    Extruder Motor Skipping and Inconsistent Layers
    69
    4.5k
      Are you using the E3D thermistor, or something else?
      M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 R4700
      This isn't correct for the E3D thermistor.
      Secretasianman7undefined 1 Reply Last reply Reply Quote 0
      • Secretasianman7undefined
        Secretasianman7 @Phaedrux
        @phaedrux I am using the E3D thermistor, Honestly I've been learning as I go with this duet board, I'm pretty new to tuning and tweaking a 3D printer and used the default given thermistor value from the firmware configuration tool. I absolutely could have entered incorrectly.
        I am using a 30W E3D 12v thermistor, what would be the appropriate M308 Value to input for that given thermistor?
          Try this instead M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
          • mikeabuilderundefined
            mikeabuilder
            @Secretasianman7, I think Phaedrux has you on a good track, but the typical way to test a thermistor is to put it somewhere at a known temperature. The classic method is an ice bath and boiling water. This gives two points to test at a wide temperature separation. But you can also look at the temperature reported when the printer is just turned on and neither the bed or hot end heating has started. The reported temperatures should be the same.
            • mrehorstdmdundefined
              mrehorstdmd
              The jerk and acceleration settings for the extruder look pretty low to me. I don't think that's causing your problem, but it will lead to other problems.
              Is the print cooling fan turning on during the print and cooling off the heater block or nozzle?
              • Stephen6309undefined
                Stephen6309 @Secretasianman7
                @secretasianman7 Check if the filament is feeding from the spool easily.
                  Secretasianman7 @mrehorstdmd
                  @mrehorstdmd Thanks! What kinds of jerk and acceleration settings should I be looking at entering instead? Very new to tuning and tweaking a 3D printer, so I'm very much learning as I go.
                  Both the hot-end cooling fan and part cooling fan are turning on during printing.
                    @phaedrux Just tried the new thermistor M308 parameter, and ran another pid tune, still having the same issue. If I put my fingers on the filament as Its being fed, I can feel almost like a bump or a jolt every time it skips and doesn't lay down filament. Could it be something in my slicer profile? I'm using PrusaSlicer with the MK2S profile. I've attached a few pics to show what's happening. IMG_20220517_154315.jpg IMG_20220517_154243.jpg
                      Does it extrude cleanly into free air if you just use DWC to heat the hotend and use the extrude buttons?
                        @phaedrux Just tested, it does not extrude cleanly into air when extruding from DWC. Also, when extruding into air, as the motor skips, I can make it skip a bit less by pushing on the filament with my fingers, but that doesn't cure the problem entirely.
                        • jens55undefined
                          jens55
                          Looking at the print sample, it looks like the gap between bed and nozzle is excessive. This can cause exactly the kind of horrible mess you see here. Of course the 'not extruding cleanly into air' also doesn't help.
                            Secretasianman7 @jens55
                            @jens55 Nozzle height could definitely do with an adjustment, but I'd like to see good extrusion first.
                            • jens55undefined
                              jens55 @Secretasianman7
                              @secretasianman7, yeah, the bit about the motor still skipping and skipping less if you push on the filament is a great big red flag.
                                @jens55 Agreed. Feeling very perplexed about the root cause as I've changed out nozzles multiple times, and swapped out the entire hotend, thermistor, heater cartridge and stepper motor to no effect. Quite a strange problem...
                                  Phaedrux Moderator @Secretasianman7
                                  @secretasianman7 said in Extruder Motor Skipping and Inconsistent Layers:
                                  Swapped extruder motors to test if bad stepper. Also changed from a 1amp stepper to 1.5amp stepper to test if underpowered stepper.
                                  So you had the problem before you swapped the extruder motor as well?
                                    @phaedrux Yes. The perplexing nature of this problem is that it has persisted across multiple motors, drivers, nozzles and hotends. Also across multiple filaments, all PLA.
                                      Extruder tension problem?
                                      Secretasianman7undefined 2 Replies Last reply Reply Quote 0
                                        @phaedrux tried extruder tension in between all levels from very tight to minimal tension. Problem persists
                                          @phaedrux I'm running firmware version 3.4, any chance that either rolling back to a previous version or trying out 3.4.1 would affect things at all?
                                            mrehorstdmd
                                            Try disabling the print cooling fan in the slicer and see if the problem persists.
                                            I'm using extruder acceleration of 3000 mm/sec, and extruder jerk speed of 50 mm/sec. You don't want either set too low because if the extruder can't keep up with the printing speed, the controller will limit the printing speed to values that the extruder can keep up with.
