    Only one Driver working
    620
    • Fabian Duundefined
      Fabian Du
      I have a Duet3 6HC for my Printer. Used a MKS Sbase 1.3 with external drivers before.
      I use Nema17 motors in X (2 parallel) and Y (4 parallel) and 2 Nema 34 (parallel) in Z axis.
      The printer is pretty big, thats why I need the Nema 34.
      Everything is working except the movement of the motors.
      Problem 1: X and Y Axis
      The Driver 0.1 is working fine. I can plug the X or Y axis on this Driver and they work how they should.
      So I assume my wiring of the X/Y motors is correct.
      When I decline the motor to a different driver and connect them to it and want to home/move I get the message:
      Driver 0.X warning: phase A may be disconnected, phase B may be disconnected
      This appears at all drivers I decline in the config.
      Endstops are plugged and working. Extruder motor is working as well.
      Problem 2: Z Axis
      It doesnt matter on which driver I decline the Z Axis I always get this message:
      Warning: Driver 0.2 warning: phase A short to ground, phase B short to ground, phase B may be disconnected
      Here is my config:
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon May 02 2022 14:06:34 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"FARO" ; set printer name
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X40.00 Y40.00 Z400.00 E420.00 ; set steps per mm
      M201 X500.00 Y500.00 Z16.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1600 Y1600 Z3600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S60 ; Set idle timeout
      M208 X1000 Y1000 Z1000 S0 ; set axis maxima
      M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
      M558 P0 H5 F120 T3000 ; disable Z probe but set dive height, probe speed and travel speed
      M308 S0 P"temp0" Y"thermistor" T100000 B3960 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
      M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
      You guys have any Idea what I can do to make it work?
      Thank you in advance 🙂
      Best regards,
      Fabian
      aronmeszarosundefined 1 Reply Last reply Reply Quote 0
      • oliofundefined
        oliof
        can you add high res photos of your board -- back and front, as well as the connectors for the motors?
        • aronmeszarosundefined
          aronmeszaros @Fabian Du
          @fabian-du Are you connecting the Nema 34 directly to the duet board?
            Can you send M122 and M98 P"config.g" in the gcode console and share the results here?
            When and where did you purchase the Duet?
            It's hard to tell from your description whether the drivers working or not is configuration dependant. For instance, the Z axis won't work even on a driver that did work for the X axis?
            The motors are wired in parallel? Have you tested individual motors?
              Fabian Du
              thank you for the fast respond 🙂
              Here is the M122:
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
              Board ID: 08DJM-956BA-NA3TJ-6JKF0-3S86Q-1V9GT
              Used output buffers: 1 of 40 (25 max)
              Static ram: 151000
              Dynamic ram: 95932 of which 0 recycled
              Never used RAM 103740, free system stack 206 words
              Tasks: NETWORK(ready,26.6%,251) ETHERNET(notifyWait,0.2%,168) HEAT(notifyWait,0.0%,347) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.9%,92) MAIN(running,65.3%,1087) IDLE(ready,0.0%,30), total 100.0%
              Owned mutexes:
              Last reset 00:04:11 ago, cause: power up
              Last software reset at 2022-05-02 13:15, reason: User, GCodes spinning, available RAM 103596, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Step timer max interval 126
              MCU temperature: min 42.6, current 42.9, max 43.0
              Supply voltage: min 24.5, current 24.5, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min n/a, mspos 8, reads 19616, writes 0 timeouts 0
              Driver 1: standstill, SG min n/a, mspos 8, reads 19616, writes 0 timeouts 0
              Driver 2: standstill, SG min n/a, mspos 8, reads 19617, writes 0 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 8, reads 19617, writes 0 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 8, reads 19617, writes 0 timeouts 0
              Driver 5: standstill, SG min n/a, mspos 8, reads 19616, writes 0 timeouts 0
              Date/time: 2022-05-03 09:37:30
              Slowest loop: 2.90ms; fastest: 0.05ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 2.3ms, write time 0.0ms, max retries 0
              DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty
              === CAN ===
              Messages queued 31, received 0, lost 0, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 17/0/0
              Tx timeouts 0,0,17,0,0,14 last cancelled message type 30 dest 127
              === Network ===
              Slowest loop: 1.92ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              • Ethernet -
                State: active
                Error counts: 0 0 1 0 0
              M98:
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Yes I tried to use only one motor for the X Axis on the other drivers, still only working on driver 0.1.
              I bought the duet some month ago from a german reseller CR3D. Use the duet since one week or so.
              When I use the Z motors on the working Driver 0.1 i get this message:
              Warning: Driver 0.1 warning: phase A short to Vin, phase B may be disconnected
              3.5.2022, 09:48:57 Error: Driver 0.1 error: phase A short to Vin
              Changed the steps, acceleration etc. to the suitable values for the Z axis.
              Is it even possible to run the Nema 34 with the board or do I need a extension board or something?
              Also thought about going back to the external drivers, so I will need the extension board anyway...
              Here are the pictures of the board:
                what are the specs of your nema34?
                  Fabian Du
                  Here is the data sheet of the steppers for the Z axis.
                    You'd have to put your details into the EMF calculator to see if your voltage/movement speed combo for that motor is going to work.
                    https://www.reprapfirmware.org/emf.html
                    Running the motors in parallel also complicate the matter. Have you tested them wired independently yet?
                      Fabian Du
                      i used my numbers in the tool. It should work with my specs.
                      When I use one motor its still the same problem.
                      Also tried it with a NEMA 23 motor, still not working:
                      Its so strange that only Driver 0.1 is working, also with the X/Y axis.
                      When I use the NEMA 23 with this driver, its working.
                      You think the board could be damaged or something?
                      Still its unlikely that 5 drivers are broken, no?
                        droftarts administrators @Fabian Du
                        @fabian-du This may sound silly, but check that you are connecting the motor to the correct driver on the board. The order of the drivers on the board is not intuitive:
                        You may have assumed driver 0 is next to driver 3, eg:
                        top of PCB
                        edge of PCB Driver 0 Driver 3
                        Driver 1 Driver 4
                        Driver 2 Driver 5
                        But actually driver 2 is. This would explain why driver 1 (it's in the middle) and the extruder (driver 3) works (I think you said this works?), but driver 0 and 2 don't (they are swapped).
                        Fabian Duundefined 1 Reply Last reply Reply Quote 0
                          Fabian Du @droftarts
                          @droftarts
                          yes the swapped drivers would´ve made sense.
                          But I understood the positioning right, as shown in the first picture.
                          My Z Axis with the Nema 34 motors now also works in parallel with the driver 0.1 (middle, outside of the board) with the same settings I use for X and Y.
                          So i set the same numbers for all drivers:
                          M92 X160.00 Y160.00 Z160.00 E420.00 ; set steps per mm
                          M566 X900.00 Y900.00 Z900.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; set maximum speeds (mm/min)
                          M201 X500.00 Y500.00 Z500.00 E250.00 ; set accelerations (mm/s^2)
                          M906 X1600 Y1600 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          Its still only the driver 0.1 which is working.
                          Tried to use the Z and Y Axis in driver 0.0 and 0.2 and vice versa.
                          Still the same error.
                          Since the motors are working with driver 0.1, my wiring should be right.
                          The config for all axes are also the same, so I´m pretty clueless what else I could try out.
                            Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                            • jay_s_ukundefined jay_s_uk referenced this topic
