    Best Choice of Motor for a Delta Printer
    3.4k
    • ignacmcundefined
      ignacmc @bberger
      @bberger Here you have them...still a work in progress, but can be printed so far...I tried to avoid all collissions with bolt heads and so on. You have on FRONTAL part and TWO sides...If you develop them further, please share 😉
      Change extension from STL to F3D
      Enclosure IMC SIDES.stl Enclosure IMC FRONT.stl
      Predator with Duet3 Mini 5+, Smarteffector v4 and LGX Lite Extruder
      • lord binkyundefined
        lord binky
        @bberger said in Best Choice of Motor for a Delta Printer:
        Wantai 42BYGHM810
        I use the Wantai 42BYGHM810 on my delta. I don't use dampers and the motors are basically silent. I have gone through 3 different sets of dampers and after chasing every other mechanical issue I could and tuning the drivers, they very much were unnecessary and only added to ghosting. Whatever your choice if you don't have a pillow block (most printers don't) then I highly recommend putting a roller bearing between the pulley and the motor case (my current preference is the needle bearings). You have to measure the space available and account for possibly adding some washers to keep your pulley centered. What this does it reduce the tension on the motor shaft, the tension on the pulley instead is applied to the thrust bearing and motor to the motor case saving your internal motor bearings. Before I started doing this my previous motors needed replacement every 2-3 years because of bearing issues on my deltas, and I feel like it helps on ghosting and tension too (that's just an added bonus so wasn't worth testing for me).
        uxcell TC512 Thrust Needle Roller Bearings with Washers 5/16" Bore 3/4" OD 5/64" Width 5pcs
        https://www.amazon.com/gp/product/B07VZXWSG6/
        uxcell F5-10M Thrust Ball Bearings 5mm x 10mm x 4mm Chrome Steel Single Direction 4pcs
        https://www.amazon.com/gp/product/B07QKKYKR8/
        ignacmcundefined 2 Replies Last reply Reply Quote 1
        • ignacmcundefined
          ignacmc @lord binky
          @lord-binky I am afraid there is not enough space to fit a Bearing here....IMG_3188.jpg
          bbergerundefined lord binkyundefined 2 Replies Last reply Reply Quote 0
          • bbergerundefined
            bberger @ignacmc
            @ignacmc the needle bearings suggested here are super thin though.
            But yes, with the suggested tension of Gates for their belts in linear positioning applications we're at the upper end of what Nema 17 bearings usually are rated for. On my Moon's it just barely within "extended" spec (they're in the rated "can be up to this load, but expect reduced bearing life).
            Haven't looked up the Wantai specs though. I don't think that they'll be a problem in our application. At least not for the lifetime of the printer unless it's maybe running 24/7 in a farm.
            The thing with pillow blocks / bracings is: they need to be accurate or they will introduce crooked sideload themselves on the motor bearings.
            Has anyone been able to find the Wantai with a D-Shaft and connectors? That's the primary reason why I have been to lazy to switch back to them.. I know they exist as they can be ordered to spec that way, but haven't seen any retailer carrying them 😕
            • ignacmcundefined
              ignacmc @lord binky
              @lord-binky But I don't get your idea...you are recommending Thrust Bearings, that are designed to take axial loads (in the direction of the motor shaft). But the belt tension is acting perpendicular to the motor shaft, that is RADIAL loads. What is the use for a thrust bearing here? They cannot absorb any of the belt loads
              CabalSoulundefined 1 Reply Last reply Reply Quote 0
              • CabalSoulundefined
                CabalSoul @ignacmc
                @ignacmc i think what he suggests when the belts displace the motor shaft, this bearing would prevent or alleviate the displacement of the motor shaft and thus reduce strain on the motor bearings . The strongest force would be on the lower side of this flat bearing.
                I liked this idea and never thought of it before, I’ll look into that.
                I’m planning to make an automatic belt tensioner and a more sturdy motor shaft would help a lot.
                Anycubic Predator, Orbiter Extruder , Duet Wifi, Mosquito Hotend, Remote Extruder Stepper cooling and Part cooling
                ignacmcundefined 1 Reply Last reply Reply Quote 0
                • ignacmcundefined
                  ignacmc @CabalSoul
                  @cabalsoul I think that this thrust bearing only works when subject to compression. And this is only going to happen when there is a noticeable bending on the shaft which is not going to be the case (or the motor will be destroyed) ;-)...Here we have mainly a shear force and this bearing is not taking any load...Just my opinion, a photo of the setup would help me to understand it better
                  CabalSoulundefined lord binkyundefined 2 Replies Last reply Reply Quote 0
                  • tapirathundefined
                    tapirath
                    Duet documentation states that low inductance = higher speed or rather holding its torque for a wider range of speed so looking at just the spec sheet LDO one seems to be better. I've also found these motors (if you're in europe) to be good on paper too: https://www.reichelt.com/de/en/hybrid-stepper-motor-nema-17-0-9-2-4-a-2-4-v-act-17hm5424-p237911.html
                    It's both 0.9 and low inductance compared to a lot of offerings from different brands.
                      CabalSoul @ignacmc
                      @ignacmc once Ive installed a pulley flush to the stepper motor.
                      After I’ve tensioned the belts with 25N and started up I heard a grinding noise. The deflection was not noticeable with bare eyes but there was definitely one, and the pulley started grind against the motor.
                      So from my experience displacement occurs also with light loads .
                      Setup is the same as yours on the Anycubic predator.
                      The stepper motor in question was a moons ms17ha2p4200
                      https://www.moonsindustries.com/m/p/nema-17-high-precision-hybrid-stepper-motors/ms17ha2p4200-000004611110015919
                        lord binky @ignacmc
                        @ignacmc this is right, snug the pulley against the thrust bearing will limit the amount of deflection on the motor shaft. Next time you have the chance watch closely before and after tensioning motors on a delta for me the amount of force for visible deflection on the shaft is actually very little when tensioning directly against the motor (especially if you use dampers!). At the temps we are comfortable running the motors I'd wager bearing wear is in the top two motor issues after a year of use.
                          lord binky @ignacmc
                          @ignacmc
                          Ok, here's some pics. The first is an example of the setup. The others show thickness, the needle bearing you have options depending on the surface of the motor face, the ball bearing set while the ID being the same as the motor shaft is nice i prefer the needle bearings for contact area against the pulley.
                          ignacmcundefined 1 Reply Last reply Reply Quote 2
                          • ignacmcundefined
                            ignacmc @lord binky
                            @lord-binky Well you have conviced me, and I will give it a try. I have just received the Wantai 42BYGH810 I ordered a couple of weeks ago, looking a the datasheet they seem the best in class. I will have to file a flat in the shaft as they come without it. Then I will install a bearing and a pulley on top. How did you tensioned the belt to 25N? Some people use a frequency meter (Mersenne Laws), but it does not seem very accurate. Shouldn't it be a better idea to apply a 2x25=50 Newton force to the idler pulley and tighten the plate bolts in that position?
                            lord binkyundefined 1 Reply Last reply Reply Quote 0
                              lord binky @ignacmc
                              @ignacmc i just push the carriages all the way up and tension to an equal frequency using an app. I ballpark the base tension at the idler pulley for tight but not too tight and tune from there. You have a lot more wiggle room than you'd expect, just make sure they're the same.
                              I've been using deltas for years (my first was a the seemecnc rostock max v2) and I've found it isn't as necessary to hit a specific tension than it is to just maintain a reasonable and equal tension on the towers. I've done all sorts of gauges and tricks for targeting a specific tension and it just hasn't mattered. That goes for pretty much all aspects of a delta though, carriage resistance, arm lengths, rod spacing, etc. The more each tower responds the same the less weird stuff you chase and are able to compensate with a setting change in software for or identify the root cause like joints.
                              lord binkyundefined ignacmcundefined 2 Replies Last reply Reply Quote 0
                                lord binky @lord binky
                                I'll also add for me if you exclude bearing issues in motors or pulleys (I've blown the tiny bearings in idler pulleys multiple times which is why i used flanged bearings now). The next issue of high belt tension is going to be eating up the belts and teeth when your hotend or carriage eventually crashes. I think it's easy enough to tension a little more and recalibrate starting low and then go high until nothing improves.
                                • ignacmcundefined
                                  ignacmc @lord binky
                                  @lord-binky Exactly the same story for me....a Rostock Max v2 was my first delta...How many Hertz do you aim for?
