    Surfacing Macro
    CNC
    11
    28
    2.6k
      jay_s_uk @CthulhuLabs
      @cthulhulabs fantastic! I look forward to trying this when I next need it
      • Sindariusundefined
        Sindarius @CthulhuLabs
        @cthulhulabs This is really impressive! Thanks for sharing. I plan on trying it out soon myself!
        CthulhuLabsundefined 1 Reply Last reply Reply Quote 1
        • CthulhuLabsundefined
          CthulhuLabs @Sindarius
          @sindarius / @jay_s_uk
          Get a chance to try this out? Trying to see if there are any ways to improve it.
          Sindariusundefined 1 Reply Last reply Reply Quote 0
            @cthulhulabs It's been too cold in my garage to want to do any woodworking at the moment πŸ˜“
            I do have the macro copied over to my machine once it warms up enough to be in there.
            • chimaeraghundefined
              chimaeragh
              It would be nice if this macro could be made into a plugin. Then you wouldn't have to edit the macro to change parameters. Something like the CNC touchprobe plugin by @raymondstone πŸ‘
              Duet 2 Wifi, Ooznest Workbee CNC 1510
              chimaeraghundefined 1 Reply Last reply Reply Quote 1
              • psychotik2k3undefined
                psychotik2k3
                damn that would be another reason for me to update my old duet2w from RRF2.1 to 3.3 πŸ€”
                no build another cnc first
                  chimaeragh @chimaeragh
                  I tested this macro today. Works nicely, had to edit some parameters for my Ooznest touchprobe input. Thanks a lot
                  ; Adjust probe for low speed probing
                  M558 K0 P8 C"!e0stop" H20 F120 T300					; Z probe number - Z probe switch type - probe recovery 1s probe speed and travel speed
                  • sinned6915undefined
                    sinned6915 @CthulhuLabs
                    @cthulhulabs i like this macro! I am trying ot use it by I am encountering a couple of hiccups. I know this is an older thread, but I am hoping you might see this reply.
                    1. Are you using a PanelDue in conjunction with your machine?
                    2. Where/how are you controlling your spindle?
                    3. I am getting funny outputs with the move command prompts on PanelDue. I get the first one for probing Z. but not for any of the other ones. M291 Syntax looks correct. I am trying to get a PC near the machine to see what the console looks like.
                    M291 P"Insert your surfacing bit into your spindle and position it above the probe plate" R"Probing" S3 X1 Y1 Z1
                    ; Set bit above center of probe
                    G91																			; relative positioning
                    ; Probe Z component
                    G38.2 Z{move.axes[2].userPosition - (var.ProbeThickness + 2.25)}			; seek until the probe circuit is closed Z-axis 25 mm
                    G0 Z{var.ZClearanceHeight}													; rapid move Z axis 5 mm
                    G10 P1 L{var.CoordSystem} Z{var.ProbeThickness + var.ZClearanceHeight}		; store relative probe offset for coordinates system 1
                    G90																			; Absolute positioning
                    M291 P"Move to the starting X Y position for surfacing" R"Start Position" S3 X1 Y1 Z0
                    set var.StartX = move.axes[0].userPosition;
                    set var.StartY = move.axes[1].userPosition;
                    if var.Debug
                    	M118 P0 S{"StartX = " ^ var.StartX} L2
                    	M118 P0 S{"StartY = " ^ var.StartY} L2
                    M291 P"Move to the ending X Y position for surfacing" R"End Position" S3 X1 Y1 Z0
                    set var.EndX = move.axes[0].userPosition;
                    set var.EndY = move.axes[1].userPosition;
                    1. How or where are you turning your spindle on? As mine is controlled through RRF, I need to insert the tokens to turn off/on. I am thjnking before and after the while loop?
                    T1
                    G90
                    M03 S5000
                    G04 S1
                    G0 X0.0000 Y0.0000 Z3.0000
                    ; Begin surfacing loop
                    while true
                    	M291 P"Surface another layer?" S3 X0 Y0 Z0	; then prompt the user if they want to do another layer
                    M03 S3500          ; ramp spindle speed down
                    G04 S1
                    M03 S1500
                    G04 S1
                    M05
                    G04 S1
                    G90
                    chimaeraghundefined CthulhuLabsundefined 2 Replies Last reply Reply Quote 0
                      chimaeragh @sinned6915
                      @sinned6915 I have modified the macro for an Ooznest Workbee with their latest Firmware (RRF3.3). M3 starts the router and M5 stops it.
                      ; Constants
                      var Debug = false;
                      var ProbeThickness = 5;
                      var CoordSystem	= 20;
                      var StepOver = 10;
                      var DepthOfCut = 0.2;
                      var FeedRate = 8000;
                      var ZClearanceHeight = 25;
                      ; Variables
                      var StartX = 0;			; The X starting position
                      var StartY = 0;			; The Y starting position
                      var EndX = 0;			; The X ending position
                      var EndY = 0;			; The Y ending position
                      var YDir = 0;			; The direction to go in Y
                      var YDist = 0;			; The distance to go in Y
                      var YPos = 0;			; The position in Y to move to
                      var YDistLeft = 0;		; How much we have left to move in Y
                      var ZDepth = 0;			; How far down we should be in Z
                      var XSorE = "End"		; Whether X should move towards the start or the end position
                      ; If the printer hasn't been homed, home it
                      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                         G28
                      G31 K0 P500 X0 Y0 Z0								; Set trigger value - set offset and trigger height - Z probe number
                      ; Probe Z component
                      if var.Debug
                      if var.Debug
                         M118 P0 S{"EndX = " ^ var.EndX} L2
                         M118 P0 S{"EndY = " ^ var.EndY} L2
                      M291 P"Are you ready to begin surfacing?" S3 X0 Y0 Z0
                      ; Figure out which direction in Y we are going
                      if var.EndY < var.StartY
                         set var.YDir = -1;
                      elif var.EndY > var.StartY
                         set var.YDir = 1;
                      else
                         set var.YDir = 0;
                      if var.Debug
                         M118 P0 S{"YDir = " ^ var.YDir} L2
                      set var.YDist = {abs(var.StartY - var.EndY)};
                      if var.Debug
                         M118 P0 S{"YDist = " ^ var.YDist} L2
                      while true
                         if var.Debug
                         	M118 P0 S"Begin Layer Loop" L2;
                         set var.ZDepth = {var.ZDepth - var.DepthOfCut};
                         set var.YDistLeft = {var.YDist};
                         ; go to the start X and Y position then down to Z Depth
                         if var.Debug
                         	M118 P0 S{"Move to start X" ^ var.StartX ^ ",Y" ^ var.StartY} L2
                         T1
                         M3 S17500 ;M42 P1 S1
                         G0 X{var.StartX} Y{var.StartY}
                         if var.Debug
                         	M118 P0 S{"Move to start Z" ^ var.ZDepth} L2
                         G1 Z{var.ZDepth}
                         ; we should be at the Start X position so move to the End X position
                         if var.Debug
                         	M118 P0 S{"Move to X" ^ var.EndX} L2
                         G1 X{var.EndX} F{var.FeedRate}
                         set var.XSorE = "Start"
                         while var.YDistLeft > var.StepOver
                         	if var.Debug
                         		M118 P0 S"Begin Y Loop" L2
                         	; move in Y by StepOver
                         	set var.YPos = {move.axes[1].userPosition + (var.StepOver * var.YDir)}
                         	if var.Debug
                         		M118 P0 S{"Move to Y" ^ var.YPos} L2
                         	G1 Y{var.YPos} F{var.FeedRate}
                         	set var.YDistLeft = {var.YDistLeft - var.StepOver}
                         	if var.XSorE == "Start"
                         		; move X to the start position
                         		if var.Debug
                         			M118 P0 S{"Move to X" ^ var.StartX} L2
                         		G1 X{var.StartX} F{var.FeedRate}
                         		set var.XSorE = "End"
                         	else
                         		; move X to the end position
                         		if var.Debug
                         ; move in Y the rest of the distance left
                         set var.YPos = {move.axes[1].userPosition + (var.YDistLeft * var.YDir)}
                         if var.Debug
                         ; one last move in X
                         	if var.Debug
                         else
                         	if var.Debug
                         G0 Z{var.ZClearanceHeight}					; get out of the way
                         M400										; wait for the movement buffer to catch up
                         M5 ;M42 P1 S0
                      sinned6915undefined 1 Reply Last reply Reply Quote 0
                        sinned6915 @chimaeragh
                        @chimaeragh thank you. i am downloading now and will try it again.
                        chimaeraghundefined 1 Reply Last reply Reply Quote 0
                          @sinned6915 Line 89 selects the tool (T1). If your spindle is set to tool 0 (T0) change it accordingly. Line 90 sends the M3 command to start the spindle.
                            CthulhuLabs @sinned6915
                            @sinned6915 sorry for the late reply. Have not been on this forum for a while. No I am not using a PanelDue. I am using a Pi with an HDMI touch screen monitor. As for spindle I am using a Brushless Dewalt Trim Router with the ESC replaced with an ODrive. It currently requires running commands from odrivetool on the Pi.
                            @chimaeragh what all did you change in your version? I just upgraded to an ODrive Pro and can finally use an ADC input to control my spindle.
                              chimaeragh @CthulhuLabs
                              @cthulhulabs My DeWalt is configured as a spindle and is automated via a relay. So I can use M3 to start it and M5 to stop it. (Already modified my Vectric postprocessor for this)
                              I added M3 and M5 commands into the surfacing loop at line 89 and line 148 of the macro.
                              T1 ; selects the spindle Tool 1
                              M3 S17500 ; starts tool
                              CthulhuLabsundefined 1 Reply Last reply Reply Quote 0
                                CthulhuLabs @chimaeragh
                                @chimaeragh Cool. There is a variable at the top for the spindle RPMs. Now that my spindle RPM can be controlled by the Duet I plan to add it. You should probably use that in your M3 command.
                                I am thinking of rewriting this Macro to only cut in one direction to give a more uniform surface finish. Basically cut from Left to Right, raise up, rapid to the next cut, lower and repeat. There would be a flag in it to change it between Left to Right and Right to Left. Might also add a flag to go from top to bottom or bottom to top.
                                nikki-mundefined 1 Reply Last reply Reply Quote 0
                                • nikki-mundefined
                                  nikki-m @CthulhuLabs
                                  @CthulhuLabs I use your surfacing.g code on a regular basis. Love it.
                                  But is there any way to modify it so that the Depth of Cut could be adjusted by user input?
                                  It would be nice to be able to enter a different value each time I use this macro, without having to edit the code. It would be even nicer if the DOC could be modified on each susbequent pass ("run again"). Perhaps also to limit the input value to between 0.1mm and 3.0mm?
                                  HebigTundefined 1 Reply Last reply Reply Quote 0
                                  • HebigTundefined
                                    HebigT @nikki-m
                                    @nikki-m
                                    I know you can pass parameters to a macro in the macro call itself (e.g. depth of pass)
                                    Manually choosing this value on each run of the macro may be possible now using M291 on 3.5 beta firmware.
                                    • nikki-mundefined
                                      nikki-m @HebigT
                                      @HebigT Yes, I did look into the M291 function, but sadly, I am still on the v3.3 (awaiting any update from Ooznest)!!
                                      Does this mean that there is no other way to program in a variable DOC? Apart from setting up numerous versions of the macro, each with a different value for the doc?
                                      • HebigTundefined
                                        HebigT @nikki-m
                                        @nikki-m
                                        With 3.3 you should still be able to pass a parameter in the macro call. You’ll just have to modify the macro (hopefully only once!) to assign that parameter to the DOC variable (e.g. var DepthOfCut= {param.y} )
                                        It’ll still be a manual process of entering the parameter each time you start the macro, but it should save you the trouble of having to change the DOC variable within the macro each time.
                                        See the macro parameter section at this link:
                                        https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
                                        • nikki-mundefined
                                          nikki-m @HebigT
                                          @HebigT @HebigT I'm not sure I understand what you are saying here.
                                          Is there an actual command (and presumably through a screen interaction) in v3. 3 which allows a user to type in and enter a value, and to then assign this value to an existing variable?
                                          I still cannot find any means of entering an external value. I am still having to resort to having multiple versions of this macro, each wirh different values for doc.
                                          OwenDundefined 1 Reply Last reply Reply Quote 0
                                          • OwenDundefined
                                            OwenD @nikki-m
                                            @nikki-m
                                            For RRF 3.3 and later you can pass parameters using M98
                                            So you can call your macro using M98 P"mymacro.g" Y0.002
                                            and in the macro you access the parameter using param
                                            e.g.
                                            var depthOfCut = 0.001
                                            if exists(param.Y)
                                                set var.depthOfCut = param.Y
