    CONSTANT AJAX disconnect errors
    307
    55.1k
      I have reviewed the wifi server project and found an issue which could explain some of the problems you are seeing. I hope to have an updated DuetWiFiServer by tomorrow. It will be compatible with DuetWiFiFirmware 1.20beta1, so I suggest you upgrade to that (along with DuetWiFiServer 1.20alpha1) to provide a baseline.
      • KeeganBundefined
        KeeganB
        That is very exciting David! (the update)
        I just upgraded to a new router and I am still learning the GUI for it. The pings make me believe it was not connected to the router, but when going to the web GUI for the router it still showed the Duet on the connected clients list. I am inclined to not believe that though, and I may have been reading the page wrong. I will test that again next time I get a disconnect.
        EDIT: I will try to get updated the the respective 1.20 beta/alpha firmwares tonight.
        Artemis
        Rostock Max v2
        Orion
        • Jareryundefined
          Jarery
          Loaded the new software
          Firmware Version: 1.20beta1 (2017-10-02)
          WiFi Server Version: 1.20alpha1
          Web Interface Version: 1.19.3 (this dint show at first even with reboot)
          Ran well for 2 hours then disconnect, bottom line with reason not on the popup. Just the same AJAX error.
          Unable to reconnect with connect button
          M522 shows still connected to access point
          Router shows disconnected
          Unable to ping
          Reset wifi with paneldue
          M522 S0, pause, M522 S1
          Connect button reconnects.
          M122 after reconnect then shows:
          MaxReps: 12, StepErrors: 0, FreeDm: 120, MinFreeDm 120, MaxWait: 230003ms, Underruns: 0, 0
          Scheduled moves: 127412, completed moves: 127383
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is doing "G1 X-67.592 Y56.469 E0.06335" in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          Network state is running
          WiFi firmware version 1.20alpha1
          WiFi MAC address a0:20:a6:10:55:89
          WiFi Vcc 3.16, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 38816
          WiFi IP address 192.168.2.32
          WiFi signal strength -46dBm
          Reconnections 0
          HTTP sessions: 1 of 8
          Socket states: 2 0 0 0 0 0 0 0
          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          Edit: second disconnection, same print, reconnected after 2nd press of connect without having to cycle wifi module. Router showed it as not connect prior to using connect button.
          After it reconnected, a M122 showed Reconnections 1 (first time I've ever seen reconnections not be 0)
          • KeeganBundefined
            KeeganB
            @dc42:
            Thanks for that report. Net time it happens, please log on to your router and see whether it still shows the Duet as a connected client, and post the relevant bits of the M122 report again. The M122 says that the Duet is connected to the router, but I want to know whether the router agrees.
            Are you using a static IP address, or DHCP?
            This is a bit odd.
            Currently I can't load DWC.
            Pronterface shows connected to my network
            Router shows connected but access type is "wired"
            Edit:
            After running M552 S-1 and then M552 S1, the router now shows the Duet access type as "2.4G", as expected.
            I will keep an eye on this to see if it always changes to "wired" when the issues happen.
            Artemis
            Rostock Max v2
            Orion
            • MiRundefined
              MiR
              I just upgraded to 1.19.2 and I see the same issues as described in callil's comment above.
              Does it help if I do Airtraces with my Mac? If yes, should I do this with 1.19.2 or should I upgrade to 1.20 beta?
              The interesting thing I am seeing is that the duett is still associated to the AP but it is not answering to pings.
                The next DuetWiFiServer release I do will be designed to work with 1.20beta1, or possibly a later 1.20 beta release.
                • MiRundefined
                  MiR
                  I upgraded anyway, it took a little longer until I was unable to use the connection.
                  Fun thing is that I still see packet exchange between AP and duet:
                  RSSI: -40 dBm
                  TXPacketCount
                  176423
                  RXPacketCount
                  20352
                  a little later:
                  TXPacketCount
                  176799
                  RXPacketCount
                  20744
                  I can also still access station stats of the duet:
                  /cfg/system/root # wlctl -i wl0 sta_info 5C:CF:7F:37:8A:E3
                  [VER 4] STA 5C:CF:7F:37:8A:E3:
                  aid:5
                  rateset [ 1 2 5.5 6 9 11 12 18 24 36 48 54 ]
                  idle 1 seconds
                  in network 1857 seconds
                  state: AUTHENTICATED ASSOCIATED AUTHORIZED
                  flags 0x1e13a: WME PS N_CAP AMPDU AMSDU
                  HT caps 0x112c: SGI20 STBC-Rx
                  tx total pkts: 177054
                  tx total bytes: 47635359
                  tx ucast pkts: 23995
                  tx ucast bytes: 3712620
                  tx mcast/bcast pkts: 153059
                  tx mcast/bcast bytes: 43922739
                  tx failures: 1
                  rx data pkts: 21124
                  rx data bytes: 6136443
                  rx ucast pkts: 21112
                  rx ucast bytes: 6134771
                  rx mcast/bcast pkts: 12
                  rx mcast/bcast bytes: 1672
                  rate of last tx pkt: 72222 kbps - 19500 kbps
                  rate of last rx pkt: 6000 kbps
                  rx decrypt succeeds: 17064
                  rx decrypt failures: 88
                  tx data pkts retried: 0
                  per antenna rssi of last rx data frame: -47 -40 -41 0
                  per antenna average rssi of rx data frames: -46 -40 -40 0
                  per antenna noise floor: -94 -97 -96 0
                  tx total pkts sent: 23994
                  tx pkts retries: 2400
                  tx pkts retry exhausted: 1
                  tx FW total pkts sent: 64
                  tx FW pkts retries: 0
                  tx FW pkts retry exhausted: 0
                  rx total pkts retried: 2116
                  Are you able to turn of Powersave on the esp? I see in the stats that PS flag is set, I have seen numerous errors with Powersave on WiFi
                  • KeeganBundefined
                    KeeganB
                    And this is tonight's error….
                    This was loading DWC about 1 min after a fresh power up of the printer:
                    Error reason: SyntaxError: JSON Parse error: Unterminated string
                    Then after hitting refresh for the web browser I got a different error that I wasn't able to copy before it disappeared, but I think it ended in "invalid digits."
                    after M552 S-1 and S1, this is the new error:
                    Error reason: SyntaxError: JSON Parse error: Expected '}'
                    EDIT:
                    updated to all the latest firmwares from the edge GitHub, disconnects continue. That was expected, but just as an FYI for those following along.
                    Artemis
                    Rostock Max v2
                    Orion
                    • KeeganBundefined
                      KeeganB
                      Hey David,
                      Just checking in on the new firmware. I continue to have disconnects, but haven't done much or posted any further on them in the past few days.
                      Artemis
                      Rostock Max v2
                      Orion
                        I recall that some of you report that the WiFi is reliable when the printer is idle, but it disconnects a little while after printing starts, even though you are not using high microstepping. It occurs to me that this could be temperature-related. The WiFi module gets warm in normal use, and when the stepper drivers are generating heat as well it could be getting too hot to function properly. So please try the following:
                        • Monitor the CPU temperature in DWC until the point at which it disconnects. Is there a significant rise in temperature?
                        • Try cooling the Duet with a fan, if you don't already.
                        • KeeganBundefined
                          KeeganB
                          David,
                          Where in DWC can I see the board temp?
                          Thanks
                          Artemis
                          Rostock Max v2
                          Orion
                          • Dougal1957undefined
                            Dougal1957
                            on any page if you check the Temp area top left you will see an Extras label click it and the MCU temp will appears which you can add to the Line chart if you wish.
                            • Jareryundefined
                              Jarery
                              My Board is mounted above my delta, so bed heat has no effect. The board temp is low to mid 30's when no fan is used. (calibrated just yesterday its about 3 degrees below the PT100 temp)
                              Mine also disconnects while idle.
                              • KeeganBundefined
                                KeeganB
                                @Dougal1957:
                                perfect, thanks!
                                32.8C at idle after being powered on for several hours.
                                Artemis
                                Rostock Max v2
                                Orion
                                • KeeganBundefined
                                  KeeganB
                                  Over a couple different hour long prints the MCU temp stayed right around 34 C.
                                  Artemis
                                  Rostock Max v2
                                  Orion
                                    Please can those of you who are experiencing disconnect errors and are running DuetWiFiFirmware 1.20beta1 try changing the wifi firmware to version 1.20alpha1+1, which is available here: https://www.dropbox.com/s/u7vpp2wg4rlqs8l/DuetWiFiServer.bin?dl=1. Then let me know if you think it is better or worse.
                                    • Jareryundefined
                                      Jarery
                                      DuetWiFiFirmware1.20alpha1+1
                                      • Install 6:55
                                      • idle
                                      • Disconnect 7:55
                                      The log showed slightly different times. The disconnect happened at 7:55 but doesn't show on the log till 8:05. It would not connect via connect button during that time.
                                      2017-10-12 06:56:11 Event logging started
                                      2017-10-12 08:05:21 WiFi reported error: Lost connection, auto reconnecting
                                      2017-10-12 08:05:22 WiFi reported error: Auto reconnect succeeded
                                      after reconnect M122:
                                      WiFi firmware version 1.20alpha1+1
                                      WiFi flash size 4194304, free heap 38352
                                      WiFi signal strength -45dBm
                                      Reconnections 1
                                      Edit 2:
                                      Left idle it disconnected again, after waiting 30 min Im able to reconnect. Log doesn't show that it ever knew it was disconnected: The 10:10 log is me reconnecting after disconnecting 30 min or so previous
                                      2017-10-12 08:58:13 HTTP client 192.168.2.49 login succeeded
                                      2017-10-12 10:10:20 HTTP client 192.168.2.49 login succeeded
                                      • Jareryundefined
                                        Jarery
                                        First print, disconnected while printing the skirt
                                          Thanks for your feedback. Which country are you in?
                                          • Jareryundefined
                                            Jarery
                                            Canada, Vancouver BC specificaly,
