    New firmware 1.20beta1
    Firmware installation
    14
    34
    5.3k
      No, there wasn't time to do that in this beta.
      • fmaundefined
        fma
        Ok.
        Frédéric
        • frafaundefined
          frafa
          1.20beta1 perfect for me on Scara 🙂
          Scara with DuetWifi => Scarlette3D
          https://youtu.be/mBF5cO8vGhI
          • Adam_Sundefined
            Adam_S
            Briefly tested the 4-point math this AM. It seems to be far happier and actually gives realistic numbers, as opposed to previous which would be way off if things needed anything more than a marginal adjustment. Will mess with it more tonight.
            • mhackneyundefined
              mhackney
              Just updated one of my deltas. Working well so far.
              My 3D Printing blog: http://www.sublimelayers.com
              Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
              • KeeganBundefined
                KeeganB
                I also updated last night, and things are working fine.
                Artemis
                Rostock Max v2
                Orion
                  Thanks for the feedback. The only bug in 1.20 I have found so far is that if you issues the M21 or M22 command, it always reports Error in DWC even though the command succeeded. Will be fixed in next beta.
                  • Willy510undefined
                    Willy510
                    Is this the Error bug in DWC ? It keeps flashing every 5 or 10 seconds. Seems to be printing fine, just repeating the error screen over and over.
                    • krzakuundefined
                      krzaku
                      Maybe the g-code generated by your slicer repeats the wrong temperature.
                        What error screen?
                        • Willy510undefined
                          Willy510
                          @dc42:
                          What error screen?
                          Sorry should have specfic
                          The blue box in the camera feed box with the temp error.
                          Sliced in KISS using the same profile that I usually use and haven't seen this behavior before where it keeps on flashing every few seconds, but I'll check the slicer profile again to see if I changed anything
                            My guess is that you have made a mistake with your slicer settings, and as a result the Gcode file is asking to set the bed temperature to 225C instead of the hot end temperature. Look for the M140 or M190 commands in the gcode file to check this.
                            • darookeeundefined
                              darookee
                              @Willy510:
                              Is your slicer generating M117 commands on layerchange? Or anything that is not a move? Because that sounds like the problem I have that you can see here: https://www.duet3d.com/forum/thread.php?pid=26586#p26586
                              • kraegarundefined
                                kraegar
                                Working great on the RailCore. No issues at all.
                                  Thanks everyone for the feedback. Beta 1 is turning out to be very stable.
                                  • fmaundefined
                                    fma
                                    I just switched to this release yesterday, and my 2 prints worked fine.
                                    But I still have some AJAX errors (they have never been very frequent though).
                                    Frédéric
                                      @fma:
                                      Have you worked through https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors ?
                                      • fmaundefined
                                        fma
                                        Yes, but I could not improve things.
                                        As said, it does not occur very often; only during prints, but not on every print. It may be a external issue…
                                        I may try to switch to the ESP-07S (once the warranty has expired ;)).
                                        Frédéric
                                          I've added an item to that wiki page about a possible correlation with the temperature of the Duet.
                                          • fmaundefined
                                            fma
                                            Well, I have 2 big 40mm fans blowing on the Duet/Duex, triggered when CPU rises above 45°C, as you do…
                                            Frédéric
