    M950 output on 1XD
    533
    • Nightowlundefined
      Nightowl @tecno
      @tecno
      You could use an external relay, like these and control the relay from the control board and provide an independent 15V supply to the fans.
      You could also wire them in parallel, but be aware of the current drawn. I've connected two in parallel as cooling fans of the enclosure I used for the Duet3 MB6HC.
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @Nightowl
        @nightowl999
        Or use a stepdown like this
        Nightowlundefined 1 Reply Last reply Reply Quote 0
        • Nightowlundefined
          Nightowl @tecno
          @tecno
          So if you already knew, why did you ask?
          • tecnoundefined
            tecno @Nightowl
            @nightowl999
            I was asking for setting up output0 on 1XD to output 5V (if at all possible) to fans.
            droftartsundefined Nightowlundefined 2 Replies Last reply Reply Quote 0
              droftarts administrators @tecno
              @tecno as far as I’m aware, IO_0 and IO_1 are VIN outputs only, and not voltage selectable.
              • Nightowlundefined
                Nightowl @tecno
                @tecno
                That wasn't really clear from you post, though.
                My fans are connected to out8 @ Q500 and seem to work well enough, but then my fans are 12V and only on when the Duet3 MB6HC is on.
                M950 F0 C"out8" Q500 ; create fan 0 on pin out 8 and set its frequency
                M106 P0 S0.5 H-1 ; set fan 0 value. Thermostatic control is turned off
                • tecnoundefined
                  tecno @Nightowl
                  @nightowl999 said in M950 output on 1XD:
                  Lets blame the bloody foreigner šŸ˜‰
                  Nightowlundefined 1 Reply Last reply Reply Quote -1
                  • tecnoundefined
                    tecno @droftarts
                    @droftarts
                    The StepDown it is, thanks for clarifying Ian.
                    • Nightowlundefined
                      Nightowl @tecno
                      @tecno said in M950 output on 1XD:
                      Absolutely not. We're all foreigners to someone, which makes us all equal!
                      tecnoundefined 1 Reply Last reply Reply Quote 3
                      • tecnoundefined
                        tecno @Nightowl
                        My 3 fan cooling for the Mini5
