    CONSTANT AJAX disconnect errors
    307
    55.1k
      The next DuetWiFiServer release I do will be designed to work with 1.20beta1, or possibly a later 1.20 beta release.
      • MiRundefined
        MiR
        I upgraded anyway, it took a little longer until I was unable to use the connection.
        Fun thing is that I still see packet exchange between AP and duet:
        RSSI: -40 dBm
        TXPacketCount
        176423
        RXPacketCount
        20352
        a little later:
        TXPacketCount
        176799
        RXPacketCount
        20744
        I can also still access station stats of the duet:
        /cfg/system/root # wlctl -i wl0 sta_info 5C:CF:7F:37:8A:E3
        [VER 4] STA 5C:CF:7F:37:8A:E3:
        aid:5
        rateset [ 1 2 5.5 6 9 11 12 18 24 36 48 54 ]
        idle 1 seconds
        in network 1857 seconds
        state: AUTHENTICATED ASSOCIATED AUTHORIZED
        flags 0x1e13a: WME PS N_CAP AMPDU AMSDU
        HT caps 0x112c: SGI20 STBC-Rx
        tx total pkts: 177054
        tx total bytes: 47635359
        tx ucast pkts: 23995
        tx ucast bytes: 3712620
        tx mcast/bcast pkts: 153059
        tx mcast/bcast bytes: 43922739
        tx failures: 1
        rx data pkts: 21124
        rx data bytes: 6136443
        rx ucast pkts: 21112
        rx ucast bytes: 6134771
        rx mcast/bcast pkts: 12
        rx mcast/bcast bytes: 1672
        rate of last tx pkt: 72222 kbps - 19500 kbps
        rate of last rx pkt: 6000 kbps
        rx decrypt succeeds: 17064
        rx decrypt failures: 88
        tx data pkts retried: 0
        per antenna rssi of last rx data frame: -47 -40 -41 0
        per antenna average rssi of rx data frames: -46 -40 -40 0
        per antenna noise floor: -94 -97 -96 0
        tx total pkts sent: 23994
        tx pkts retries: 2400
        tx pkts retry exhausted: 1
        tx FW total pkts sent: 64
        tx FW pkts retries: 0
        tx FW pkts retry exhausted: 0
        rx total pkts retried: 2116
        Are you able to turn of Powersave on the esp? I see in the stats that PS flag is set, I have seen numerous errors with Powersave on WiFi
        • KeeganBundefined
          KeeganB
          And this is tonight's error….
          This was loading DWC about 1 min after a fresh power up of the printer:
          Error reason: SyntaxError: JSON Parse error: Unterminated string
          Then after hitting refresh for the web browser I got a different error that I wasn't able to copy before it disappeared, but I think it ended in "invalid digits."
          after M552 S-1 and S1, this is the new error:
          Error reason: SyntaxError: JSON Parse error: Expected '}'
          EDIT:
          updated to all the latest firmwares from the edge GitHub, disconnects continue. That was expected, but just as an FYI for those following along.
          Artemis
          Rostock Max v2
          Orion
          • KeeganBundefined
            KeeganB
            Hey David,
            Just checking in on the new firmware. I continue to have disconnects, but haven't done much or posted any further on them in the past few days.
            Artemis
            Rostock Max v2
            Orion
              I recall that some of you report that the WiFi is reliable when the printer is idle, but it disconnects a little while after printing starts, even though you are not using high microstepping. It occurs to me that this could be temperature-related. The WiFi module gets warm in normal use, and when the stepper drivers are generating heat as well it could be getting too hot to function properly. So please try the following:
              • Monitor the CPU temperature in DWC until the point at which it disconnects. Is there a significant rise in temperature?
              • Try cooling the Duet with a fan, if you don't already.
              • KeeganBundefined
                KeeganB
                David,
                Where in DWC can I see the board temp?
                Thanks
                Artemis
                Rostock Max v2
                Orion
                • Dougal1957undefined
                  Dougal1957
                  on any page if you check the Temp area top left you will see an Extras label click it and the MCU temp will appears which you can add to the Line chart if you wish.
                  • Jareryundefined
                    Jarery
                    My Board is mounted above my delta, so bed heat has no effect. The board temp is low to mid 30's when no fan is used. (calibrated just yesterday its about 3 degrees below the PT100 temp)
                    Mine also disconnects while idle.
                    • KeeganBundefined
                      KeeganB
                      @Dougal1957:
                      perfect, thanks!
                      32.8C at idle after being powered on for several hours.
                      Artemis
                      Rostock Max v2
                      Orion
                      • KeeganBundefined
                        KeeganB
                        Over a couple different hour long prints the MCU temp stayed right around 34 C.
                        Artemis
                        Rostock Max v2
                        Orion
                          Please can those of you who are experiencing disconnect errors and are running DuetWiFiFirmware 1.20beta1 try changing the wifi firmware to version 1.20alpha1+1, which is available here: https://www.dropbox.com/s/u7vpp2wg4rlqs8l/DuetWiFiServer.bin?dl=1. Then let me know if you think it is better or worse.
                          • Jareryundefined
                            Jarery
                            DuetWiFiFirmware1.20alpha1+1
                            • Install 6:55
                            • idle
                            • Disconnect 7:55
                            The log showed slightly different times. The disconnect happened at 7:55 but doesn't show on the log till 8:05. It would not connect via connect button during that time.
                            2017-10-12 06:56:11 Event logging started
                            2017-10-12 08:05:21 WiFi reported error: Lost connection, auto reconnecting
                            2017-10-12 08:05:22 WiFi reported error: Auto reconnect succeeded
                            after reconnect M122:
                            Network state is running
                            WiFi firmware version 1.20alpha1+1
                            WiFi MAC address a0:20:a6:10:55:89
                            WiFi Vcc 3.16, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 38352
                            WiFi IP address 192.168.2.32
                            WiFi signal strength -45dBm
                            Reconnections 1
                            HTTP sessions: 1 of 8
                            Socket states: 2 0 0 0 0 0 0 0
                            Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                            Edit 2:
                            Left idle it disconnected again, after waiting 30 min Im able to reconnect. Log doesn't show that it ever knew it was disconnected: The 10:10 log is me reconnecting after disconnecting 30 min or so previous
                            2017-10-12 08:58:13 HTTP client 192.168.2.49 login succeeded
                            2017-10-12 10:10:20 HTTP client 192.168.2.49 login succeeded
                            • Jareryundefined
                              Jarery
                              First print, disconnected while printing the skirt
                                Thanks for your feedback. Which country are you in?
                                • Jareryundefined
                                  Jarery
                                  Canada, Vancouver BC specificaly,
                                  • KeeganBundefined
                                    KeeganB
                                    Ill be away from the printer for about a week, but will updated to that new version you shared David as soon as I return.
                                    Artemis
                                    Rostock Max v2
                                    Orion
                                    • fmaundefined
                                      fma
                                      David, I juste realized that my WiFi signal strength is really low: -68dBm! I think I'm lucky it's working so well, despite such poor signal!
                                      I think I will order the new ESP module, with antenna.
                                      Frédéric
                                      • callilundefined
                                        callil
                                        Updated to alpha1+1 - pretty much the same story for me unfortunately.
                                        The following log is right after a disconnect when idle. I restarted the wifi module with M552 on device.
                                        [[language]]
                                        Used output buffers: 3 of 32 (17 max)
                                        RepRapFirmware for Duet WiFi version 1.20beta1 running on Duet WiFi 1.0
                                        Board ID: 08DAM-9K9K2-NGNSN-6JKD0-3SJ6T-15UBM
                                        Static ram used: 15128
                                        Dynamic ram used: 96048
                                        Recycled dynamic ram: 3512
                                        Stack ram used: 1352 current, 4880 maximum
                                        Never used ram: 11504
                                        Last reset 00:06:35 ago, cause: reset button or watchdog
                                        Last software reset reason: User, spinning module GCodes, available RAM 11504 bytes (slot 3)
                                        Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                                        Error status: 0
                                        Free file entries: 10
                                        SD card longest block write time: 0.0ms
                                        MCU temperature: min 41.1, current 41.6, max 42.8
                                        Supply voltage: min 24.1, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0
                                        Driver 0: stalled standstill
                                        Driver 1: stalled standstill
                                        Driver 2: stalled standstill
                                        Driver 3: standstill
                                        Driver 4: standstill
                                        Date/time: 2017-10-15 15:01:57
                                        Slowest main loop (seconds): 0.008844; fastest: 0.000033
                                        MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                        Bed compensation in use: none
                                        Bed heater = 0, chamber heater = -1
                                        Heater 0 is on, I-accum = 0.0
                                        Heater 1 is on, I-accum = 0.3
                                        Segments left: 0
                                        Movement lock held by null
                                        http is idle in state(s) 0
                                        telnet is idle in state(s) 0
                                        file is idle in state(s) 0
                                        serial is idle in state(s) 0
                                        aux is idle in state(s) 0
                                        daemon is idle in state(s) 0
                                        queue is idle in state(s) 0
                                        Code queue is empty.
                                        WiFi MAC address 5c:cf:7f:ef:4c:24
                                        WiFi Vcc 3.11, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 35064
                                        WiFi IP address 192.168.1.107
                                        WiFi signal strength -58dBm
                                        Reconnections 0
                                        • JohnOCFIIundefined
                                          JohnOCFII
                                          I've been leery of updating beyond 1.18.2 due to the frequent reports of WiFi issues. Today I decided to take the leap. The upgrade to 1.19.2 went well. Checking M122 my RSSI varied between -53 and -58 (the access point is one floor away in a wood framed house). I stayed connected from a web browser (Google Chrome from a Mac) for approximately 4 hours. During the middle of that 4 hour window was a single 90 minute print.
                                          All seemed good. Not posting to gloat - but just wanted to add some data points. My access point is an Asus router running the third party Asus-Merlin firmware.
                                          John
                                          • Jareryundefined
                                            Jarery
                                            @JohnOCFII:
                                            My setup is similar, albeit with the issues.
                                            I have an Asus AC3100 as my main router about 3m away, and an AC66U about 12m away as an access point both with same firmware version, both Merlins.
