    having problems finishing one print starting next
    • codfish124undefined
      codfish124
      I have 2 printers doing strange things after finishing or canceling a print and starting the next print.
      printer 1 will not deploy BLtouch until the printer is rebooted.... if I deploy the test probe, then hit the emergency stop the probe will deploy prior to stopping and resetting.
      printer 2 finishes the print when I start the next it homes all axis then goes slightly left and lifts Z pushed plastic then moved to X Y home and pushes plastic to fast while raising Z I hit emergency stop and print the same file with no issues.
      • oliofundefined
        oliof @codfish124
        @codfish124 for the first issue, try adding M280 Px S160 to reset the probe at the beginning of your homez.g (with x being replaced by your servo number, usually this is P0).
        For your second issue this sounds like you're stuck in relative move mode after homing. Make sure to have a G90 at the end of your homing files/beginning of your gcode start section to make sure your printer is in the right mode.
        codfish124undefined 1 Reply Last reply Reply Quote 1
          For us to really understand what is going on we need to see the gcode that is actually being executed, so please share with us your config.g, homing files, slicer start and end gcode (an example sliced gcode file would be best). It would also help to know what firmware and duet you are using. Sending M122 and M98 P"config.g" in the gcode console and copy pasting it here would be good.
          codfish124undefined 1 Reply Last reply Reply Quote 0
            codfish124 @oliof
            @oliof duh!!!!
            thank seems to have fixed printer #2 thank you
              codfish124 @Phaedrux
              @phaedrux
              this one has been doing this for some time though it was wireing but I have rewired it a few times
              here is the M122
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
              Board ID: 0JD0M-9P6M2-NWNS4-7JKF0-3S46J-KV0VM
              Used output buffers: 3 of 24 (12 max)
              Static ram: 23868
              Dynamic ram: 74860 of which 0 recycled
              Never used RAM 13352, free system stack 184 words
              Tasks: NETWORK(ready,129.4%,226) HEAT(notifyWait,2.2%,332) Move(notifyWait,0.1%,364) MAIN(running,147.8%,448) IDLE(ready,1.3%,30), total 280.8%
              Owned mutexes: WiFi(NETWORK)
              Last reset 27:25:41 ago, cause: software
              Last software reset at 2022-05-03 13:49, reason: User, GCodes spinning, available RAM 13208, slot 2
              Error status: 0x00
              Step timer max interval 0
              MCU temperature: min 35.2, current 36.3, max 37.7
              Supply voltage: min 24.1, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min n/a
              Driver 1: standstill, SG min n/a
              Driver 2: standstill, SG min n/a
              Driver 3: standstill, SG min n/a
              Driver 4: standstill, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2022-05-04 17:15:28
              Slowest loop: 33.88ms; fastest: 0.19ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 26.5ms, write time 0.0ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty
              === Network ===
              Slowest loop: 15.40ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              HTTP sessions: 1 of 8
              - WiFi -
              Network state is active
              WiFi firmware version 1.26
              WiFi MAC address 98:cd:ac:20:60:d8
              WiFi Vcc 3.45, reset reason Power up
              WiFi flash size 4194304, free heap 25352
              WiFi IP address 192.168.1.31
              WiFi signal strength -66dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
              Socket states: 0 0 0 0 0 0 0 0```
              and the M98 P
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
                codfish124 @codfish124
                what else is needed this is most frustrating
