    CNC Pause and Resume config files
    Gcode meta commands
    1.7k
    • Nightowlundefined
      Nightowl @OwenD
      @owend Here you go...
      27/05/2022, 20:38:47 	M0
      Cancelled printing file 0:/gcodes/Calibration Toolpath.gcode, print time was 0h 0m
      27/05/2022, 20:38:33 	Printing paused at X128.8 Y122.6 Z66.0
      27/05/2022, 20:38:32 	No tool selected
      Error: Bad command: {if state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
      Error: in file macro line 6 column 36: meta command: array index out of bounds
      27/05/2022, 20:38:30 	M25
      Resume state saved
      27/05/2022, 20:38:24 	M32 "0:/gcodes/Calibration Toolpath.gcode"
      File 0:/gcodes/Calibration Toolpath.gcode selected for printing
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      • Nightowlundefined
        Nightowl @OwenD
        @owend Should the wriggly brackets be after the second "if"?
        I changed it anyway, and now get this in the Console:
        27/05/2022, 20:46:49 	M0
        27/05/2022, 20:46:44 	Printing paused at X125.6 Y125.8 Z66.0
        27/05/2022, 20:46:43 	No tool selected
        Error: in file macro line 11 column 81: meta command: array index out of bounds
        27/05/2022, 20:46:40 	M25
        Resume state saved
        27/05/2022, 20:46:35 	M32 "0:/gcodes/Calibration Toolpath.gcode"
        BTW, when I click pause, the spinde keeps running and the XY stays where it is, not returning to the safe XY.
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @Nightowl
          @nightowl999 said in CNC Pause and Resume config files:
          Yes, I thought I corrected that.
          But now it's clear there's no tool selected when you are pausing.
          Therefore none of the subsequent code can work as it relies on a tool being selected.
          Is this a real job, or a dummy one?
          I'm willing to bet this would work (if I haven't mage any syntax errors LOL)
          ; pause.g
          if state.currentTool = -1
          	echo "No tool selected - selecting tool zero"
          	T0
          G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} ; move the Z axis to a safe height
          if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
          	set global.savedSpindleSpeed = tools[state.currentTool].spindleRpm ; save current spindle speed
          	G1 X273.5 Y560 F2400 ; move XY to a safe place
          	M5 ; turn the spindle off
          	echo "Spindle speed saved at " ^ { global.savedSpindleSpeed } ^ "RPM"
          else
          	echo "condition not met - Tool is ", state.currentTool, " Spindle RPM is ", tools[state.currentTool].spindleRpm
          EDIT
          If this works then we need to know how many tools you have.
          Nightowlundefined 1 Reply Last reply Reply Quote 1
          • Nightowlundefined
            Nightowl @OwenD
            @owend I'll try it, but I'm aware you're tired (as am I!)
            • OwenDundefined
              OwenD @Nightowl
              It's 5:51 AM here. I'm tired because I woke at 3am and couldn't get back to sleep 😧
              Try it when you can and report back.
              Nightowlundefined 2 Replies Last reply Reply Quote 1
              • Nightowlundefined
                Nightowl
                It works! And the spindle turns off with pause and on with resume!
                • Nightowlundefined
                  Nightowl @OwenD
                  @owend It's only 9pm here, but I've been trying to sort this all day!
                  • OwenDundefined
                    OwenD @Nightowl
                    @nightowl999
                    OK,
                    So the problem was there was no tool selected.
                    I would have thought that was necessary to turn a spindle on, but maybe not.
                    If you have multiple tools then you'll need to consider how to store which tool was selected when you pause (if RRF doesn't store that in CNC mode)
                    • Nightowlundefined
                      Nightowl @OwenD
                      @owend This is how my spindle is configured in config.g:
                      ; Makita and relay configuration
                      M950 R0 C"out1+out7" L0:18000	; enable router relay on out7
                      M563 P0 S"Makita" R0 		; assign spindle 0 to tool 0 and name it Makita
                      T0				; select tool 0
                      This was only configured to turn the spindle off/on via a relay, but I figured I will need this resolved for when my speed-contollable milling motor turns up. My assumption is the speed thing isn't relevant as the DI isn't connected.
                      • OwenDundefined
                        OwenD @Nightowl
                        @nightowl999
                        What happens in the console when you run
                        M98 P"0:/sys/config.g"
                        You're selecting T0, so I'm at a loss why it's not selected in your job.
                        Somewhere something is turning it off.
                        • Nightowlundefined
                          Nightowl @OwenD
                          @owend said in CNC Pause and Resume config files:
                          From the command line?
                          • OwenDundefined
                            OwenD @Nightowl
                            @nightowl999
                            yes
                            • Nightowlundefined
                              Nightowl @OwenD
                              @owend
                              Only this:
                              27/05/2022, 21:02:24 M98 P"0:/sys/config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Error: in file macro line 66 column 27: meta command: variable 'savedSpindleSpeed' already exists
                              but I haven't 'rebooted' the Duet
                              • OwenDundefined
                                OwenD
                                @nightowl999
                                OK
                                That error is normal if you haven't rebooted.
                                I'm at a loss why you have no tool selected when pause.g begins unless RRF deselects it when G25 is run.
                                I've been looking through the object model a bit and I think you can do away with teh global variable and use values from the object model.
                                I'll post something to try in 5-10 minutes
                                • Nightowlundefined
                                  Nightowl @OwenD
                                  @owend If you're sure. I don't want to stress you (or me!) out trying to resolve this. I thought this would be easy 🤣 🤣
                                  I'm going back to the hous, but I'll update the files when you post the answer ( 🙂 ) and I'll try it out toorrow morning (my time).
                                  I'm really grateful for your time and help with this, @OwenD
                                  • OwenDundefined
                                    OwenD @Nightowl
                                    @nightowl999
                                    Try these
                                    ; pause.g
                                    and
                                    ;resume.g
                                    if state.restorePoints[0].toolNumber =-1
                                    	"echo no tool was saved- selecting T0"
                                    	T0
                                    else
                                    	T{state.restorePoints[0].toolNumber} ; select the tool that was active
                                    if state.restorePoints[0].spindleSpeeds[0] = 0
                                    	echo "No resume speed was saved"
                                    else
                                    	M3 S{state.restorePoints[0].spindleSpeeds[0]}	; resume saved spindle speed
                                    	G4 S1					; wait 1 second to allow the spindle to spin up
                                    	echo "Spindle speed resumed at ", state.restorePoints[0].spindleSpeeds[0], "RPM" ; this should show that the setting was successful
                                    Forgot to comment "resume.g" corrected.
                                    Also I have no way of checking what's stored in the restore point arrays.
                                    • Nightowlundefined
                                      Nightowl @OwenD
                                      @owend I tweaked the first echo, too!
                                      • Nightowlundefined
                                        Nightowl @OwenD
                                        @owend I need to call it a night. I've been summoned and the neighbours don't like the noise!
                                        Here's the last bit of Console text...
                                        27/05/2022, 21:28:41 	M0
                                        Printing paused at X205.3 Y258.9 Z64.0
                                        27/05/2022, 21:28:30 	M25
                                        Resume state saved
                                        27/05/2022, 21:28:29 	Printing resumed
                                        27/05/2022, 21:28:21 	M24
                                        Error: in file macro line 7 column 4: meta command: unknown value 'spindleSpeeds^'
                                        27/05/2022, 21:28:17 	Printing paused at X205.3 Y212.6 Z65.0
                                        27/05/2022, 21:28:07 	M25
                                        Resume state saved
                                        27/05/2022, 21:27:48 	M32 "0:/gcodes/Calibration Toolpath.gcode"
                                        Once again, the spindle didn't restart 😞
                                        • OwenDundefined
                                          OwenD @Nightowl
                                          @nightowl999
                                          OK.
                                          As I said, I have no way of checking exactly how the restore points for spindles work.
                                          Perhaps @DC42 could chime in at this point now that it's narrowed down and explain why there's no tool selected when you pause and also whether all the spindle speeds etc are saved in the object model.
                                          • Nightowlundefined
                                            Nightowl @OwenD
                                            Thank you, @OwenD. you've been an absolute diamond.
                                            I'll restore the files back to where they were before I said "It works!..." and hope @dc42 would be kind enough to help.
                                            Thanks again!
