24 volt 40w hotend wiring?
@arnold_r_clark Hello Sir. I tried connecting directly to the "out0" and changed the config file but received a N/A in the DWC. When I connect to the "out1" it works fine. My bed is also connected to "out0" and functions well.
It is a very large printer and I am using large nozzle diameters with various materials, so higher nozzle temps are preferred ( I think)
Any assistance is appreciated! -
This post is deleted! -
@damaged_goods The information is all in the documentation that @Arnold_R_Clark linked to. It is specifically stated that OUT0 is intended for bed heaters with a current of up to 18A. The documentarian also says that OUT1 to 3 are intended for extruders heaters and have a current limit of 6A. Your 40 Watt heater will only draw 1.7 Amps so use any of OUT1 to OUT3 (as per the documentation).
@arnold_r_clark thanks for the advice. Since I had no electronics knowledge 2 years ago and have since built a functioning 5 foot x 5 foot x 7 foot multimaterial printer, I would say I have educated myself plenty.
I have read all those documents but was looking for some friendly help. -
@deckingman Thank you sir. I read all those documents but it was often all Greek to me. My aged brain has limited comprehension for new information these days.
My understanding is that a rated 24/40 heater cartridge will not work optimally on the 12 volt outputs 1-3. Is there a 24 volt output I can use or am I wrong?
I'm just trying to not burn the house down some days
Thanks again,
Dave -
@damaged_goods OUT 1-3 are VIN powered, I would assume you purchased a 24v heater because you use 24v as the input voltage?
@rushmere3d That is correct and my heater seemed to be struggling at higher temperatures. Are out1-3 12 volt or 24? VIN is voltage in from the power supply correct? Sorry for my ignorance, I didn't want to damage the board.
@damaged_goods out 1-3 are the same voltage as your input voltage.
What temperature are you trying to reach?
What hardware are you using exactly?
@rushmere3d duet 3 mainboard, with Prusa hot end but I may upgrade. I am hoping to have a print temp range up to 300-350. Mostly just in case.
@damaged_goods By Prusa hotend do you mean an E3D V6? If so you can't print over 300°c, 280°c to be honest with a stock one. You'd need to upgrade some of the components.
@rushmere3d that is my plan.
@rushmere3d mosquito magnum +?
@damaged_goods No experience with that, sorry.
@damaged_goods said in 24 volt 40w hotend wiring?:
If you are happy with the V6 but it's struggling to reach the temperature you want, then a 60 watt heater might be a cheaper option than buying a whole new hot end. A 60 watt heater at 24V will still only draw 2.5 amps so well within the 6 amp spec of Out 1 to 3. Alternatively have you tried fitting a silicone sock?
@deckingman But they'll still need to change at least the block and thermistor because there max temp is 300°c.
@rushmere3d said in 24 volt 40w hotend wiring?:
Really? What's the block made out of - lead or a tin/lead alloy?
I'm using humble aluminium on my 6 input multi material hot end because I know the melting point of aluminium is around 660 deg C.
@deckingman Thank you gentleman. I did just try a sock and that does help. I also built a styrofoam aluminum foil enclosure. That along with a 240 volt 2160 watt bed heater gives me a pretty stable print environment. I will upgrade the hotend when this one gives up the ghost.
@rushmere3d Thank you gentleman. I did just try a sock and that does help. I also built a styrofoam aluminum foil enclosure. That along with a 240 volt 2160 watt bed heater gives me a pretty stable print environment. I will upgrade the hotend when this one gives up the ghost.
@deckingman Just giving the same warning as E3D do on their own products.
@rushmere3d The limit is because of the supplied thermister.
