    NEED HELP please
    3.3k
    • CaysonPundefined
      CaysonP
      "Identify the COM port number or port name of the PanelDue board on your PC. If you use Windows, you can do this via Start->Control Panel->System->Device Manager. Expand Ports (COM and LPT), and look for Bossa port. Make a note of the port number. If you can’t find the port, try repeating the Erase and Reset sequence, or disconnecting and reconnecting the USB cable, or try a different USB port on your computer. Note: the port number of the Bossa port for PanelDue will not be the same as the one you use when uploading firmware to Duet electronics.
      Use bossac to program the board. Under Windows, open a command prompt and use this command:
      bossac.exe –port=COM9 -e -w -v -b PanelDueFirmware.bin
      Replace COM9 in this command by the COM port number you found, and PanelDueFirmware.bin by the path to your downloaded firmware file. It is possible to use the interactive version (Bossa) instead of bossac, but if you do then you must check the Erase All, Lock, and Boot from Flash boxes."
      This is where it did not continue to cooperate. the command did not go through. here is what it said,
      C:\Users\CCWCF>bossac.exe --port=COM9 -e -w -v -b PanelDueFirmware.bin
      'bossac.exe' is not recognized as an internal or external command,
      operable program or batch file.
        Assuming you have already downloaded and installed Bossa as described in the instructions, you probably need to specify the path to bossac.exe, for example use "C:\Program Files\BOSSA\bossac.exe" (including the quotation marks) at the start of the command line instead of just bossac.exe.
        • CaysonPundefined
          CaysonP
          I have tried that… i am not smart in this area.
          I am willing to ship this board and screen back, and re-order and i will make sure i DON'T touch the erase button.
          That will be easier for me as i do not understand these instructions.
          unless there is another way or its something simple im not understanding correctly.
          I am not in anyway frustrated or upset at Duet.
          • elmoretundefined
            elmoret
            You have to be in the correct directory (the directory with bossac.exe and PanelDueFirmware.bin) before running the command.
            Could you post a screenshot of your attempt, then I can point out what's wrong?
            • CaysonPundefined
              CaysonP
              How do i post a picture. when i click image i get this. [ img]
              I tired dragging and dropping. copy paste.
              • elmoretundefined
                elmoret
                Upload the image to an image host, such as imgur.
                Place the URL inside of the img tags, like this:
                [ img]https://i.imgur.com/v6jkSLc.jpg[/ img]
                Except without the space before the img in each tag.
                • CaysonPundefined
                  CaysonP
                  Thank you!!!
                  • CaysonPundefined
                    CaysonP
                    https://imgur.com/a/0UFVp
                      The top left window in your image shows the interactive version of Bossa. It looks like you have the filename entered correctly, and it has connected to the PanelDue. You just need to check the Lock box, then press Write.
                      • CaysonPundefined
                        CaysonP
                        still no luck.
                        i think my problem is the command promt.
                        is says
                        "file name" is not recognized as an internal or external command, operable program or batch file.
                        • oleeundefined
                          olee
                          Try the next 2 commands in command prompt window (press ENTER after each entered command):
                          cd "\Program files (x86)\BOSSA"
                          bossac.exe –port=COM11 -e -w -v -b PanelDueFirmware.bin
                          • CaysonPundefined
                            CaysonP
                            That command i think got me closer but still no go.
                            https://imgur.com/a/XQTWN
                            I feel im missing something stupid…....
                            • elmoretundefined
                              elmoret
                              Yes, you're closer. But your command is referencing "PanelDueFirmware.bin", but the filename you have is "PanelDue-v4-5.0.bin". So Bossa can't find the file you're asking it to find.
                              So you either need to rename the .bin file, or change the command that you're putting into the command prompt.
                              • oleeundefined
                                olee
                                Didn't see filename, sorry. So second command should be
                                bossac.exe –port=COM11 -e -w -v -b PanelDue-v3-5.0.bin
                                • CaysonPundefined
                                  CaysonP
                                  https://imgur.com/a/DEpnk
                                  Is that it?
                                  • oleeundefined
                                    olee
                                    It seems to me you are in right place, firmware is download on the board.
                                    • CaysonPundefined
                                      CaysonP
                                      still no luck, i have a black screen that wont turn on. ive checked wiring and made sure its not 1 pin off or backwards.
                                        You have successfully re-installed firmware on the board.
                                        1. Check that there is a jumper on the voltage select pins, in the 3.3V position. Please check that your board revision is 3.0, to match the firmware you have flashed. The version is printed on the back of the PanelDue controller board.
                                        2. If you EITHER press the Reset button (NOT Erase!) OR disconnect and then reconnect the USB connector, the display should turn on and you should see a "Touch the spot" prompt (you don't need to connect it to the Duet to get this). If the screen is still blank, then return both the PanelDue control board and the display to your supplier and ask for a replacement.
                                        • CaysonPundefined
                                          CaysonP
                                          will the Paneldue work not plugged into the duetwifi?
                                          • CaysonPundefined
                                            CaysonP
                                            is there a software i can use to control the DuetWiFi from my computer and bypass the PanelDue?
