    Network discovery
    Using Duet Controllers
    network discovery broadcast code
    • Furbyhaxxundefined
      Furbyhaxx
      Does the duet firmware provides a method for discovering all duets (incl. their IP's) in a network?
      Stephen6309undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        It's going to depend on your Duet.
        https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking
        The assumption is that if you're setting up the Duet from scratch you are also in control of the network, so you're either assigning a static IP or DHCP reservation.
        At one point there was a phone application that would find Duets on the network. But I can't seem to find anything about that right now.
        • Stephen6309undefined
          Stephen6309 @Furbyhaxx
          @furbyhaxx I use the freeware 'Advanced IP Scanner' to find them.
          You can also use PrinterName.local, where PrinterName is the name you gave the printer using M550.
            jay_s_uk @Furbyhaxx
            @furbyhaxx i use fing https://www.fing.com/products/fing-desktop
            • gloomyandyundefined
              gloomyandy
              If you are using a WiFi version then it will create an mdns entry (for <printername>.local) that will have an extra txt record with "product" set to "DuetWiFi". I'm pretty sure the app that @Phaedrux mentioned uses that to locate Duets. The app is called "findmyduet" and a google search throws up a few hits, including this one: https://github.com/Duet3D/FindMyDuet
                Furbyhaxx
                I hoped that the firmware offers such functionality, as even crappy flashforge firmware does. But the mdns approach is a good starti g point.
                As I'm writing a centralized 3D printer monitoring and management application that not only works with Duet's. Such functionality would be good.
                • chrishammundefined
                  chrishamm administrators @Furbyhaxx
                  @furbyhaxx We support mDNS, you should be able to use that.
                  Duet boards (both in SBC and standalone mode) announce the "product" property which always starts with "Duet".
                  Duet software engineer
