    Power failure and resurrection on a CNC machine
    CNC
    7.4k
    • infiniteloopundefined
      infiniteloop @Nightowl
      @nightowl999 said in Power failure and resurrection on a CNC machine:
      I just noted a difference between your resurrect-prologue.g and the template I sent you - here's my version:
      if {global.abort_process == true}
      and here's your corresponding line:
      if global.abort_process == true
      You see the difference? 😌
      Nightowlundefined 1 Reply Last reply Reply Quote 0
      • Nightowlundefined
        Nightowl @infiniteloop
        @infiniteloop I do, yes. I tried it at that, but changed it back to using the squiggly brackets, as it made no difference.
        They're currently in place, as per your version.
        ; resurrect-prologue.g
        M98 P"RestoreSpindleSpeed.g"
        	abort
        ; abort terminates this and all other macros in the call chain, so 'rien ne va plus'
        ; Continuation has been approved, so here we go:"
        M98 P"homeall.g"	; homes all axes before restarting the job
        {1}
        I don't know why there are two {1} showing at the end of the file, though. There's only 1 in the actual file!
        Where is the global.abort_process declared, or is it a ssytem variable?
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
          Erm, my file looks like this...
          That's a radically abbreviated version… 🤔
          Either, your SaveSpindleSpeed.g has been truncated so that it just generates 4 lines of output, or we see the result of too little power left after pulling the plug.
          [Edit] First, please check your copy of SaveSpindleSpeed.g carefully against the posted version. If both are equal, call SaveSpindleSpeed.g from the console:
          • throws it an error?
          • looks the resulting RestoreSpindleSpeed.g like the one I posted above?
            I'm not quite sure, either, but I think they indicate empty lines.
            Nightowlundefined 1 Reply Last reply Reply Quote 1
            • Nightowlundefined
              @infiniteloop said in Power failure and resurrection on a CNC machine:
              Maybe you're right about the powerloss, then, or (sorry for asking again) the global.abort_process variable hasn't been declared?
                @nightowl999 I've added some hints to my post above. Please try them …
                Nightowlundefined 3 Replies Last reply Reply Quote 1
                • Nightowlundefined
                  @infiniteloop It says the file's not found, but it's deffo there in my \sys folder!
                  Error: in file macro line 28 column 26: meta command: control character in string
                  OK, there was a " missing on the last line...
                  • Nightowlundefined
                    @infiniteloop Now the file looks like this:
                    ; RestoreSpindleSpeed.g
                    ; Spindle speed saved from running "null" CNC file
                    ; set up the global variable abort_process so we can abort further execution of resurrect.g:
                    if {!exists(global.abort_process)}
                        global abort_process = true
                    else
                        set global.abort_process = true
                    ; now comes the dialog:
                    M291 S3 R"Resurrect:" P"Continue with <null>?"
                    ; we will only arrive here if the dialog was closed with OK:
                    set global.abort_process = false
                    M3 S0
                    ;EOF
                    I'll have another go at the power fail test...
                      That's perfect. Before pulling the plug again, you should call resurrect-prologue.g from the console to see if you still get an error. Note, however, that your router might execute the homing moves if the construct works as expected.
                      • Nightowlundefined
                        @infiniteloop
                        Same problem. Only half a RestoreSpindleSpeed.g file...
                        • Nightowlundefined
                          @infiniteloop
                          OK, so I called resurret-prologue.g which gave a prompt to carry on. I clicked OK and the homing sequence completed.
                          Then i got these errors:
                          31/05/2022, 12:19:04 	M292
                          Error: Bad command: {1}
                          31/05/2022, 12:19:04 	m98 P"resurrect-prologue.g"
                          EDIT: I've deleted the {1}
                            So we've localised this problem: rapid power loss …
                            In the meantime, please test with a RestoreSpindleSpeed.g which you generate from the command line
                            M98 P"SaveSpindleSpeed.g"
                            Proceed as suggested in my last post. Feel free to edit the S parameter of M3 if want your spindle to turn ☺
                            • Nightowlundefined
                              @infiniteloop
                              That seems to work now.
                              Shall I try the ultimate test?
                                That are these empty line marks who seem to be generated when I put my stuff into the code (black) box. 😠
                                Simply remove all occurrences of {1}… I just see: you did that already while I was writing 😊
                                  Without enough power to safely complete macro execution at power off, what is the definition of "ultimate"? 🤔
                                  • Nightowlundefined
                                    @infiniteloop As everything is hunky dory, the "ultimate" test would be to see if everything does work. If not, a UPS might be in order 😞
                                      Do you have a separated 5V rail (with its own PSU) just to power the Duet?
                                      • Nightowlundefined
                                        @infiniteloop Nope. It's just my 24V PSU
                                        I wouldn't know how to do that, but it's only the Duet that's powered from the 24V, as the spindle has it's own power supply.
                                        Still, the "ultimate" test failed at the same point, so I'm going to need to look at the 5V - or UPS - option!
                                        But surely, if the power fails, it fails. What use is a 5V supply if it's on the same mains circuit?
                                        infiniteloopundefined 2 Replies Last reply Reply Quote 0
                                          If you put your UPS on that, the Duet won't notice the loss of mains power: Without a voltage drop, M911 won't be executed … until the UPS runs out of juice. But then, you face the same situation as now.
                                            You could either use a large capacitor, a tiny UPS or a power bank to keep the 5V alive for a while.
