    First cut success - with questions!
    Duet Web Control
    8
    66
    3.5k
    • Nightowlundefined
      Nightowl @fcwilt
      That's very kind @fcwilt, but please don't let this spoil your evening.
      I've given up for the evening, anyway 👍 😴
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      • JoergS5undefined
        JoergS5 @o_lampe
        @Nightowl999 said in First cut success - with questions!:
        userPosition is already higher than (max-5)? Would it try to move +5 anyways and hit the upper limit or stop automatically at max?
        getting the "Error: G0/G1: target position outside machine limits", which
        The firmware is strict for laser/CNC mode to stop with the error if the target is not reachable. This is different to 3D printer mode, where it prints the adjusted range.*)
        If your X and Y ranges are ok, then maybe the program wants to lift Z more than the M208 upper limit of 100. To analyse, the line which produces the error should be identified and the current position from M114 Count value and M92 setting.
        *) for someone who is interested in the code: GCodes.cpp
        	case LimitPositionResult::adjusted:
        	case LimitPositionResult::adjustedAndIntermediateUnreachable:
        		if (machineType != MachineType::fff)
        			err = "G0/G1: target position outside machine limits";		// it's a laser or CNC so this is a definite error
        			return true;
        		ToolOffsetInverseTransform(moveState.coords, moveState.currentUserPosition);	// make sure the limits are reflected in the user position
        		if (lp == LimitPositionResult::adjusted)
        			break;														// we can reach the intermediate positions, so nothing more to do
        		// no break
        adjusted stops for laser/CNC, but is accepted for 3D printers.
        Nightowlundefined 1 Reply Last reply Reply Quote 0
        • Nightowlundefined
          Nightowl @JoergS5
          I wouldn't know the first thing about code, @joergs5, but I'll take a look at the Z height.
          If it's relevant, the Z axis configuration sets the physical drive for Z as 'backwards'...
          M569 P0.3 S0 ; physical drive 0.3 goes backwards - Z axis
          ...with the Z minima/maxima set at 0/100.
          I'm not sure I fully understand what you're suggesting, but I'd be happy to run the code, if you could tell me exactly how!
          Vielen dank.
          • JoergS5undefined
            JoergS5 @Nightowl
            @nightowl999 the first thing would be to find the line which produces the first error message and then proceeding the lines before and then
            • run M114 and notify the Count values (the first being X position, second y, third Z)
            • then tell me the count value and M92 and the G0/G1 command which fails. I'll tell you how to calculate and hope to give you an answer for the error
            • if you want to verify homing, please home and after homing, run M114 and notify count values as well
            To avoid ruining your workpieces, there is a simulation mode which should be possible to use. I didn't use it before, so just an idea. M37, but I don't know it, but maybe valuable to find the error line.
            Nightowlundefined 2 Replies Last reply Reply Quote 0
            • Nightowlundefined
              Nightowl @JoergS5
              @JoergS5 Thank you.
              Before homing, M114 reports the following:
              X:0.000 Y:0.000 Z:0.000 E:0.000 Count 0 0 0 Machine 0.000 0.000 0.000 Bed comp 0.000
              Just a moment, and I'll home it...
              • Nightowlundefined
                Nightowl @JoergS5
                @JoergS5
                After homing, it's:
                X:547.000 Y:784.000 Z:97.000 E:0.000 Count 218800 313600 38800 Machine 547.000 784.000 97.000 Bed comp 0.000
                • JoergS5undefined
                  JoergS5 @Nightowl
                  @nightowl999 said in First cut success - with questions!:
                  @JoergS5
                  After homing, it's:
                  The 218800 is a value from your M92 setting and the homing position. What is your M92 setting, please?
                  Nightowlundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                  • Nightowlundefined
                    Nightowl @JoergS5
                    @joergs5 All axes are set at 400 steps per mm
                    • JoergS5undefined
                      JoergS5 @JoergS5
                      @joergs5 ok, I think it's 218800/547 = 400.
                      This means, for every mm your router moves, the Count value for X will be incremented by 400. So you can always see where the firmware thinks that your router is.
                      Now before you start the error G0/G1 move, you can make a M114 and know where the router is. (of course the G1 before will be this position also in most cases, but to be sure...).
                      NB the values being all 0 at the beginning is, because firmware doesn't know where your steppers are at the beginning. This is what homing is meant for: telling the firmware where the stepper's positions are. The only reason why the firmware Count values and true stepper position may vary is if there are lost steps (M122 hiccups hight numbers will tell you).
                      • JoergS5undefined
                        JoergS5 @Nightowl
                        @nightowl999
                        547 * 400 = 218800
                        784 * 400 = 313600
                        97 * 400 = 38800
                        or other round, from the Count value divide by your M92 (400) and you'll get the current mm position.
                        • Nightowlundefined
                          Nightowl @JoergS5
                          @JoergS5
                          Should I move the axes to the Work XYZ first, set Work XYZ, then run M114?
                          • JoergS5undefined
                            JoergS5 @Nightowl
                            @JoergS5
                            Should I move the axes to the Work XYZ first, then run M114?
                            My proposal would be to move to the last position which is ok. Then make a M114 and notify the Count values, then verify that the next command throws an error.
                            • Nightowlundefined
                              Nightowl @JoergS5
                              @joergs5 Sorry, I edited the question as you answered...
                              I've now placed the spindle at the Work XYZ (without the cutter installed!) so should I set Work XYZ then run M114?
                              • Nightowlundefined
                                Nightowl
                                M114 before setting Work XYZ...
                                X:37.000 Y:204.000 Z:85.000 E:0.000 Count 14800 81600 34000 Machine 37.000 204.000 85.000 Bed comp 0.000
                                Some more information:
                                Since installing the spoil board, my Z height has reduced to 75mm, but I haven't changed it in the config.g file yet.
                                M114 after setting Work XYZ...
                                X:0.000 Y:0.000 Z:0.000 E:0.000 Count 14800 81600 34000 Machine 37.000 204.000 85.000 Bed comp 0.000
                                • JoergS5undefined
                                  JoergS5 @Nightowl
                                  Interesting! I was not sure, whether it will be corrected or not.
                                  So work change (did you make it by G54?) doesn't change the count values.
                                  I've learned here something also!
                                  XYZ are the values from the work XYZ view, and the Machine coordinates behind are the true original coordinates.
                                  • Nightowlundefined
                                    Nightowl @JoergS5
                                    @joergs5
                                    I just clicked the Work XYZ button on the Dashboard. I don't know anything about G54??
                                    • Nightowlundefined
                                      Nightowl @JoergS5
                                      @joergs5
                                      The workzero.g file has the following lines:
                                      ; workzero.g
                                      ; G90 ; set to absolute positioning
                                      G53 G1 Z{move.axes[2].max} F1500 ; raise the Z to the highest position
                                      G1 X0 Y0 F2400 ; go directly above the work zero position
                                      G1 Z0 F2400 ; go to the work Z zero position
                                      • JoergS5undefined
                                        JoergS5 @Nightowl
                                        @joergs5
                                        I think it's not so important now, we want to find the reason for the error message.
                                        One possible reason could be that the M208 limits take the XYZ values. But let's verify by you searching for the first error G0/G1.
                                        • Nightowlundefined
                                          Nightowl @JoergS5
                                          @joergs5 OK. Shall I load and run the file?
                                          Actually, what I did was upload the gcode file, then right-clicked it and simulated the project, with these results:
                                          21/05/2022, 19:54:21 File 0:/gcodes/102 Avalon Pocket_1-102 Avalon Pocket.gcode will print in 0h 14m plus heating time
                                          21/05/2022, 19:54:19 M37 P"0:/gcodes/102 Avalon Pocket_1-102 Avalon Pocket.gcode"
                                          Simulating print of file 0:/gcodes/102 Avalon Pocket_1-102 Avalon Pocket.gcode
                                          • JoergS5undefined
                                            JoergS5 @Nightowl
                                            G53
                                            G53 is to clear coordinate changes and not using any machine coordinates, so I would not run it.
                                            https://duet3d.dozuki.com/Wiki/Gcode#Section_G53_Use_machine_coordinates
                                            There should be G54 to G59 somewhere else, probably in your Cut2D software.
                                            The problem now is that I don't know your software and which commands are run. I can only help to find out the reason why there is the G0/G1 error message.
