CNC Pause and Resume config files
Gcode meta commands
1.6k
    Nightowl
    I've had a lot of success, thanks to several people on this forum, tweaking the standard 3D printer pause and resume config files to be more suitable for CNC use, but I've come across a bit a glitch.
    The pause.g file appears to function correctly, but I get this error when I resume from the pause, the end result being the spindle speed isn't 'saved':
    Error: in file macro line 2 column 4: meta command: unknown value 'currentTool'
    These are the files:
    ;pause.g
    G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)}
    if currentTool >= 0 & tools[state.currentTool].spindle >= 0
    set global.savedSpindleSpeed = tools[state.currentTool].spindleRpm ; save current spindle speed
    G1 X273.5 Y560 ; go to a safe place
    M5 ; turn the spindle off
    echo "Spindle speed saved at " ^ { global.savedSpindleSpeed } ^ " RPM"
    ; resume.g
    M3 S{global.savedSpindleSpeed} ; resume saved spindle speed
    G4 S1 ; pause to allow the spindle to reach saved speed
    G1 R1 X0 Y0 F2400 ; go to above the paused XY position, keeping current Z
    I'm guessing the savedSpindleSpeed hasn't actually been saved because the system either doesn't recognise 'currentTool', I've got a typo somewhere or the tool configuration is wrong.
    Are there reference pages I could look at to try my own troubleshooting, please - unless someone sees something I haven't?
    Thank you.
    Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
    I'm still on my learning curve, so take everything I say with caution!
    RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
    undefined 1 Reply Last reply 25 May 2022, 16:37 Reply Quote 0
      dc42 administrators @Nightowl
      @nightowl999 in both files you gave used both "currentTool" (which is wrong) and "state.currentTool" (which is correct).
      undefined 1 Reply Last reply 25 May 2022, 16:44 Reply Quote 0
        Nightowl @dc42
        @dc42 Aha!
        So "currentTool" should be replaced with "state.currentTool"?
        Thank you!
        undefined 1 Reply Last reply 25 May 2022, 17:40 Reply Quote 0
          Nightowl @Nightowl
          So I've made the changes you suggested, @dc42, but the spindle speed is not saved correctly. The first notification I get is the spindle speed is saved at 0RPM
          The second thing is that, on resume, the spindle doesn't start up again. This may be related, of course.
          These are my files now...
          ; pause.g
          G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} ; move the Z axis to a safe height
          if state.currentTool >= 0 & tools[state.currentTool].spindle >= 0
          G1 X273.5 Y560 F2400 ; move XY to a safe place
          echo "Spindle speed saved at " ^ { global.savedSpindleSpeed } ^ "RPM"
          ; resume.g
          G4 S1 ; wait 1 second to allow the spindle to spin up
          echo "Spindle speed resumed at " ^ { global.savedSpindleSpeed } ^ "RPM"
          G1 R1 X0 Y0 F2400 ; go above the paused XY position
          Could you also tell me how to post these in the black boxes with pretty coloured text, too? I feel I'm demonstrating my ignorance every time I post code this way! 😊
          PS I'm going to change the echo lines shortly 👍
          undefined undefined 2 Replies Last reply 25 May 2022, 19:59 Reply Quote 0
            @nightowl999 have you declared the savedSpindleSpeed variable in config.g, like this?
            global savedSpindleSpeed = 0
            Also, if you temporarily remove the M5 command from pause.g does the spindle continue to run?
            undefined 2 Replies Last reply 25 May 2022, 22:51 Reply Quote 0
              Nightowl @dc42
              @dc42 said in CNC Pause and Resume config files:
              Exactly like that, yes, and way down the file, as you suggested.
              I'll check that tomorrow and let you know.
              Thank you
                Nightowl @dc42
                @dc42 A bit of an update...
                With the M5 command disabled, the spindle continues to run.
                In the DWC, the Current RPM is shown as 10,000rpm but the Set RPM is 18,000rpm.
                The first lines of code within the gcode file are...
                1 ; VECTRIC POST REVISION
                2 ; A long string of random letters and numbers
                3 T1
                4 G17
                5 G21
                6 G90
                7 G0Z5.090
                8 G0X0.000Y0.000
                9 M3P0S18000
                ... and so on
                When I click Pause, I get this in the Console:
                26/05/2022, 12:20:07 Printing paused at X155.3 Y188.6 Z66.0
                26/05/2022, 12:19:56 Spindle speed saved at 0 RPM
                26/05/2022, 12:19:54 M25
                Resume state saved
                Thank you
                  OwenD @Nightowl
                  @nightowl999 said in CNC Pause and Resume config files:
                  ; resume.g
                  This won't resolve to true because you have a couple of errors
                  Try
                  if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                  undefined 1 Reply Last reply 27 May 2022, 18:28 Reply Quote 1
                    Nightowl @OwenD
                    @owend Whoops, sorry. I kinda progressed this in the other thread you've responded to 😊
                    Thank you, anyway 👍
                    undefined 1 Reply Last reply 27 May 2022, 18:45 Reply Quote 0
                      OwenD @Nightowl
                      @nightowl999
                      Probably better to keep this here as it's more specific than the other thread as it's become messy.
                      I'm not really familiar with all requirements of CNC mode but it may be prudent to do some more checks in your macro.
                      Also I note that there are some other spindle related object model values.
                      These might help trace what's going on
                      ; first ensure we have an active tool
                      if state.currentTool =-1
                      echo "No tool active. Selecting tool zero"
                      T0 ; select tool zero
                      echo "Spindle state on tool " , state.currentTool , " is " , spindles[state.currentTool].active
                      echo "Spindle speed resumed at ", spindles[state.currentTool].active, "RPM" ; this should show that the setting was successful
                      G1 R1 X0 Y0 F2400
                      else
                      echo "condition not met. Spindle speed remains at " , tools[state.currentTool].spindleRpm , "RPM"
                      EDIT
                      I noticed an error here. Code amended above
                      echo "Spindle speed resumed at ", spindles[].active, "RPM"
                      undefined 1 Reply Last reply 27 May 2022, 19:03 Reply Quote 0
                        Nightowl @OwenD
                        @owend This is the text from the console after changing the resume.g file...
                        27/05/2022, 20:02:40 M0
                        Printing paused at X125.6 Y125.8 Z65.0
                        Cancelled printing file 0:/gcodes/Calibration Toolpath.gcode, print time was 0h 0m
                        27/05/2022, 20:02:27 Spindle speed saved at 0 RPM
                        27/05/2022, 20:02:24 M25
                        Resume state saved
                        27/05/2022, 20:02:22 Printing resumed
                        27/05/2022, 20:02:09 Spindle speed resumed at 0 RPM
                        27/05/2022, 20:02:09 M24
                        Spindle state on tool 0 is 5000
                        27/05/2022, 20:02:00 Printing paused at X128.8 Y122.6 Z66.0
                        27/05/2022, 20:01:47 Spindle speed saved at 0 RPM
                        27/05/2022, 20:01:46 M25
                        Resume state saved
                        27/05/2022, 20:01:29 M32 "0:/gcodes/Calibration Toolpath.gcode"
                        File 0:/gcodes/Calibration Toolpath.gcode selected for printing
                        undefined 1 Reply Last reply 27 May 2022, 19:17 Reply Quote 0
                          OwenD @Nightowl
                          @nightowl999
                          OK,
                          We are getting close.
                          It seems there is no tool selected after the pause.
                          If you have multiple tools then it may be necessary to record which was selected.
                          I made a small error on one part that didn't give me the value I wanted in one of tehechos.
                          Please change both files
                          ; pause.g
                          else
                          echo "condition not met - Tool is ", state.currentTool, " Spindle RPM is ", tools[state.currentTool].spindleRpm
                          and
                          resume.g
                          echo "Spindle state on tool " , state.currentTool , " is " , spindles[state.currentTool].state
                          G1 R1 X0 Y0 F2400
                          else
                          EDIT:
                          Apologies.
                          I got the indenting on pause.g all wrong. (lack of sleep). Corrected above
                          undefined 1 Reply Last reply 27 May 2022, 19:27 Reply Quote 0
                            Nightowl @OwenD
                            @owend I'm happy to leave this for now, if you need to get some beauty sleep!
                            Here's the console text:
                            27/05/2022, 20:25:40 M0
                            27/05/2022, 20:25:27 Printing paused at X128.8 Y122.6 Z66.0
                            27/05/2022, 20:25:26 Error: in file macro line 20 column 81: meta command: array index out of bounds
                            27/05/2022, 20:25:24 M25
                            Resume state saved
                            27/05/2022, 20:25:19 M32 "0:/gcodes/Calibration Toolpath.gcode"
                            PS You have nothing to apologise for!
                            undefined 1 Reply Last reply 27 May 2022, 19:36 Reply Quote 0
                              OwenD @Nightowl
                              @nightowl999
                              All good.
                              Can you try this pause.g
                              I can't understand the index out of bounds if there's a tool selected.
                              There is no line 20, but you're probably getting extra carriage returns when copy/pasting
                              ; pause.g
                              if state.currentTool = -1
                              echo "No tool selected"
                              {if state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                              else
                              undefined 3 Replies Last reply 27 May 2022, 19:38 Reply Quote 0
                                Nightowl @OwenD
                                @owend Doing that now, but I REMd out the other lines, so that's why there's a line 20.
                                Not any more, though!
                                  Nightowl @OwenD
                                  @owend Here you go...
                                  27/05/2022, 20:38:47 M0
                                  27/05/2022, 20:38:33 Printing paused at X128.8 Y122.6 Z66.0
                                  27/05/2022, 20:38:32 No tool selected
                                  Error: Bad command: {if state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                                  Error: in file macro line 6 column 36: meta command: array index out of bounds
                                  27/05/2022, 20:38:30 M25
                                  Resume state saved
                                  27/05/2022, 20:38:24 M32 "0:/gcodes/Calibration Toolpath.gcode"
                                    Nightowl @OwenD
                                    @owend Should the wriggly brackets be after the second "if"?
                                    I changed it anyway, and now get this in the Console:
                                    27/05/2022, 20:46:49 M0
                                    27/05/2022, 20:46:44 Printing paused at X125.6 Y125.8 Z66.0
                                    27/05/2022, 20:46:43 No tool selected
                                    Error: in file macro line 11 column 81: meta command: array index out of bounds
                                    27/05/2022, 20:46:40 M25
                                    Resume state saved
                                    27/05/2022, 20:46:35 M32 "0:/gcodes/Calibration Toolpath.gcode"
                                    BTW, when I click pause, the spinde keeps running and the XY stays where it is, not returning to the safe XY.
                                    undefined 1 Reply Last reply 27 May 2022, 19:49 Reply Quote 0
                                      OwenD @Nightowl
                                      Yes, I thought I corrected that.
                                      But now it's clear there's no tool selected when you are pausing.
                                      Therefore none of the subsequent code can work as it relies on a tool being selected.
                                      Is this a real job, or a dummy one?
                                      I'm willing to bet this would work (if I haven't mage any syntax errors LOL)
                                      ; pause.g
                                      echo "No tool selected - selecting tool zero"
                                      T0
                                      else
                                      EDIT
                                      If this works then we need to know how many tools you have.
                                      undefined 1 Reply Last reply 27 May 2022, 19:50 Reply Quote 1
                                        Nightowl @OwenD
                                        @owend I'll try it, but I'm aware you're tired (as am I!)
                                        undefined 1 Reply Last reply 27 May 2022, 19:53 Reply Quote 0
                                          OwenD @Nightowl
                                          It's 5:51 AM here. I'm tired because I woke at 3am and couldn't get back to sleep 😧
                                          Try it when you can and report back.
                                          undefined 2 Replies Last reply 27 May 2022, 19:54 Reply Quote 1
                                          1 out of 44
