need Guru on duet 3 mini5 using stall guard/sensor less homing
Warning: Driver 0.4 stall
Drive 4 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 96, pwmScaleAuto 9, pwmOfsAuto 61, pwmGradAuto 18, pos 657
Drive 5 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 16, pwmScaleAuto 0, pwmOfsAuto 64, pwmGradAuto 18, pos 8
Drive 6 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 33, pwmScaleAuto 3, pwmOfsAuto 69, pwmGradAuto 19, pos 446
6/10/2022, 10:49:35 AM Warning: Driver 0.5 stall
lower motor current
Drive 4 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 22, pwmScaleAuto 0, pwmOfsAuto 61, pwmGradAuto 19, pos 392
Drive 5 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 26, pwmScaleAuto 0, pwmOfsAuto 64, pwmGradAuto 18, pos 1016
Drive 6 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 24, pwmScaleAuto 0, pwmOfsAuto 66, pwmGradAuto 19, pos 40
home max z
Warning: Driver 0.5 stall -
can anyone explain to me the following info , this was after Drive 4 failed to move the Z axis.
the only big difference i can see is the "POS" value drive 4, 40 but drive 5,6 600 and 680, what is "POS"
Drive 4 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 15, pwmScaleAuto 0, pwmOfsAuto 60, pwmGradAuto 18, pos 40
Drive 5 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 22, pwmScaleAuto 2, pwmOfsAuto 61, pwmGradAuto 18, pos 600
Drive 6 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 10 (234.4 mm/sec), pwmScaleSum 24, pwmScaleAuto 0, pwmOfsAuto 72, pwmGradAuto 19, pos 680 -
running M122 within the macro i can see that the drive is stalled , its not always the same drive and its a random event
part of the M122 file
MCU temperature: min 29.8, current 31.4, max 32.9
Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/522/522, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 214, reads 8942, writes 18, timeouts 0, DMA errors 0, CC errors 0
Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 207, reads 8943, writes 17, timeouts 0, DMA errors 0, CC errors 0
Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 109, reads 8959, writes 0, timeouts 0, DMA errors 0, CC errors 0
Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 115, reads 8959, writes 0, timeouts 0, DMA errors 0, CC errors 0
Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 188, reads 8945, writes 15, timeouts 0, DMA errors 0, CC errors 0
Driver 5: stalled, standstill, SG min 0, read errors 0, write errors 0, ifcnt 188, reads 8945, writes 15, timeouts 0, DMA errors 0, CC errors 0
Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 186, reads 8945, writes 14, timeouts 0, DMA errors 0, -
Have also noticed M122 does not always report the Stalled motor , sometimes the motor does not move but is this because its NOT stalled but just didn't move for other reasons
Without having seen either your machine, your config.g, your stall test macro, it's really hard to say anything about your setup.
The gurus luckily wrote down their wisdom at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_stall_detection
AFAIR,
pos
is the microstep position as reported by the driver, usually a value between 0 and 1024. it will wrap around multiple times when you move your axis. I would not worry about them being different per axis, especially if you use something like automatic bed alignment.Regarding the irregular report of stall in M122 -- this may be a simple race condition. Usually if you detect a stall for homing, the motor stops moving, so if M122 runs, the stall flag may have already cleared from the driver.
@oliof
Hi i can post everything , just when i think ive fixed it it happens again, when a motor stalls do you know if it turns of the power to that stepper motor? -
@moth4017 See the M915 description. With
R0
a stall is only reported but nothing is done beyond that. If your motor stops while it should be moving and you haven't setR2
/R3
, then it is most likely a physical issue, i.e. binding.I can tell you that I can create stall reports on Z when enabling Z hop just from the back emf of stopping a short movement if sensitivity is high enough (-:
@oliof
Hi yes im using R0 , the file below is using R1 as i have just tried itI have 3 stepper motors on the Z axis , when i send the Z axis to the bottom of the printer , 1 or 2 of the motors will loose drive , its not always the same motor and its not all the tame.
; home_max_Z
echo "start home max Z"
M122
;M569 P0.4 ; Check status in console
;M569 P0.5
;M569 P0.6
G91 ; relative positioning
M569 P0.4 S1 D3 V10 ; set to stelth chop
M569 P0.5 S0 D3 V10 ; set to stelth chop
M569 P0.6 S1 D3 V10 ; set to stelth chopM915 P0.4 S2 F0 R1 H400 ; Configure Z-Axis Stall Detection
M915 P0.5 S2 F0 R1 H400 ; Configure Z-Axis Stall Detection
M915 P0.6 S2 F0 R1 H400 ; Configure Z-Axis Stall Detectionecho "diag before stall detection setup"
G1 P50
echo "stall detection setup"
M17 Z ;energise a motor for stealthChop tuning
G1 P240 ; pause to allow the drivers to characterise the motor
G1 H1 Z-2.4 F6000 ; move a little for cal of sensorless homing / not stalled
echo "after stall detection setup"
;M569 P0.5
;M569 P0.6echo "lower motor current"
M913 Z80 ; Lower motor current %
M566 Z15.00 ;jerk
M201 Z50.00 ; set accelerations (mm/s^2)
G4 P150 ;wait time ms
M574 Z2 S4 ; Configure Z-Axis stall detection homing
;M569 P0.5 ; Check status in console
;M569 P0.6 ; Check status in consoleecho "home max z"
G1 H1 Z350 F3000 ; Home Z-Axis actuators independently
G92 Z300 ; set a Z height
G90 ; absolute positioningG4 P300
;revert back
echo "after revert back"
M913 Z100 ; Reset motor current
M569 P0.4 S1 D2 V2000 ; reset motors back to spread cycle,
M569 P0.5 S0 D2 V2000 ; reset motors back to spread cycle,
M569 P0.6 S1 D2 V2000 ; reset motors back to spread cycle,
M84 ; turn off motors
echo "The bed has landed" -
ive also tries
s values from 1 to 50
H values 200, 400,
F1 and F0
jerk settings and acceleration -
@moth4017 what firmware version are you using? Use M115 to check.
@dc42 release 3.4.1
the one you did 7 days ago -
@moth4017 we'll need to see your config.g file and your homing files.
; Config.g G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Valkyrie 3030 V004" ; set printer name M669 K1 ; core xy ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 D2 ; physical drive 0 goes forwards M569 P0.1 S1 D2 ; physical drive 1 goes forwards M569 P0.2 S1 ; physical drive 2 goes forwards ( blown needs replacing) M569 P0.3 S0 ; physical drive 3 extruder M569 P0.4 S1 D2 ; physical drive 4 goes forwards D3=stealthchop M569 P0.5 S0 D2 ; physical drive 5 goes backwards M569 P0.6 S1 D2 ; physical drive 6 goes forwards M584 X0.1 Y0.0 Z0.4:0.5:0.6 E0.3 ; set drive mapping FL,FR,RC M350 X16 Y16 I1 ; configure microstepping with interpolation M350 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z320.00 E562.00 ; set steps per m M566 X800.00 Y800.00 Z100.00 E100.00 P1 ; set maximum instantaneous speed changes (mm/min) jerk M203 X24000.00 Y24000.00 Z6000.00 E400.00 ; set maximum speeds (mm/min) M201 X2200.00 Y2200.00 Z100.00 E250.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E800 I50 ; set motor currents (mA) and motor idle factor in per cent M84 X Y S20 ; Set idle timeout sec ; Axis Limits M208 S1 X-28 Y-50 Z0 ; set axis minima "Travel Area" M208 S0 X290 Y295 Z405 ; set axis maxima "Travel area" ; Endstops M574 X1 S3 ; configure sensorless endstop, 1 = low end, 2 = high end. s3 = single motor, S4 multipule motors M574 Y2 S3 ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in M574 Z2 S4 ; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors M671 X-20:300:150 Y0:0:280 S25 ; leadscrews at front left,front right, rear Center s= max correction factor must be in same order as M584 M558 P8 C"!io3.in" H10 F8000 T8000 R0 A2 S0.05 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 Z0.9 ; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed G31 P500 X27 Y-15 ; set x,y trigger value, offset and trigger height M557 X10:290 Y10:285 S100 ; define mesh grid ; Heaters ;Bed M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed T °C" ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"out0" T0 Q10 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 R0.838 K0.331:0.000 D3.08 E1.35 S0.90 B0 ; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950 M140 H0 ; map heated bed to heater 0 M143 H0 S130 ; set temperature limit for heater 0 to max C ;extruder M308 S1 P"temp1" Y"pt1000" A"Extruder T °C" ; configure sensor 1 as thermistor on pin e0temp (104gt2) M950 H1 C"out1" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 R3.558 K0.357:0.000 D9.14 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit M143 H1 S320 ; set temperature limit for heater 1 to max C ;Chamber M308 S2 P"temp2" Y"thermistor" T100000 B4267 A"Chamber T °C" ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out5" T2 ; create chamber heater output on 1.out0 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2 M143 H2 S100 ; set temperature limit for heater 2 to 280C M308 S10 Y"mcu-temp" A"MCU" ; defines sensor 10 as MCU temperature sensor M308 S11 Y"drivers" A"Duet stepper drivers" ; defines sensor 11 as stepper driver temperature sensor G1 H1 Z-0.2 F3000 ; Fans M950 F0 C"out4" Q250 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 C"Part Fan" ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out3" Q250 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T35 C"Extruder Fan" ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C T0 ; Custom settings are not defined M98 P"/macros/home_max_Z" ;External Buttons M950 J1 C"!io2.in" ;config input pin switch NO connected to io2 and Gnd M581 P1 T0 C0 ;T0 = emergency stop on trigger; T1 = pause print; T{N} = runs the macro "sys/trigger{N}.g", rising edge S1 falling edge S0 ;M581 P1 T4 c0 ;run a macro trigger4.g M582 T0 ; Check External Trigger ; homex.g echo "start" M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console G91 ; relative positioning M569 P0.0 S1 D3 V10 ; set to stealth chop M569 P0.1 S1 D3 V10 ; set to stealth chop M915 P0.0 S30 F0 R1 H200 ; Configure Z-Axis Stall Detection M915 P0.1 S30 F0 R1 H200 ; Configure Z-Axis Stall Detection echo "stall detection setup" M17 X Y ; Check status in console G1 P140 ;pause to allow the drivers to characterise the motor G1 H1 X-0.2 F3000 ; move a little for cal of sensorless homing / not stalled G1 H1 Y-0.2 F3000 ; move a little for cal of sensorless homing / not stalle echo "lower motor current" M913 X70 Y70 ; Lower motor current % G4 P150 ; wait 150ms M574 X1 Y2 S3 ; Configure Z-Axis stall detection homing M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console echo "home x" G1 H1 X-350 F6000 G1 H2 X10 Y10 G1 H1 X-350 F6000 ; Home Z-Axis actuators independently M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console G90 ; absolute positioning G1 X150 F6000 ; move to center of bed ;revert back echo "after revert back" M913 X100 Y100 ; Reset motor current % M569 P0.0 S1 D2 ; reset motors back to spread cycle, M569 P0.1 S1 D2 ; reset motors back to spread cycle, M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console ;homey.g echo "Home Y" M569 P0.0 ; check status in console Y M569 P0.1 ; check status in console X G91 ; Relative positioning M569 P0.0 S1 D3 V10 ; set to stelth chop M569 P0.1 S1 D3 V10 ; set to stelth chop M915 P0.0 S10 F0 R1 H200 ; Configure x-Axis Stall Detection M915 P0.1 S10 F0 R1 H200 ; Configure x-Axis Stall Detection echo "stall detection setup" M17 X Y G1 P140 G1 H1 X-0.5 F3000 ; move a little for cal of sensorless homing / not stalled G1 H1 Y-0.5 F3000 ; move a little for cal of sensorless homing / not stalled echo "lower motor current" M913 X70 Y70 ; Lower motor current % G4 P150 M574 X1 Y2 S3 ; Configure Z-Axis stall detection homing M569 P0.0 ; check status in console M569 P0.1 ; check status in console echo "Home Y" G1 H1 Y350 F6000 G1 H2 X-10 Y10 G1 H1 Y350 F6000 ; Home Z-Axis actuators independently M569 P0.0 ; check status in console M569 P0.1 ; check status in console G90 ; absolute positioning G1 Y150 F6000 ; move to center of bed ;revert back echo "after revert back" M913 X100 Y100 ; Reset motor current M569 P0.0 S1 D2 ; reset motors back to spread cycle, M569 P0.1 S1 D2 ; reset motors back to spread cycle, M569 P0.0 ; check status in console M569 P0.1 ; check status in console and this is the one thats causing the issues
; home_max_Z echo "start home max Z" M122 ;M569 P0.4 ; Check status in console ;M569 P0.5 ;M569 P0.6 G91 ; relative positioning M569 P0.4 S1 D3 V10 ; set to stelth chop M569 P0.5 S0 D3 V10 ; set to stelth chop M569 P0.6 S1 D3 V10 ; set to stelth chop M915 P0.4 S2 F0 R1 H400 ; Configure Z-Axis Stall Detection M915 P0.5 S2 F0 R1 H400 ; Configure Z-Axis Stall Detection M915 P0.6 S2 F0 R1 H400 ; Configure Z-Axis Stall Detection echo "diag before stall detection setup" G1 P50 echo "stall detection setup" M17 Z ;energise a motor for stealthChop tuning G1 P240 ; pause to allow the drivers to characterise the motor G1 H1 Z-2.4 F6000 ; move a little for cal of sensorless homing / not stalled echo "after stall detection setup" ;M569 P0.4 ; Check status in console ;M569 P0.5 ;M569 P0.6 echo "lower motor current" M913 Z80 ; Lower motor current % M566 Z15.00 ;jerk M201 Z50.00 ; set accelerations (mm/s^2) G4 P150 ;wait time ms M574 Z2 S4 ; Configure Z-Axis stall detection homing ;M569 P0.4 ; Check status in console ;M569 P0.5 ; Check status in console ;M569 P0.6 ; Check status in console echo "home max z" G1 H1 Z350 F3000 ; Home Z-Axis actuators independently G92 Z300 ; set a Z height ;M569 P0.4 ; Check status in console ;M569 P0.5 ; Check status in console ;M569 P0.6 ; Check status in console G90 ; absolute positioning G4 P300 ;revert back echo "after revert back" M913 Z100 ; Reset motor current M569 P0.4 S1 D2 V2000 ; reset motors back to spread cycle, M569 P0.5 S0 D2 V2000 ; reset motors back to spread cycle, M569 P0.6 S1 D2 V2000 ; reset motors back to spread cycle, ;M569 P0.4 ; Check status in console ;M569 P0.5 ; Check status in console ;M569 P0.6 ; Check status in console M84 ; turn off motors echo "The bed has landed" -
This post is deleted! -
@Arnold_R_Clark no, you are absolutely right. Simple microswitches are far superior to sensorless homing in ease of configuration, repeatability, and reliability. I have so far spent more time dealing with weird behavior of the sensorless homing setup I am running purely to be able to show how it would work for those that insist, than it would have been to order microswitches, wait a week for them to arrive, and fitting them -- including the wait time I guess.
@arnold_r_clark hi I do agree with you, i had 3 micro switches on the z axis but I needed the inputs for other functions and as the x an y axis work fine 100 % after the first homing , I thought it was going to become an easy exercise..... yes I could get an extension board but progress of stepper drivers and software can be archived . I'm not one to give up so I have persevered for 3 versions of software and a lot of reading and testing I'm sure at some point it will be as reliable as the X and Y. Wish me luck and a few more beers ..
The thing is I am running stalldetect homing on all 5 axis on the same printer flawlessly. I mean its bonkers! The difference is I run the Duet 2 wifi + Duex 5 as is TMC 2660 drivers. I still find it strange that the TMC 2209 drivers act so different
The 2660s do StallGuard2 in SpreadCycle, the 2209s do StallGuard4 in StealthChop. They work differently, so it's not a super big surprise that they need specific tuning.
hi any thoughts on how i can track the homing issues ?
No more Gurus out there playing with the Duet 3 mini5 tmc2209
