    deployprobe.g for Euclid not running
    1.2k
    • Adamfilipundefined
      Adamfilip @Adamfilip
      @adamfilip I run a macro that runs the deployprobe.g
      M401 P1 ;Deployprobe
      • Stephen6309undefined
        Stephen6309 @Adamfilip
        @adamfilip I use this code to check homing:
        while iterations < #move.axes & move.axes[iterations].visible
        	if !move.axes[iterations].homed
        		G28
        		break
          jay_s_uk @Adamfilip
          @adamfilip so if your X and Y (assuming they are driver 0 and 1) aren't homed, it should home. If they are homed, it should echo stop1.
          Are you trying this with or without the motors homed?
          Adamfilipundefined 1 Reply Last reply Reply Quote 0
            Adamfilip @jay_s_uk
            @jay_s_uk
            I run this after i have already homed
            this is my config if it helps
            ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
            ;M564 H0											; allow movement without homing
            G90                                              ; send absolute coordinates...
            M83                                              ; ...but relative extruder moves
            M550 P"TitanXY"                                  ; set printer name
            M669 K0                                          ; Motion Kinematics for Cartesian mode
            M552 S1                                          ; enable network
            M586 P0 S1                                       ; enable HTTP
            M586 P1 S0                                       ; disable FTP
            M586 P2 S0                                       ; disable Telnet
            M569 P0 S0                           			; X Motor physical drive 0 goes backwards previously P0
            M569 P1 S1										; Y Motor
            M569 P2 S1                                      ; Z physical drive 2 goes backwards
            M569 P3 S1                                  ; E0 Extruder physical drive 3 goes Forwards
            ;M569 P4 S1                                      ; 2nd Y Motor on E1 Driver
            M584 X0 Y1 Z2 E3                              ; set drive mapping , Y is on two drivers. E1 as well
            M350 X16 Y16 Z4 I1                             ; configure microstepping without interpolation, previously 32
            M350 E16 I1                                     ; configure microstepping with interpolation
            M92 X80 Y80 Z800 E409             				; set steps per mm
            M566 X900 Y900 Z50 E1600 						; Set maximum instantaneous speed changes (mm/min) JERK
            M203 X21000 Y21000 Z500 E10000 				; Set maximum speeds (mm/min)
            M201 X2000 Y2000 Z50 E5000 					; Set accelerations (mm/s^2)
            ;M204 P1000 T3000								; Set printing and travel accelerations
            M906 X1100 Y1100 Z1200 E1200 I30 				; Set motor currents (mA) and motor idle factor in per cent X1400 Y1400 Z1300
            M84 S30 ; Set idle timeout
            M572 D0 S0.01									; Pressure Advance                                        ; Set idle timeout
            M208 X0 Y0 Z0 S1                                 ; set axis minima
            M208 X300 Y300 Z550 S0                           ; set axis maxima
            M574 X2 S1 P"!xstop"   ; X max active high endstop switch
            M574 Y2 S1 P"!ystop"   ; Y max active high endstop switch
            M574 Z1 S1 P"!zstop"   ; Z min active high endstop switch
            ;Euclid Settings
            M574 E1 S2
            M558 K0 P5 C"^zprobe.in" H4 F500 60 T9000 A1 S0.01
            G31 K0 P500 X0 Y-39 Z3.55
            M557 X10:290 Y10:290 S40                      ; define mesh grid S86 =  Spacing 86mm
            ;Magnetic Filament Monitor
            ;M591 D0 P3 C"e1_stop" S1  ; filament monitor connected to E0_stop
            ;M591 D0 ; display filament sensor parameters for extruder drive 0
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                            ; create bed heater output on bedheat and map it to sensor 0
            M140 H0											; Map heated bed to heater 0
            M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
            M307 H1 B0 R1.591 C187.0:154.2 D7.57 S1.00 V24.1
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                             ; create nozzle heater output on e0heat and map it to sensor 1
            M143 H1 S285									; set temperature limit for heater 1 to 280C
            M307 H1 R1.71 C175.5:157.9 D5.73 S1.00 V24.1
            ;Chamber Temp
            M308 S2 P"Chamber" Y"thermistor" T100000 B4725 C7.06e-8 A"Chamber"
            M950 F0 C"fan2" Q500                         ;create fan 2 on pin fan0 and set its frequency
            M106 P0 S0 H-1                            ; set fan 0 value. Thermostatic control is turned off
            ;M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
            ;M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
            ;M950 F2 C"fan1" Q500                             ; create fan 2 on pin fan1 and set its frequency
            ;M106 P2 S1 H1 T45                                ; set fan 2 value. Thermostatic control is turned on
            M563 P0 D0 H1 F0                                 ; define tool 0
            G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
            G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
            ;M564 S0 H0										;disable homing and no limits on movement
            jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @Adamfilip
              @adamfilip it should just run then. I don't see anything wrong with the logic.
              What version of RRF are you running?
              Adamfilipundefined 2 Replies Last reply Reply Quote 0
                Adamfilip @jay_s_uk
                @jay_s_uk
                Board: Duet 2 WiFi (2WiFi)
                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
                Duet WiFi Server Version: 1.26
                • fcwiltundefined
                  fcwilt @Adamfilip
                  @adamfilip
                  If you have two steppers for the Y axis why do they not appear in your M584 commands?
                  Normally it would look like this (based on the comments):
                  M584 X0 Y1:4 Z2 E3
                    Adamfilip @fcwilt
                    @fcwilt actually I use too, its changed to only a signal Y.
                    sorry some old notes still linger
                      Adamfilip @jay_s_uk
                      @jay_s_uk yeah its weird.
                      I restarted the machine. did home all.
                      ran the macro and nothing.
                      not even the first echo statement showed up in console
                      Adamfilipundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                        @adamfilip
                        I copied the entire deployprobe.g code into a macro and it runs on its own
                        so it seems like the deployprobe.g itself isnt being run when asked with
                        fcwiltundefined oliofundefined 2 Replies Last reply Reply Quote 0
                        • fcwiltundefined
                          fcwilt @Adamfilip
                          @adamfilip
                          Just to provide another point of view.
                          I no longer home things as needed because I found I did not like homing taking place unexpectedly because I had tried to do something that required the printer to be homed, like mount the probe.
                          So now I just check that the printer is homed and abort if it is not.
                          I have a Euclid on one of my printers but I don't use the deploy/retract feature that is part of the firmware. I call my routines to mount/unmount the probe as needed. I have found that for normal operations I can keep the probe mounted except during actual printing. Any operation that needs the probe, such as setting the Z=0 Datum, mounts the probe and leaves it mounted. In the print start code just before actual printing begins the probe is unmounted.
                          Just food for thought.
                          • fcwiltundefined
                            fcwilt @Adamfilip
                            @adamfilip said in deployprobe.g for Euclid not running:
                            Doesn't the firmware track the state of the probe and only run the deploy/retract routines when it thinks it needs to?
                            • oliofundefined
                              oliof @Adamfilip
                              @adamfilip If the euclid is your only probe, drop the P1 and only run M401. Alternately, try P0 because your probe definition assignes ID 0.
                              Adamfilipundefined 1 Reply Last reply Reply Quote 1
                                Adamfilip @oliof
                                @oliof Thank you both M401 and M401 P0 worked!
                                  @adamfilip only other error im getting in console is
                                  Probe Pickup complete
                                  Warning: G3000: Command is not supported
                                    @adamfilip
                                    G90                           ; absolute positioning
                                    G0 X150 Y150 G3000            ; move to the center of the bed
                                    M400                          ; wait for moves to finish
                                      @adamfilip probably just a typo and should be F
                                      • Phaedruxundefined Phaedrux has marked this topic as solved
