    CONSTANT AJAX disconnect errors
    307
    55.1k
    • KeeganBundefined
      KeeganB
      Over a couple different hour long prints the MCU temp stayed right around 34 C.
      Artemis
      Rostock Max v2
      Orion
        Please can those of you who are experiencing disconnect errors and are running DuetWiFiFirmware 1.20beta1 try changing the wifi firmware to version 1.20alpha1+1, which is available here: https://www.dropbox.com/s/u7vpp2wg4rlqs8l/DuetWiFiServer.bin?dl=1. Then let me know if you think it is better or worse.
        • Jareryundefined
          Jarery
          DuetWiFiFirmware1.20alpha1+1
          • Install 6:55
          • idle
          • Disconnect 7:55
          The log showed slightly different times. The disconnect happened at 7:55 but doesn't show on the log till 8:05. It would not connect via connect button during that time.
          2017-10-12 06:56:11 Event logging started
          2017-10-12 08:05:21 WiFi reported error: Lost connection, auto reconnecting
          2017-10-12 08:05:22 WiFi reported error: Auto reconnect succeeded
          after reconnect M122:
          Network state is running
          WiFi firmware version 1.20alpha1+1
          WiFi MAC address a0:20:a6:10:55:89
          WiFi Vcc 3.16, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 38352
          WiFi IP address 192.168.2.32
          WiFi signal strength -45dBm
          Reconnections 1
          HTTP sessions: 1 of 8
          Socket states: 2 0 0 0 0 0 0 0
          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          Edit 2:
          Left idle it disconnected again, after waiting 30 min Im able to reconnect. Log doesn't show that it ever knew it was disconnected: The 10:10 log is me reconnecting after disconnecting 30 min or so previous
          2017-10-12 08:58:13 HTTP client 192.168.2.49 login succeeded
          2017-10-12 10:10:20 HTTP client 192.168.2.49 login succeeded
          • Jareryundefined
            Jarery
            First print, disconnected while printing the skirt
              Thanks for your feedback. Which country are you in?
              • Jareryundefined
                Jarery
                Canada, Vancouver BC specificaly,
                • KeeganBundefined
                  KeeganB
                  Ill be away from the printer for about a week, but will updated to that new version you shared David as soon as I return.
                  Artemis
                  Rostock Max v2
                  Orion
                  • fmaundefined
                    fma
                    David, I juste realized that my WiFi signal strength is really low: -68dBm! I think I'm lucky it's working so well, despite such poor signal!
                    I think I will order the new ESP module, with antenna.
                    Frédéric
                    • callilundefined
                      callil
                      Updated to alpha1+1 - pretty much the same story for me unfortunately.
                      The following log is right after a disconnect when idle. I restarted the wifi module with M552 on device.
                      [[language]]
                      Used output buffers: 3 of 32 (17 max)
                      RepRapFirmware for Duet WiFi version 1.20beta1 running on Duet WiFi 1.0
                      Board ID: 08DAM-9K9K2-NGNSN-6JKD0-3SJ6T-15UBM
                      Static ram used: 15128
                      Dynamic ram used: 96048
                      Recycled dynamic ram: 3512
                      Stack ram used: 1352 current, 4880 maximum
                      Never used ram: 11504
                      Last reset 00:06:35 ago, cause: reset button or watchdog
                      Last software reset reason: User, spinning module GCodes, available RAM 11504 bytes (slot 3)
                      Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                      Error status: 0
                      Free file entries: 10
                      SD card longest block write time: 0.0ms
                      MCU temperature: min 41.1, current 41.6, max 42.8
                      Supply voltage: min 24.1, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0
                      Driver 0: stalled standstill
                      Driver 1: stalled standstill
                      Driver 2: stalled standstill
                      Driver 3: standstill
                      Driver 4: standstill
                      Date/time: 2017-10-15 15:01:57
                      Slowest main loop (seconds): 0.008844; fastest: 0.000033
                      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                      Bed compensation in use: none
                      Bed heater = 0, chamber heater = -1
                      Heater 0 is on, I-accum = 0.0
                      Heater 1 is on, I-accum = 0.3
                      Segments left: 0
                      Movement lock held by null
                      http is idle in state(s) 0
                      telnet is idle in state(s) 0
                      file is idle in state(s) 0
                      serial is idle in state(s) 0
                      aux is idle in state(s) 0
                      daemon is idle in state(s) 0
                      queue is idle in state(s) 0
                      Code queue is empty.
                      WiFi MAC address 5c:cf:7f:ef:4c:24
                      WiFi Vcc 3.11, reset reason Turned on by main processor
                      WiFi flash size 4194304, free heap 35064
                      WiFi IP address 192.168.1.107
                      WiFi signal strength -58dBm
                      Reconnections 0
                      • JohnOCFIIundefined
                        JohnOCFII
                        I've been leery of updating beyond 1.18.2 due to the frequent reports of WiFi issues. Today I decided to take the leap. The upgrade to 1.19.2 went well. Checking M122 my RSSI varied between -53 and -58 (the access point is one floor away in a wood framed house). I stayed connected from a web browser (Google Chrome from a Mac) for approximately 4 hours. During the middle of that 4 hour window was a single 90 minute print.
                        All seemed good. Not posting to gloat - but just wanted to add some data points. My access point is an Asus router running the third party Asus-Merlin firmware.
                        John
                        • Jareryundefined
                          Jarery
                          @JohnOCFII:
                          My setup is similar, albeit with the issues.
                          I have an Asus AC3100 as my main router about 3m away, and an AC66U about 12m away as an access point both with same firmware version, both Merlins.
                          • saironundefined
                            sairon
                            I experienced the same issue on a new Duet Wifi I received this week. I recalled that I had similar problems with some devices in the past with WMM mode enabled on the router. And indeed, disabling it fixed the issue. I have a router running OpenWrt based distribution, which allows to enable/disable WMM on per-SSID basis. I'm not sure about other routers, such as those ASUS devices mentioned here, but I think it should be at least possible to toggle WMM globally to try if it solves the problem.
                            • fmaundefined
                              fma
                              As I use an OpenWRT-based router, I'll give this a try! Thanks.
                              Frédéric
                                JohnOCFII
                                @sairon:
                                Interesting.
                                One of my routers is an Asus RT-AC68P. The other is an older RT-N66R. The DuetWifi was attached to the RT-N66R. Both are running Asuswrt-Merlin 380.68_4
                                I notice on the Wireless section - Professional tab there is an item labeled: "Enable WMM APSD" The choices are "Enable" and "Disable" I'm not sure if they mean enabled and disabled but both routers are in the default setting, which shows "Enable."
                                Seeing that this setting has something to do with power saving mode and QoS, who knows - this could be related. I do not see a setting specific to just WMM.
                                https://routerguide.net/wmm-apsd-on-or-off/
                                John
                                • saironundefined
                                  sairon
                                  @JohnOCFII:
                                  Yep, "disabling WMM" practically means "disabling WMM APSD". Even the page you've linked mentions that it can be linked to connection dropouts: "There are reported cases of mobile devices dropping connections when the WMM APSD options are turned on."
                                  As I said, it seems that disabling it resolved the issue for me, so it's worth a try if anyone faces the problem. Probably the worst thing that can happen is that they'll have worse battery performance on their mobile devices for the time of the test.
                                  • MiRundefined
                                    MiR
                                    This article:
                                    http://bbs.espressif.com/viewtopic.php?t=133
                                    mentions a parameter for esp8266 to disable powersave on the chip itself, at least when in client-mode.
                                    „You can use wifi_set_sleep_type to set sleep type for power saving and set NONE_SLEEP_T to disable power saving.“
                                    @David: Could this be worth a try?
                                      I looked at this before and I think it defaults to no power saving, but I'll check.
                                      • MiRundefined
                                        MiR
                                        At least when I checked with sta_info about a week ago the module was reporting powersave capability to the AP
                                        • Jareryundefined
                                          Jarery
                                          turned off WMM APSD
                                          So far 2 hours into a print. Not a definitive answer yet, but so far id say looks promising…
                                          As I wrote this I went back and saw pink screen "ajax error" timeout, but was able to immediately reconnect with connect button.
                                          Will continue testing
                                          Edit: disconnected 5 min later, now can't reconnect....back to square one..
                                          • fmaundefined
                                            fma
                                            I also turned off WMM. So far, no disconnect…
                                            Frédéric
