs.duet3d.com/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
                Can you send M588 S"*" to clear out any saved SSIDs?
                Then try sending M552 S0 and then try adding an SSID with M587.
                https://docs.duet3d.com/User_manual/Reference/Gcodes#m587-add-wifi-host-network-to-remembered-list-or-list-remembered-networks
                Do you still get the same SPI timeout error?
                Can you take some close up photos of the solder points around the wifi module?
                • Chrissundefined
                  Chriss @Phaedrux
                  @phaedrux said in Mini 5+ Wifi not working any more:
                  It should be a normal wireless client. The idea to set it in AP mode was a just to see whether I can get it somehow working.
                  ok
                  Wow, that did it somehow.... My understanding is that this is something I did in the past a couple of times without success. The Deletion reported the SPI timeout, the M587 S...... reported a ok now, the very first time and the M552 S1 did it with the wifi connection.
                  I guess that you do not need that any more after it is back working, don't you?
                  I do not understand why "M558 S"*" does report that error. Die the module be enabled for that? Or does it report that error when there is no SSID configured?
                  Cheers, Chriss
                    I'm not really sure, but I'm glad it's working now.
                    • Chrissundefined
                      Chriss @Phaedrux
                      @phaedrux
                      Me too..... that is my "firmware" and "Config test" board here on my desk. I do not need that very often but it should smoothly work if I do not it.
                      It is a bit confusing that a shutdown period of 2 month resulted in a work like that. 😞 I hope that the board remains stable now.... The board is 4-5 month old....
                      Cheers, Chriss
                        dc42 administrators @Chriss
                        @chriss I've seen "SPI timeout" messages occasionally when doing M587/588/589 operations, where the operation has actually succeeded. I think they occur when the wifi chip has to perform an erase operation on the area of flash memory used to hold the data.
