    Cannot get Mesh Bed Compensation to work correctly
    914
    • Alijambo73undefined
      Alijambo73 @Phaedrux
      @phaedrux The weird thing is that the low spots are not always consistent. You can see that in the height map compared to the actual photo. The height map is showing the back 2 corners as the high spots but the photo shows the 2 right corners.
      I have been trying to find where the issue might be and started another bed level test print. The height map shows the front 2 cornets at Z:.22. the print is perfect on the left corner but is on the glass on the right corner. This makes me wonder if its something other than the frame but I don't have a lot of experience with this.
      I have linear rails not rods and they seem to perfectly parallel. So if its the frame it would have to be the extrusions that the y rails are mounted to on the top left and right of the frame... Correct?
      DIY-O-Sphereundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @Alijambo73
        @alijambo73
        From my own experience I can say that a original HEVO Z-axis does not work properly (and my bed is only 350x350...).The bed frame is not stiff enough. I had to constantly relevel the bed.
        I modified the connection of the linear bearings on mine.
        https://forum.duet3d.com/topic/13530/za-and-zb-connections/21?_=1651794964325
        Maybe your third z-axis makes a little difference.
        (UTC+1)
        Alijambo73undefined 1 Reply Last reply Reply Quote 1
          Alijambo73 @DIY-O-Sphere
          @diy-o-sphere Did you have the same issue with Mesh Bed Leveling and did this solve it?
          I run a g32 so the bed should technically be level so I kind of ruled that out.
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @Alijambo73
            @alijambo73 said in Cannot get Mesh Bed Compensation to work correctly:
            How did you determine that?
            Alijambo73undefined 2 Replies Last reply Reply Quote 0
              Alijambo73 @fcwilt
              This post is deleted!
                Alijambo73 @fcwilt
                @fcwilt said in Cannot get Mesh Bed Compensation to work correctly:
                By feel
                  Phaedrux Moderator @Alijambo73
                  2.235, 2.22, 2.132, 2.068, 2.027, 2.015, 1.985, 1.905 and 1.885.
                  The fact of the matter is your probe trigger height is varying quite a bit at different locations.
                  • fcwiltundefined
                    fcwilt @Alijambo73
                    By feel
                    You are making a joke?
                      I had inconsistent z movements. When the printer was moved in Z, it did not return to the previous height.
                      It was easy to measure with a gauge. This was most noticeable in the corners. The bed mechanics was always bent. After the rebuild, there are no more problems with that.
                      (UTC+1)
                      • oliofundefined
                        oliof @DIY-O-Sphere
                        It's possible that you have gantry twist which would explain the different trigger heights. In theory you could write a bed.g which adjusts the trigger height depending on location but that sounds weird.
                        To find out whether you have gantry twist it probably is best if you used a dial gauge to measure rather than feel the distance from gantry to bed. Since your gantry and rod fittings are 3d printed they allow for a bit of compliance. Adding some bushing slop and possible ovality of your rods can easily make for half of your measured differences, and a slight twist which I don't think would be visible to the naked eye or feel will not show up by moving the gantry since the compliance of the printed part will allow the mechanism to slide without interference.
                        oliofundefined 1 Reply Last reply Reply Quote 1
                        • oliofundefined
                          oliof @oliof
                          no idea why this was addressed to DIY-O-Sphere, it was supposed to go to OP of course.
