duet wifi firmware 2.05 triggers not working
Using Duet Controllers
435
    martin7404
    I am trying to set external trigger on duet wifi using M581.
    In the config.g line is
    M581 E1 T3 S1 C0
    I am triggering a button connected to E1 end-stop and the LES on the board is lit, but no action.
    When I try M582 T3 from console it runs the trigger3.g file , BUT it run's it every time no mater if the button is on or of and the LED lit or not ?
    Any help please
    P.S the machine have only 1 axis Z , with external driver , no heaters , not tools, no othe axis defined
    Muldex IDEX Duet2+Duex5
    Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
    Sapphire Pro with Duet2, with closed-loop motors
    custom high temp E3D tool changer with Duet2+Duex
    undefined 1 Reply Last reply 18 May 2022, 17:28 Reply Quote 0
      alankilian @martin7404
      @martin7404 According to the M581 description:
      Any trigger number # greater than 1 causes the macro file sys/trigger#.g
      So your file should be called trigger3.g not trigger.g
      Maybe that will help.
      undefined 1 Reply Last reply 18 May 2022, 17:46 Reply Quote 0
        martin7404 @alankilian
        @alankilian ohh sorry my tipo yes indeed it is called trigger3.g
          What do you have in the trigger file?
          Why still 2.05?
          undefined 1 Reply Last reply 19 May 2022, 04:57 Reply Quote 0
            martin7404 @Phaedrux
            @phaedrux yes I have trigger3.g
            I posted it yesterday in the wrong thread.
              This?
              ;G4 S0.5
              G92 Z8
              G90 G1 Z1 F10000
              G1 Z-2 F100
              G1 Z-1 F6000
              G1 Z-3 F100
              G1 Z-2.5 F6000
              G1 Z-4 F100
              G1 Z-3.5 F6000
              G1 Z-5 F100
              G1 Z-4.5 F6000
              G1 Z-6 F100
              G1 Z-5.5 F6000
              G1 Z-7 F100
              G1 Z-6.5 F6000
              G1 Z-8 F100
              G1 Z-7.5 F6000
              G1 Z-9 F100
              G1 Z-8.5 F6000
              G1 Z-10 F100
              G1 Z-9.5 F6000
              G1 Z-11 F100
              G1 Z-10.5 F6000
              G1 Z-12 F100
              G1 Z-11.5 F6000
              G1 Z-13 F100
              ;G1 Z-12.5 F6000
              ;1 Z-13 F100
              G1 Z8 F5000
              undefined 1 Reply Last reply 19 May 2022, 05:30 Reply Quote 0
                @phaedrux yes
                undefined 1 Reply Last reply 19 May 2022, 05:37 Reply Quote 0
                  fcwilt @martin7404
                  @martin7404
                  Does the LED on the board change state as you push the button?
                  undefined 1 Reply Last reply 19 May 2022, 05:40 Reply Quote 0
                    martin7404 @fcwilt
                    @fcwilt YES
                    undefined 1 Reply Last reply 19 May 2022, 08:23 Reply Quote 0
                      fcwilt @martin7404
                      @martin7404 said in duet wifi firmware 2.05 triggers not working:
                      @fcwilt YES
                      And you verified that the button is connected to the E1 endstop and the LED that is changing is for the E1 endstop?
                      Perhaps the documentation for M582 is wrong and it runs the trigger regardless of input state. Notice for v3 firmware there is an option to control this.
                      undefined 1 Reply Last reply 19 May 2022, 16:14 Reply Quote 0
                        martin7404 @fcwilt
                        @fcwilt So I switched to 3.1.1 and it is working. Now I have to upgrade and rewire the other duet wifi
                        Thank you all
                        undefined 1 Reply Last reply 19 May 2022, 16:45 Reply Quote 0
                          fcwilt @martin7404
                          Thank you all
                          Glad to hear it is working.
                          Since you upgraded to 3.1.1 you might as well now upgrade to 3.3.0 or perhaps 3.4.x.
                          undefined 1 Reply Last reply 19 May 2022, 18:41 Reply Quote 0
                            martin7404 @fcwilt
                            @fcwilt i am on 3.4 on my printers, but this is just custom drilling automat with 5 axis and 2 spondles with VFD, if it is working it is good enough
                            8 out of 13
