Print quits, moves to home mid print
@jackson-0 said in Print quits, moves to home mid print:
"Warning. IP 192.168.0.2 requested file 'MEowSDBGMEQwQjAJBgUr...' from HTTP server, possibly a virus attack" - not sure if this is something interrupting it?
This is resolved in 3.4.1rc1
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.1rc1
May want to see if Modix recommends updating or not yet.
I did install a crash detector recently
What do you mean by crash detector?
@phaedrux It was an inductive sensor and thumbscrew from Modix that attaches between the frame and bed. When I set it up and test it, if the two came in contact, it stopped the printer and showed "halted" in the status. I'm not getting that message now, and it shouldn't have been able to trigger anyways.
That looks like it would be used as an endstop for homing the printer. Likely unrelated.
@jackson-0 Got it. Can't think of any other sensor/hardware that would have made it autopause. I'll ask Modix about updating to 3.4.1.
Filament runout sensor?
@jackson-0 The M122 indicates a pause with a bit about doing T-1 and running a macro. Is there a tool change at the point where the printer stops by any chance? If so, the culprit might be in a tool change macro. IIRC, T-1 will disable to the current tool.
@deckingman said in Print quits, moves to home mid print:
I thought so too, but at least in the gcode files shared there are no T-1 commands.
@deckingman @phaedrux Sorry for the delay in response - got in touch again with Modix. They found a couple other similar cases and recommended upgrading to 3.4 firmware. I've started the print again and all seems to be going well so far. I don't think there should be any tool change. We have a secondary extruder setup, but it is not in use.
@phaedrux Alright, it just paused again. At least resume seems to work now, but according to the console, it's now pausing due to "Filament error on extruder 0: tooLittleMovement". Maybe the nozzle needs to be cleaned out or it should be printing at higher temp?
You'll probably need to do some calibration.
