    deployprobe.g for Euclid not running
    1.2k
    • fcwiltundefined
      fcwilt @Adamfilip
      @adamfilip
      If you have two steppers for the Y axis why do they not appear in your M584 commands?
      Normally it would look like this (based on the comments):
      M584 X0 Y1:4 Z2 E3
      Adamfilipundefined 1 Reply Last reply Reply Quote 0
      • Adamfilipundefined
        Adamfilip @fcwilt
        @fcwilt actually I use too, its changed to only a signal Y.
        sorry some old notes still linger
          Adamfilip @jay_s_uk
          @jay_s_uk yeah its weird.
          I restarted the machine. did home all.
          ran the macro and nothing.
          not even the first echo statement showed up in console
          Adamfilipundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
            Adamfilip @Adamfilip
            @adamfilip
            I copied the entire deployprobe.g code into a macro and it runs on its own
            so it seems like the deployprobe.g itself isnt being run when asked with
            M401 P1 ;Deployprobe
            fcwiltundefined oliofundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @Adamfilip
              @adamfilip
              Just to provide another point of view.
              I no longer home things as needed because I found I did not like homing taking place unexpectedly because I had tried to do something that required the printer to be homed, like mount the probe.
              So now I just check that the printer is homed and abort if it is not.
              I have a Euclid on one of my printers but I don't use the deploy/retract feature that is part of the firmware. I call my routines to mount/unmount the probe as needed. I have found that for normal operations I can keep the probe mounted except during actual printing. Any operation that needs the probe, such as setting the Z=0 Datum, mounts the probe and leaves it mounted. In the print start code just before actual printing begins the probe is unmounted.
              Just food for thought.
              • fcwiltundefined
                fcwilt @Adamfilip
                @adamfilip said in deployprobe.g for Euclid not running:
                Doesn't the firmware track the state of the probe and only run the deploy/retract routines when it thinks it needs to?
                • oliofundefined
                  oliof @Adamfilip
                  @adamfilip If the euclid is your only probe, drop the P1 and only run M401. Alternately, try P0 because your probe definition assignes ID 0.
                  Adamfilipundefined 1 Reply Last reply Reply Quote 1
                    Adamfilip @oliof
                    @oliof Thank you both M401 and M401 P0 worked!
                      @adamfilip only other error im getting in console is
                      Probe Pickup complete
                      Warning: G3000: Command is not supported
                        @adamfilip
                        G90                           ; absolute positioning
                        G0 X150 Y150 G3000            ; move to the center of the bed
                        M400                          ; wait for moves to finish
                          @adamfilip probably just a typo and should be F
                          • Phaedruxundefined Phaedrux has marked this topic as solved
