The tower motors ..... H E L P
@tecno said in The tower motors ..... H E L P:
https://docs.duet3d.com/duet_boards/duet_3_can_expansion/duet_3_1xd_v1.0_wiring_03.pngYes
Same as above
Same as aboveThanks. Your wiring link suggests that you have connected the Enable inputs of the drivers to the 1XD boards. So if you have set the Enable polarity correctly, the carriages should move freely before you command them to move, and after that (or when you use M17) they should lock. The fact that they are not locking suggests one of the following:
- Power is not being supplied to your external drivers
- Motor is not connected correctly to external driver
- Configuration of external driver incorrect
- Configuration of RRF is incorrect, so that it is not commanding the 1XD boards to move the motors
Please run the following command and report any error messages that you see:
M98 P"config.g"
36V
Connected as per docs
2022-06-03 18:54:47 M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23
Error: Setting not available for external drivers
Setting not available for external drivers -
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue May 31 2022 17:03:35 GMT+0200 (centraleuropeisk sommartid); General preferences
M575 P1 S0 B57600 ; enable support for PanelDue
M550 P"BigDelta" ; set printer name
M665 R300 L615 B275 H570 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
M669 S1 T1 ; kinematics linear delta
M564 H0 S0 ; allow axis movement not homed; Wait a moment for the CAN expansion boards to start
G4 S2; Network
M551 P"bengt" ; set password
M552 P192.168.1.124 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P40.0 S1 R1 T10:10:10:10 ; physical drive 121.0 goes forwards
M569 P41.0 S1 R1 T10:10:10:10 ; physical drive 122.0 goes forwards
M569 P42.0 S1 R1 T10:10:10:10 ; physical drive 123.0 goes forwards
M584 X40.0 Y41.0 Z42.0 E0.0 ; set drive mapping
M350 E16 I1 ; configure microstepping with interpolation X16 Y16 Z16
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"40.io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
M574 Y2 S1 P"41.io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
M574 Z2 S1 P"42.io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in; Z-Probe
M558 P5 R0.4 C"io3.in+io4.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
M557 R85 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 F0 C"out5" Q500 ; create fan 0 on pin out3 and set its frequency
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M563 P1 D0 H1 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
;M501 ; load saved parameters from non-volatile memory -
Have been trying to search the forum what this Setting not available for external drivers is caused but cannot not find anything.
M98 P"config.g"
@tecno Have you tried removing X, Y and Z from your M906 command, you can't set the current for external drivers.
Now I did that = still no movement. Error in M98 gone
M98 P"config.g"
TELNET is enabled on port 23 -
Drivers are set to 1/16step and 3.2A
M569 P40.0 S0 R1 T10:10:10:10
M569 P41.0 S0 R1 T10:10:10:10
M569 P42.0 S0 R1 T10:10:10:10 -
With my DMM I can measure DIR shifting 4.78V to 0 and see a small shift in Step of 0.048V and EN is 4.78V
Even tried to shift driver to DM542A No movement on Y axis
Now all axis are connected to Mini5, only E0 is moving.
; Drives ;M569 P40.0 S0 R1 T10:10:10:10 ; physical drive 121.0 goes forwards ;M569 P41.0 S0 R1 T10:10:10:10 ; physical drive 122.0 goes forwards ;M569 P42.0 S0 R1 T10:10:10:10 ; physical drive 123.0 goes forwards M569 P0.0 S0 M569 P1.0 S0 M569 P2.0 S0 M569 P3.0 S0 ; physical drive 0.0 goes forwards M584 X3.0 Y2.0 Z1.0 E0.0 ;M584 X40.0 Y41.0 Z42.0 E0.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation X16 Y16 Z16 M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
What is wrong?
M569 P0.0 S0
M569 P1.0 S0
M569 P2.0 S0
M584 X3.0 Y2.0 Z1.0 E0.0You've got the numbers backwards I think.
The first digit is the board address, the second is the driver number.
Did look at my CHIRON setup with Mini5
M569 P0 S0 M569 P1 S0 M569 P2 S0 M569 P3 S0 ; physical drive 0.0 goes forwards M584 X3 Y2 Z1 E0 ;M584 X40.0 Y41.0 Z42.0 E0.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation X16 Y16 Z16 M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30
Just need to fix speed + acc
Next is to take one of the DM556´s and open it and see what is going on. Did buy these on Amazon so I need to ask for a refund.
Bah.... 2 weeks past return time = not so good
@tecno you could try disconnecting the Enable input to the external drivers, and see if that causes the motors to lock. Most external drivers use the Enable input to disable the drivers, not to enable them.
Now the drivers are out for repair and I am now concentrating to get printer to run with Mini5 drivers. Not optimal but will have to do until the DM556 are OK. -
Good news, now my DM556's are repaired and tested. Tomorrow time to get my 1XD's to their job.
