    attempting to extrude with no tool selected - SOS
    683
    • IndeX4Dundefined
      IndeX4D @Phaedrux
      @phaedrux
      tool switch = is a z prob for tools.
      I´m getting this error when selecting tool.
        I'm not exactly sure what you're trying to accomplish without more detail but the way you've got M558 setup right now isn't correct for multiple probes.
        Review the M558 wiki entry
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m558-set-z-probe-type
        You've got M558 K1 P5 commands twice. Remove one.
        The first M558 command will require a K0 to define it as the first probe. And then any time to configure or call a probe you need to specify which probe you mean to call by including K0 or K1
          Phaedrux Moderator @IndeX4D
          @index4d said in attempting to extrude with no tool selected - SOS:
          Post your tool change files as well. And your homing files.
          And can you explain the overall goal of what you're trying to do?
          • IndeX4Dundefined
            IndeX4D
            error - can´t post
            IndeX4Dundefined 1 Reply Last reply Reply Quote 1
            • IndeX4Dundefined
              IndeX4D @IndeX4D
              @index4d but I can post that there is an error... funny
                Try again.
                IndeX4Dundefined 2 Replies Last reply Reply Quote 0
                • IndeX4Dundefined
                  IndeX4D @Phaedrux
                  @phaedrux https://forum.duet3d.com/topic/24706/automatic-tool-offset-xyz-for-syringe-printer/14
                  • IndeX4Dundefined
                    IndeX4D @Phaedrux
                    @phaedrux
                    strange errors....
                    I wanted to install a tool switch like in this thread. I thougth I have to solve problem ´´ attempting with no tool......´´.
                    Before it was never a problem, I´m not sure if it´s a problem for the tool switch.
                      In that thread they used a switch as an endstop instead of another probe.
                      IndeX4Dundefined 1 Reply Last reply Reply Quote 0
                      • IndeX4Dundefined
                        IndeX4D @Phaedrux
                        @Phaedrux ok yes I know but I don´t care.
                        It´s a thing to measure the z heigth.
                          Phaedrux Moderator @Phaedrux
                          @phaedrux said in attempting to extrude with no tool selected - SOS:
                          Have you taken this post into consideration yet?
