Power failure and resurrection on a CNC machine
Yes, it's called from that file:
; resurrect-prologue.g M98 P"RestoreSpindleSpeed.g" if global.abort_process == true abort ; abort terminates this and all other macros in the cal chain, so 'rien ne va plus' ; Continuation has been approved, so here we go:" M98 P"homeall.g" ; homes all axes before restarting the job {1}
And all I did with the updated RestoreSpindleSpeed.g was copy and paste...
A thought: Should the variable be declared in config.g, or is it a system variable?
PS I tried without the curly brackets, but it made no difference, so I put them back
@nightowl999 said in Power failure and resurrection on a CNC machine:
Fine. Then please replace the contents of SaveSpindleSpeed.g with this here, as I've found an (unrelated) bug.
; SaveSpindleSpeed.g ; Macro to store the actual spindle speed (RPM) at the time this is called ; To restore the saved datum, call the macro "RestoreSpindleSpeed.g". ; Before it activates the spindle, RestoreSpindleSpeed.g asks whether to continue with the print or not. ; If not, the process can be stopped with these two lines in resurrect-prologue.g: ; ; if {global.abort_process == true} ; abort ;;; please not that this line must be indented ; ; Requires RRF 3.4 and a CNC configuration with valid spindles[0] entry in the object model var fName = "RestoreSpindleSpeed.g" echo >{var.fName} "; "^var.fName echo >>{var.fName} "; Spindle speed saved from running """^{job.file.fileName}^""" CNC file" echo >>{var.fName} "" echo >>{var.fName} "; set up the global variable abort_process so we can abort further execution of resurrect.g:" echo >>{var.fName} "if {!exists(global.abort_process)}" echo >>{var.fName} " global abort_process = true" echo >>{var.fName} "else" echo >>{var.fName} " set global.abort_process = true" echo >>{var.fName} "" echo >>{var.fName} "; now comes the dialog:" echo >>{var.fName} "M291 S3 R""Resurrect:"" P""Continue with <"^{job.file.fileName}^">?""" echo >>{var.fName} "" echo >>{var.fName} "; we will only arrive here if the dialog was closed with OK:" echo >>{var.fName} "set global.abort_process = false" echo >>{var.fName} "M3 S"^{spindles[0].active} echo >>{var.fName} "" echo >>{var.fName} ";EOF"
Then, please simulate a power outage - this step is needed to generate the proper RestoreSpindleSpeed.g macro.
@infiniteloop No, sorry. I get exactly the same error
OK, let's see β¦ Could you please compare your RestoreSpindleSpeed.g with this here:
; RestoreSpindleSpeed.g ; Spindle speed saved from running "null" CNC file ; set up the global variable abort_process so we can abort further execution of resurrect.g: if {!exists(global.abort_process)} global abort_process = true else set global.abort_process = true ; now comes the dialog: M291 S3 R"Resurrect:" P"Continue with <null>?" ; we will only arrive here if the dialog was closed with OK: set global.abort_process = false M3 S0 ;EOF
I generated this without a job running, that's why the CNC file name is "null", and without a spindle,
M3
will always be told a speed of 0 RPM. -
@infiniteloop Erm, my file looks like this...
; RestoreSpindleSpeed.g ; Spindle speed saved from running "0:/gcodes/Calibration Toolpath.gcode" CNC file ; set up the global variable abort_process so we can abort further execution of resurrect.g: if {!exists(global.abort_process)}
I just noted a difference between your resurrect-prologue.g and the template I sent you - here's my version:
and here's your corresponding line:
You see the difference?
@infiniteloop I do, yes. I tried it at that, but changed it back to using the squiggly brackets, as it made no difference.
They're currently in place, as per your version.
; resurrect-prologue.g M98 P"RestoreSpindleSpeed.g" if {global.abort_process == true} abort ; abort terminates this and all other macros in the call chain, so 'rien ne va plus' ; Continuation has been approved, so here we go:" M98 P"homeall.g" ; homes all axes before restarting the job {1}
I don't know why there are two {1} showing at the end of the file, though. There's only 1 in the actual file!
Where is the global.abort_process declared, or is it a ssytem variable?
That's a radically abbreviated versionβ¦
Either, your SaveSpindleSpeed.g has been truncated so that it just generates 4 lines of output, or we see the result of too little power left after pulling the plug.
[Edit] First, please check your copy of SaveSpindleSpeed.g carefully against the posted version. If both are equal, call SaveSpindleSpeed.g from the console:
- throws it an error?
- looks the resulting RestoreSpindleSpeed.g like the one I posted above?
I'm not quite sure, either, but I think they indicate empty lines.
@infiniteloop said in Power failure and resurrection on a CNC machine:
Maybe you're right about the powerloss, then, or (sorry for asking again) the global.abort_process variable hasn't been declared?
@nightowl999 I've added some hints to my post above. Please try them β¦
@infiniteloop It says
the file's not found, but it's deffo there in my \sys folder!Error: in file macro line 28 column 26: meta command: control character in string
OK, there was a " missing on the last line...
@infiniteloop Now the file looks like this:
I'll have another go at the power fail test...
That's perfect. Before pulling the plug again, you should call resurrect-prologue.g from the console to see if you still get an error. Note, however, that your router might execute the homing moves if the construct works as expected.
Same problem. Only half a RestoreSpindleSpeed.g file...
OK, so I called resurret-prologue.g which gave a prompt to carry on. I clicked OK and the homing sequence completed.
Then i got these errors:
31/05/2022, 12:19:04 M292 Error: Bad command: {1} 31/05/2022, 12:19:04 m98 P"resurrect-prologue.g" Error: Bad command: {1}
EDIT: I've deleted the {1}
So we've localised this problem: rapid power loss β¦
In the meantime, please test with a RestoreSpindleSpeed.g which you generate from the command line
M98 P"SaveSpindleSpeed.g"
Proceed as suggested in my last post. Feel free to edit the S parameter of
M3
if want your spindle to turn -
That are these empty line marks who seem to be generated when I put my stuff into the code (black) box.
Simply remove all occurrences of {1}β¦ I just see: you did that already while I was writing -
Shall I try the ultimate test?
Without enough power to safely complete macro execution at power off, what is the definition of "ultimate"?
